[petsc-users] Expecting Explanation
Fazlul Huq
huq2090 at gmail.com
Sun Nov 18 09:31:15 CST 2018
So I have to remove mpiexec from usr/bin
and keep it in home/petsc-3.10.2/lib/petsc/bin
Is it?
Thanks.
Sincerely,
Huq
On Sun, Nov 18, 2018 at 6:49 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Nov 17, 2018 at 10:37 PM Fazlul Huq via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> I tried to reconfigure PETSc and I got the following error message:
> Do not reconfigure, just use the mpiexec in $PETSC_DIR/$PETSC_ARCH/bin as
> Barry suggested.
> Matt
>> Unable to find mpi in default locations!
>> Perhaps you can specify with --with-mpi-dir=<directory>
>> If you do not want MPI, then give --with-mpi=0
>> You might also consider using --download-mpich instead
>> I also got this error message last time when I have installed first and I
>> have used --download-mpich command.
>> The log file is attached herewith along with terminal screenshot.
>> I am not sure what to do now.
>> Thanks.
>> Sincerely,
>> Huq
>> On Sat, Nov 17, 2018 at 5:26 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>> Then use
>>> ${PETSC_DIR}/${PETSC_ARCH}/bin/mpiexec
>>> don't just use the random (wrong) mpiexec that is in your path.
>>> Barry
>>> > On Nov 17, 2018, at 5:22 PM, Fazlul Huq <huq2090 at gmail.com> wrote:
>>> > I think when I have installed PETSc, I did --download-mpich.
>>> > How can I correct it? Shall I install PETSc again?
>>> > Thanks.
>>> > Sincerely,
>>> > Huq
>>> > On Sat, Nov 17, 2018 at 4:53 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>> > > On Nov 17, 2018, at 3:51 PM, Fazlul Huq via petsc-users <
>>> > > Thanks for the answer.
>>> > > So, when I run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4
>>> ./ex6" shouldn't it spit out
>>> > > the error "This is a uniprocessor example only!"?
>>> > > But it didn't do that rather run the code 2/4 times.
>>> > This can happen if you use the "wrong" mpiexec; that is a different
>>> mpiexec than the one associated with the mpi you built PETSc with. For
>>> example if some mpiexec is in your path and you used ./configure
>>> --download-mpich
>>> > Barry
>>> > > Thanks.
>>> > > Sincerely,
>>> > > Huq
>>> > > On Sat, Nov 17, 2018 at 1:12 PM Fazlul Huq <huq2090 at gmail.com>
>>> wrote:
>>> > > Hello PETSc developers,
>>> > > In example 6 or vec section I don't understand this line:
>>> > > if (size != 1) SETERRQ(PETSC_COMM_SELF,1,"This is a uniprocessor
>>> example only!");
>>> > > I tried to run the code with "mpiexec -n 2 ./ex6" or "mpiexec -n 4
>>> ./ex6" or even "mpiexec -n 1 ./ex6" it the code runs properly.
>>> > > Thanks.
>>> > > Sincerely,
>>> > > Huq
>>> > > Fazlul Huq
>>> > > Graduate Research Assistant
>>> > > Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>> > > University of Illinois at Urbana-Champaign (UIUC)
>>> > > E-mail: huq2090 at gmail.com
>>> > > Fazlul Huq
>>> > Fazlul Huq
>> Fazlul Huq
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181118/6d3c771c/attachment.html>
