[petsc-users] Question about DMDAGetElements
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Mon Nov 19 15:30:01 CST 2018
I think what confused me was the fact that using DMCreateMatrix(da,&A)
created a 12x12 matrix with 144 elements but summing up nel*nen from each
rank gives only 2*2+3*2+3*2+3*2=20 elements. So this means that
DMDAGetElements returns the elements for the vector created on the mesh and
this happens to be used for indexing the matrix (created using the same DM
object) via the local indices. Luckily since this code just creates a
tridiagonal matrix, this works here (since if I wanted to create a dense
matrix I'd want to have access to all the indices which would happen if the
addressable indices at each rank (for the submatrix stored locally) add up
to the size of the total matrix). Is my understanding correct?
Thanks for the help!
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181119/e6c04970/attachment-0001.html>
