[petsc-users] Solving complex linear sparse matrix in parallel + external library
Matthew Knepley
knepley at gmail.com
Fri Nov 16 06:00:26 CST 2018
On Fri, Nov 16, 2018 at 4:23 AM Sal Am via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I have a few questions:
> 1. The following issue/misunderstanding:
> My code reads in two files one PETSc vector and one PETSc matrix (b and A
> from Ax=b, size ~65000x65000).
> and then calls KSP solver to solve it by running the following in the
> terminal:
> mpiexec - n 2 ./SolveSys -ksp_type preonly -pc_type lu
> -pc_factor_mat_solver mumps
> Now mumps is supposed to work in parallel and complex, but the code is not
> solved in parallel it seems. It just prints the result twice. Adding
> -log_view gives me
> "./SolveSys on a linux-opt named F8434 with 1 processor..." printed twice.
This can happen if you use an 'mpiexec' which is from a different MPI than
the one you compiled PETSc with.
> 2. Using iterative solvers, I am having difficulty getting convergence. I
> found that there is a way to set the maximum number of iterations, but is
> there a minimum I can increase?
Why would you want a minimum iterations? Why not set a tolerance and a max?
What would you achieve with a minimum?
> 3. The residual is not computed when using direct external solvers. What
> is proper PETSc way of doing this?
Instead of 'preonly', where you do not want a residual, use 'richardson' or
'gmres' with a max of 1 iterate (-ksp_max_it 1)
Matt
> -----------------------------------------------------The
> code---------------------------------------
> #include <petscksp.h>
> #include <iostream>
> int main(int argc,char **args)
> Vec x,b; /* approx solution, RHS */
> Mat A; /* linear system matrix */
> KSP ksp; /* linear solver context */
> PetscReal norm; /* norm of solution error */
> PC pc;
> PetscMPIInt rank, size;
> PetscViewer viewer;
> PetscInt its, i;
> PetscErrorCode ierr;
> PetscScalar *xa;
> PetscBool flg = PETSC_FALSE;
> ierr = PetscInitialize(&argc,&args,(char*)0,help);if (ierr) return ierr;
> MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
> MPI_Comm_size(PETSC_COMM_WORLD,&size);
> #if !defined(PETSC_USE_COMPLEX)
> SETERRQ(PETSC_COMM_WORLD,1,"This example requires complex numbers");
> #endif
> Compute the matrix and right-hand-side vector that define
> the linear system, Ax = b.
> ierr = PetscPrintf(PETSC_COMM_WORLD,"reading vector in binary from
> Vector_b.dat ...\n");CHKERRQ(ierr);
> ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Vector_b.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
> ierr = VecCreate(PETSC_COMM_WORLD, &b);CHKERRQ(ierr);
> ierr = VecLoad(b,viewer); CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_WORLD,"reading matrix in binary from
> Matrix_A.dat ...\n");CHKERRQ(ierr);
> ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"../../python/petscpy/Matrix_A.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
> ierr = MatLoad(A,viewer);CHKERRQ(ierr);
> ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
> ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
> Create the linear solver and set various options
> PetscPrintf(PETSC_COMM_WORLD, "Creating KSP\n");
> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
> PetscPrintf(PETSC_COMM_WORLD, "KSP Operators\n");
> ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
> ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
> ierr = PCSetType(pc, PCLU);CHKERRQ(ierr);
> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> Solve the linear system
> ierr = KSPSetUp(ksp);CHKERRQ(ierr);
> ierr = KSPSetUpOnBlocks(ksp);CHKERRQ(ierr);
> ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
> PetscPrintf(PETSC_COMM_WORLD, "Solved");
> Free work space. All PETSc objects should be destroyed when they
> are no longer needed.
> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
> ierr = VecDestroy(&x);CHKERRQ(ierr);
> ierr = VecDestroy(&b);CHKERRQ(ierr);
> ierr = MatDestroy(&A);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return ierr;
> Kind regards,
> Sal
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181116/00784fe5/attachment-0001.html>
