[petsc-users] Incorrect local row ranges allocated to the processes i.e. rstart and rend are not what I expected
Fri Nov 23 10:55:12 CST 2018
On Fri, Nov 23, 2018 at 9:54 AM Klaus Burkart via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to compute the local row ranges allocated to the processes
> i.e. rstart and rend of each process, needed as a  prerequisite for
> MatMPIAIJSetPreallocation using d_nnz and o_nnz.
> I tried the following:
>     PetscInitialize(0,0,PETSC_NULL,PETSC_NULL);
>     MPI_Comm_size(PETSC_COMM_WORLD,&size);
>     MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>     MatCreate(PETSC_COMM_WORLD,&A);
>     MatSetType(A,MATMPIAIJ);
>     PetscInt local_size = PETSC_DECIDE;
>     PetscSplitOwnership(PETSC_COMM_WORLD, &local_size, &N);
>     MPI_Scan(&local_size, &rend, 1, MPIU_INT, MPI_SUM, PETSC_COMM_WORLD);
This looks right to me. Not sure what your problem is. However, you can
always use PetscLayout to do
this automatically.
     Matt
>     rstart = rend - local_size;
>     PetscInt d_nnz[local_size], o_nnz[local_size];
> compute d_nnz and o_nnz here
>     MatMPIAIJSetPreallocation(A,0,d_nnz,0,o_nnz);
>     for (rank = 0; rank < size; rank++) {
>     PetscPrintf(PETSC_COMM_WORLD,"local_size   =  %d, on process %d\n",
> local_size, rank);
>     PetscPrintf(PETSC_COMM_WORLD,"rstart =  %d, on process %d\n", rstart,
> rank);
>     PetscPrintf(PETSC_COMM_WORLD,"rend =  %d, on process %d\n", rend,
> rank);
>     PetscFinalize();
> The local size is 25 rows on each process but rstart and rend are 0 and 25
> on all processes, I expected 0 and 25, 25 and 50, 50 and 75 and 75 and 101.
> N = 100
> I can't spot the error. Any ideas, what's the problem?
> Klaus
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181123/96434e17/attachment.html>
