[petsc-users] Incorrect local row ranges allocated to the processes i.e. rstart and rend are not what I expected
Dave May dave.mayhem23 at gmail.com
Fri Nov 23 14:24:12 CST 2018
On Fri, 23 Nov 2018 at 19:39, Klaus Burkart via petsc-users <
petsc-users at mcs.anl.gov> wrote:
>     PetscInitialize(0,0,PETSC_NULL,PETSC_NULL);
>     MPI_Comm_size(PETSC_COMM_WORLD,&size);
>     MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>     MatCreate(PETSC_COMM_WORLD,&A);
>     //MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);
>     MatSetType(A,MATMPIAIJ);
>     PetscInt local_size = PETSC_DECIDE;
>     PetscSplitOwnership(PETSC_COMM_WORLD, &local_size, &N);
>     MPI_Scan(&local_size, &rend, 1, MPIU_INT, MPI_SUM, PETSC_COMM_WORLD);
>     rstart = rend - local_size;
>     PetscInt d_nnz[local_size], o_nnz[local_size];
> compute d_nnz and o_nnz here
>     MatMPIAIJSetPreallocation(A,0,d_nnz,0,o_nnz);
>     PetscSynchronizedPrintf(PETSC_COMM_WORLD,"local_size   =  %d, on
> process %d\n", local_size, rank);
>     PetscSynchronizedPrintf(PETSC_COMM_WORLD,"rstart =  %d, on process
> %d\n", rstart, rank);
>     PetscSynchronizedPrintf(PETSC_COMM_WORLD,"rend =  %d, on process
> %d\n", rend, rank);
Please read the manual page:
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscSynchronizedPrintf.html
It explicitly states
"REQUIRES a call to PetscSynchronizedFlush() by all the processes after the
completion of the calls to PetscSynchronizedPrintf() for the information
from all the processors to be printed."
  Dave
>     PetscFinalize();
> Gives me :
> local_size   =  25, on process 0
> rstart =  0, on process 0
> rend =  25, on process 0
> but there are 4 processes.
> Am Freitag, 23. November 2018, 19:51:26 MEZ hat Smith, Barry F. <
> bsmith at mcs.anl.gov> Folgendes geschrieben:
>   The correct answer is computed but you are printing out the answer all
> wrong.
>   For PetscPrintf(PETSC_COMM_WORLD) only the FIRST process ever prints
> anything so you are having the first process print out the same values
> repeatedly.
>     Don't have the loop over size in the code. You can use
> PetscSynchronizedPrintf() to have each process print its own values.
>     Barry
> > On Nov 23, 2018, at 6:44 AM, Klaus Burkart via petsc-users <
> > Hello,
> > I am trying to compute the local row ranges allocated to the processes
> i.e. rstart and rend of each process, needed as a  prerequisite for
> MatMPIAIJSetPreallocation using d_nnz and o_nnz.
> > I tried the following:
> >    for (rank = 0; rank < size; rank++) {
> >    PetscPrintf(PETSC_COMM_WORLD,"local_size  =  %d, on process %d\n",
> local_size, rank);
> >    PetscPrintf(PETSC_COMM_WORLD,"rstart =  %d, on process %d\n", rstart,
> rank);
> >    PetscPrintf(PETSC_COMM_WORLD,"rend =  %d, on process %d\n", rend,
> rank);
> >    PetscFinalize();
> > The local size is 25 rows on each process but rstart and rend are 0 and
> 25 on all processes, I expected 0 and 25, 25 and 50, 50 and 75 and 75 and
> 101. N = 100
> > I can't spot the error. Any ideas, what's the problem?
> > Klaus
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181123/6a73cdf9/attachment.html>
