[petsc-users] Solving complex linear sparse matrix in parallel + external library
Matthew Knepley
knepley at gmail.com
Tue Nov 27 04:53:45 CST 2018
On Tue, Nov 27, 2018 at 4:29 AM Sal Am <tempohoper at gmail.com> wrote:
> This can happen if you use an 'mpiexec' which is from a different MPI than
>> the one you compiled PETSc with.
> that is odd, I tried removing the --download-mpich from the config and
> tried --with-mpi=1 (which should be default anyways) and retried it with
> --with-mpich=1.
Your MPI is still broken. Some default MPIs, like those installed with
Apple, are broken. If you are on Apple
I would recommend using --download-mpich, but make sure you use
$PETSC_DIR/$PETSC_ARCH/bin/mpiexec.
If you reconfigure, you either have to specify a different --PETSC_ARCH, or
delete the $PETSC_DIR/$PETSC_ARCH completely. Otherwise, you can get bad
interaction with the libraries already sitting there.
Matt
> Current reconfig file:
> '--download-mpich',
> '--download-mumps',
> '--download-scalapack',
> '--download-superlu_dist',
> '--with-cc=gcc',
> '--with-clanguage=cxx',
> '--with-cxx=g++',
> '--with-debugging=no',
> '--with-fc=gfortran',
> '--with-mpi=1',
> '--with-mpich=1',
> '--with-scalar-type=complex',
> 'PETSC_ARCH=linux-opt'
> Still does not work though, I tried executing ex11 in
> ksp/ksp/example/tutorial/ex11 which should solve a linear system in
> parallel by running mpiexec -n 2 but it prints out
> Mat Object: 1 MPI processes
> twice.
> What am I missing?
> Why would you want a minimum iterations? Why not set a tolerance and a
>> max? What would you achieve with a minimum?
> I thought PETSc might not be iterating far enough, but after having had a
> look at KSPSetTolerances it makes more sense.
> Instead of 'preonly', where you do not want a residual, use 'richardson'
>> or 'gmres' with a max of 1 iterate (-ksp_max_it 1)
> So I tried that by executing: mpiexec -n 4 ./test -ksp_type richardson
> -pc_type lu -pc_factor_mat_solver_type mumps -ksp_max_it 1
> on the command line. However, nothing prints out on the terminal (aside
> from PetscPrintf if I have them enabled).
> Thank you.
> On Fri, Nov 16, 2018 at 12:00 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Fri, Nov 16, 2018 at 4:23 AM Sal Am via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi,
>>> I have a few questions:
>>> 1. The following issue/misunderstanding:
>>> My code reads in two files one PETSc vector and one PETSc matrix (b and
>>> A from Ax=b, size ~65000x65000).
>>> and then calls KSP solver to solve it by running the following in the
>>> terminal:
>>> mpiexec - n 2 ./SolveSys -ksp_type preonly -pc_type lu
>>> -pc_factor_mat_solver mumps
>>> Now mumps is supposed to work in parallel and complex, but the code is
>>> not solved in parallel it seems. It just prints the result twice. Adding
>>> -log_view gives me
>>> "./SolveSys on a linux-opt named F8434 with 1 processor..." printed
>>> twice.
>> than the one you compiled PETSc with.
>>> 2. Using iterative solvers, I am having difficulty getting convergence.
>>> I found that there is a way to set the maximum number of iterations, but is
>>> there a minimum I can increase?
>>> 3. The residual is not computed when using direct external solvers. What
>>> is proper PETSc way of doing this?
>> Thanks,
>> Matt
>>> -----------------------------------------------------The
>>> code---------------------------------------
>>> #include <petscksp.h>
>>> #include <iostream>
>>> int main(int argc,char **args)
>>> Vec x,b; /* approx solution, RHS */
>>> Mat A; /* linear system matrix */
>>> KSP ksp; /* linear solver context */
>>> PetscReal norm; /* norm of solution error */
>>> PC pc;
>>> PetscMPIInt rank, size;
>>> PetscViewer viewer;
>>> PetscInt its, i;
>>> PetscErrorCode ierr;
>>> PetscScalar *xa;
>>> PetscBool flg = PETSC_FALSE;
>>> ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return
>>> ierr;
>>> MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>>> MPI_Comm_size(PETSC_COMM_WORLD,&size);
>>> #if !defined(PETSC_USE_COMPLEX)
>>> SETERRQ(PETSC_COMM_WORLD,1,"This example requires complex numbers");
>>> #endif
>>> Compute the matrix and right-hand-side vector that define
>>> the linear system, Ax = b.
>>> ierr = PetscPrintf(PETSC_COMM_WORLD,"reading vector in binary from
>>> Vector_b.dat ...\n");CHKERRQ(ierr);
>>> ierr =
>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Vector_b.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>> ierr = VecCreate(PETSC_COMM_WORLD, &b);CHKERRQ(ierr);
>>> ierr = VecLoad(b,viewer); CHKERRQ(ierr);
>>> ierr = PetscPrintf(PETSC_COMM_WORLD,"reading matrix in binary from
>>> Matrix_A.dat ...\n");CHKERRQ(ierr);
>>> ierr =
>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Matrix_A.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>>> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>>> ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>>> ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>>> ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>>> Create the linear solver and set various options
>>> PetscPrintf(PETSC_COMM_WORLD, "Creating KSP\n");
>>> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>> PetscPrintf(PETSC_COMM_WORLD, "KSP Operators\n");
>>> ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>>> ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
>>> ierr = PCSetType(pc, PCLU);CHKERRQ(ierr);
>>> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>> Solve the linear system
>>> ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>>> ierr = KSPSetUpOnBlocks(ksp);CHKERRQ(ierr);
>>> ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>>> PetscPrintf(PETSC_COMM_WORLD, "Solved");
>>> Free work space. All PETSc objects should be destroyed when they
>>> are no longer needed.
>>> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>>> ierr = VecDestroy(&x);CHKERRQ(ierr);
>>> ierr = VecDestroy(&b);CHKERRQ(ierr);
>>> ierr = MatDestroy(&A);CHKERRQ(ierr);
>>> ierr = PetscFinalize();
>>> return ierr;
>>> Kind regards,
>>> Sal
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181127/65f372c0/attachment.html>
