[petsc-users] PETSc (3.9.0) GAMG weak scaling test issue
"Alberto F. Martín"
amartin at cimne.upc.edu
Mon Nov 19 07:40:20 CST 2018
Dear Matthew,
using either "-build_twosided allreduce" or "-build_twosided redscatter"
workarounds the Intel MPI internal error!
Besides, with Intel MPI, the weak scaling figures look like:
**preconditioner set up**
[0.8865120411, 2.598261833, 3.780511856]
**PCG stage**
[0.5701429844, 1.771002054, 2.292135954]
**number of PCG iterations**
[9,14,15]
which now I consider much more reasonable, in particular, for the
preconditioner set-up stage, compared to the ones
that I obtained with OpenMPI 1.10.7 and "-build_twosided ibarrier", below.
Best regards,
Alberto.
On 19/11/18 12:26, Matthew Knepley wrote:
> On Mon, Nov 19, 2018 at 5:52 AM "Alberto F. Martín"
> <amartin at cimne.upc.edu <mailto:amartin at cimne.upc.edu>> wrote:
> Dear Mark, Dear Matthew,
> in order to discard load imbalance as the cause of the reported
> weak scaling issue in the GAMG preconditioner
> set-up stage (as you said, we were feeding GAMG with a suboptimal
> mesh distribution, having empty processors,
> among others), we simplified the weak scaling test by considering
> the standard body-fitted trilinear (Q1) FE discretization
> of the 3D Poisson problem on a unit cube discretized with a
> */uniform, structured hexahedral mesh,/* /*partitioned*//*
> *//*optimally (by hand) among processors*/, with a fixed load/core
> of 30**3 hexahedra/core. Thus, all processors have the same load
> (up-to strong Dirichlet boundary conditions on the subdomains
> touching the global boundary), and the edge-cut is minimum.
> We used the following GAMG preconditioner options:
> -pc_type gamg
> -pc_gamg_type agg
> -pc_gamg_est_ksp_type cg
> -mg_levels_esteig_ksp_type cg
> -mg_coarse_sub_pc_type cholesky
> -mg_coarse_sub_pc_factor_mat_ordering_type nd
> -pc_gamg_process_eq_limit 50
> -pc_gamg_square_graph 10
> -pc_gamg_agg_nsmooths 1
> The results that we obtained for 48 (4x4x3 subdomains), 10,368
> (24x24x18 subdomains), and 16,464
> (28x28x21 subdomains) CPU cores are as follows:
> [0.9844961860, *7.017674042*, *12.10154881*]
> **PCG stage**
> [0.5849160422, 1.515251888, 1.859617710]
> [9,14,15]
> As you can observe, *there is still a significant time increase
> when scaling the problem from 48 to 10K/16K MPI tasks**
> **for the preconditioner setup stage. *This time increase is not
> as significant for the PCG stage.
> Actually, its almost perfect for PCG, given that
> 14/9 * 0.98 = 1.52 (Eff 100%)
> 15/14 * 1.52 = 1.63 (Eff 88%)
> Mark would have better comments on the scalability of the setup stage.
> **Please find attached the combined
> output of -ksp_view and -log_view for these three points of the
> weak scaling curve.
> Given these results, I am starting to suspect that something
> within the underlying software + hardware stack might be
> responsible for this. I am using OpenMPI 1.10.7 + Intel compilers
> version 18.0. The underlying supercomputer is MN-IV at
> BSC
> (https://www.bsc.es/marenostrum/marenostrum/technical-information). Have
> you ever conducted a weak scaling test
> of GAMG with OpenMPI on a similar computer architecture? Can you
> share your experience with us?
> (versions tested, outcome, etc.)
> We also tried an alternative MPI library, Intel(R) MPI Library for
> Linux* OS, Version 2018 Update 4 Build 20180823 (id: 18555),
> *without success. *For this MPI library, the preconditioner set-up
> stage crashes (find attached stack frames, and internal MPI library
> errors) for the largest two core counts (it did not crash for the
> 48 CPU cores case), while it did not crash with OpenMPI 1.10.7.
> Have you ever experienced errors like the ones
> attached? Is there anyway to set up PETSc such that the subroutine
> that crashes is replaced by an alternative implementation of
> the same concept? (this would be just a workaround).
> It certainly feels like an MPI (or driver) bug:
> libmpi.so.12 00007F460E3AEBC8 PMPIDI_CH3I_Progr Unknown Unknown
> libmpi.so.12 00007F460E72B90C MPI_Testall Unknown Unknown
> libpetsc.so.3.9.0 00007F4607391FFE PetscCommBuildTwo Unknown Unknown
> You can try another variant using
> -build_twosided <allreduce|ibarrier|redscatter>
> I think ibarrier is currently the default if supported, but -help
> should tell you.
> Thanks,
> Matt
> It might be a BUG in the Intel MPI library, although I cannot
> confirm it. We also got
> these errors with the unfitted FEM+space-filling curves version of
> our code.
> Thanks a lot for your help and valuable feedback!
> Best regards,
> Alberto.
> On 08/11/18 17:29, Mark Adams wrote:
>> I did not configured PETSc with ParMetis support. Should I?
>> I figured it out when I tried to use "-pc_gamg_repartition".
>> PETSc complained that it was not compiled with ParMetis support.
>> You need ParMetis, or some parallel mesh partitioner, configured
>> to use repartitioning. I would guess that "-pc_gamg_repartition"
>> would not help and might hurt, because it just does the coarse
>> grids, not the fine grid. But it is worth a try. Just configure
>> with --download-parmetis
>> The problem is that you are using space filling curves on the
>> background grid and are getting empty processors. Right? The
>> mesh setup phase is not super optimized, but your times
>> And you said in your attachment that you added the near null
>> space, but just the constant vector. I trust you mean the three
>> translational rigid body modes. That is the default and so you
>> should not see any difference. If you added one vector of all 1s
>> then that would be bad. You also want the rotational rigid body
>> modes. Now, you are converging pretty well and if your solution
>> does not have much rotation in it the the rotational modes are
>> not needed, but they are required for optimality in general.
> Alberto F. Martín-Huertas
> Senior Researcher, PhD. Computational Science
> Centre Internacional de Mètodes Numèrics a l'Enginyeria (CIMNE)
> Parc Mediterrani de la Tecnologia, UPC
> Esteve Terradas 5, Building C3, Office 215,
> 08860 Castelldefels (Barcelona, Spain)
> Tel.: (+34) 9341 34223
> e-mail:amartin at cimne.upc.edu <mailto:e-mail:amartin at cimne.upc.edu>
> FEMPAR project co-founder
> web:http://www.fempar.org
> ________________
> IMPORTANT NOTICE
> All personal data contained on this mail will be processed confidentially and registered in a file property of CIMNE in
> order to manage corporate communications. You may exercise the rights of access, rectification, erasure and object by
> letter sent to Ed. C1 Campus Norte UPC. Gran Capitán s/n Barcelona.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
web: http://www.fempar.org
________________
IMPORTANT NOTICE
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181119/a09342ed/attachment.html>
