[petsc-users] petsc4py help with parallel execution
Ivan
ivan.voznyuk.work at gmail.com
Thu Nov 15 11:33:45 CST 2018
Matthew,
*/As I wrote before, its not impossible. You could be directly calling
PMI, but I do not think you are doing that./*
Could you precise what is PMI? and how can we directly use it? It might
be a key to this mystery!
*/Why do you think its running on 8 processes?/*
Well, we base our opinion on 3 points:
1) htop shows a total loading of 8 processors
2) system monitor shows the same behavior
3) Time. 8 seconds vs 70 seconds, although we have a very similar PC configs
*/I think its much more likely that there are differences in the solver
(use -ksp_view to see exactly what solver was used), then to think it is
parallelism. /*
We actually use the incidental code. Or do you think that independently
on this fact, and the fact that we precise in the code
"ksp.getPC().setFactorSolverType('mumps')" ksp may solve the system of
equations using different solver?
*/Moreover, you would never ever ever see that much speedup on a laptop
since all these computations /*
*/are bandwidth limited./*
I agree to this point. But I would think that taking into account that
his computer is *a bit* more powerful and his code is executed in
parallel, we might have an acceleration. We, for example, tested other,
more physical codes. And noted acceleration x4 - x6
Thank you for your contribution,
Ivan
On 15/11/2018 18:07, Matthew Knepley wrote:
> On Thu, Nov 15, 2018 at 11:59 AM Ivan Voznyuk
> <ivan.voznyuk.work at gmail.com <mailto:ivan.voznyuk.work at gmail.com>> wrote:
> Hi Matthew,
> Does it mean that by using just command python3 simple_code.py
> (without mpiexec) you _cannot_ obtain a parallel execution?
> It s been 5 days we are trying to understand with my colleague how
> he managed to do so.
> It means that by using simply python3 simple_code.py he gets 8
> processors workiing.
> By the way, we wrote in his code few lines:
> rank = PETSc.COMM_WORLD.Get_rank()
> size = PETSc.COMM_WORLD.Get_size()
> and we got rank = 0, size = 1
> This is MPI telling you that you are only running on 1 processes.
> However, we compilator arrives to KSP.solve(), somehow it turns on
> 8 processors.
> This problem is solved on his PC in 5-8 sec (in parallel, using
> _python3 simple_code.py_), on mine it takes 70-90 secs (in
> sequantial, but with the same command _python3 simple_code.py_)
> to think it is parallelism. Moreover, you would never ever ever see
> that much speedup on a laptop since all these computations
> Thanks,
> Matt
> So, conclusion is that on his computer this code works in the same
> way as scipy: all the code is executed in sequantial mode, but
> when it comes to solution of system of linear equations, it runs
> on all available processors. All this with just running python3
> my_code.py (without any mpi-smth)
> Is it an exception / abnormal behavior? I mean, is it something
> irregular that you, developers, have never seen?
> Thanks and have a good evening!
> Ivan
> P.S. I don't think I know the answer regarding Scipy...
> On Thu, Nov 15, 2018 at 2:39 PM Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> On Thu, Nov 15, 2018 at 8:07 AM Ivan Voznyuk
> Hi Matthew,
> Thanks for your reply!
> Let me precise what I mean by defining few questions:
> 1. In order to obtain a parallel execution of
> simple_code.py, do I need to go with mpiexec python3
> simple_code.py, or I can just launch python3 simple_code.py?
> mpiexec -n 2 python3 simple_code.py
> 2. This simple_code.py consists of 2 parts: a) preparation
> of matrix b) solving the system of linear equations with
> PETSc. If I launch mpirun (or mpiexec) -np 8 python3
> simple_code.py, I suppose that I will basically obtain 8
> matrices and 8 systems to solve. However, I need to
> prepare only one matrix, but launch this code in parallel
> on 8 processors.
> When you create the Mat object, you give it a communicator
> (here PETSC_COMM_WORLD). That allows us to distribute the
> data. This is all covered extensively in the manual and the
> online tutorials, as well as the example code.
> In fact, here attached you will find a similar code
> (scipy_code.py) with only one difference: the system of
> linear equations is solved with scipy. So when I solve it,
> I can clearly see that the solution is obtained in a
> parallel way. However, I do not use the command mpirun (or
> mpiexec). I just go with python3 scipy_code.py.
> Why do you think its running in parallel?
> Thanks,
> Matt
> In this case, the first part (creation of the sparse
> matrix) is not parallel, whereas the solution of system is
> found in a parallel way.
> So my question is, Do you think that it s possible to have
> the same behavior with PETSC? And what do I need for this?
> I am asking this because for my colleague it worked! It
> means that he launches the simple_code.py on his computer
> using the command python3 simple_code.py (and not mpi-smth
> python3 simple_code.py) and he obtains a parallel
> execution of the same code.
> Thanks for your help!
> Ivan
> On Thu, Nov 15, 2018 at 11:54 AM Matthew Knepley
> <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Thu, Nov 15, 2018 at 4:53 AM Ivan Voznyuk via
> petsc-users <petsc-users at mcs.anl.gov
> <mailto:petsc-users at mcs.anl.gov>> wrote:
> Dear PETSC community,
> I have a question regarding the parallel execution
> of petsc4py.
> I have a simple code (here attached
> simple_code.py) which solves a system of linear
> equations Ax=b using petsc4py. To execute it, I
> use the command python3 simple_code.py which
> yields a sequential performance. With a colleague
> of my, we launched this code on his computer, and
> this time the execution was in parallel. Although,
> he used the same command python3 simple_code.py
> (without mpirun, neither mpiexec).
> I am not sure what you mean. To run MPI programs in
> parallel, you need a launcher like mpiexec or mpirun.
> There are Python programs (like nemesis) that use the
> launcher API directly (called PMI), but that is not
> part of petsc4py.
> Thanks,
> Matt
> My configuration: Ubuntu x86_64 Ubuntu 16.04,
> Intel Core i7, PETSc 3.10.2,
> PETSC_ARCH=arch-linux2-c-debug, petsc4py 3.10.0 in
> virtualenv
> In order to parallelize it, I have already tried:
> - use 2 different PCs
> - use Ubuntu 16.04, 18.04
> - use different architectures
> (arch-linux2-c-debug, linux-gnu-c-debug, etc)
> - ofc use different configurations (my present
> config can be found in make.log that I attached here)
> - mpi from mpich, openmpi
> Nothing worked.
> Do you have any ideas?
> Thanks and have a good day,
> Ivan
> Ivan VOZNYUK
> PhD in Computational Electromagnetics
> What most experimenters take for granted before they
> begin their experiments is infinitely more interesting
> than any results to which their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> Ivan VOZNYUK
> +33 (0)6.95.87.04.55
> My webpage <https://ivanvoznyukwork.wixsite.com/webpage>
> My LinkedIn <http://linkedin.com/in/ivan-voznyuk-b869b8106>
> What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any
> -- Norbert Wiener
> Ivan VOZNYUK
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181115/a1e1cc6b/attachment-0001.html>
