[petsc-users] On unknown ordering
Thu Nov 15 04:56:25 CST 2018
On Thu, Nov 15, 2018 at 5:49 AM Appel, Thibaut via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Good morning,
> I would like to ask about the importance of the initial choice of ordering
> the unknowns when feeding a matrix to PETSc.
> I have a regular grid, using high-order finite differences and I simply
> divide rows of the matrix with PetscSplitOwnership using vertex major,
> natural ordering for the parallelism (not using DMDA)
> My understanding is that when using LU-MUMPS, this does not matter because
> either serial or parallel analysis is performed and all the rows are
> reordered ‘optimally’ before the LU factorization. Quality of reordering
> might suffer from parallel analysis.
> But if I use the default block Jacobi with ILU with one block per
> processor, the initial ordering seems to have an influence because some
> tightly coupled degrees of freedom might lay on different processes and the
> ILU becomes less powerful. You can change the ordering on each block but
> this won’t necessarily make things better.
Yes.
> Are my observations accurate? Is there a recommended ordering type for a
> block Jacobi approach in my case? Could I expect natural improvements in
> fill-in or better GMRES robustness opting for parallelism offered by DMDA?
For fill-in, I think yes. The impact of ordering on Krylov methods is
complicated, so I have no idea here.
     Matt
> Thank you,
> Thibaut
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181115/737c42e0/attachment.html>
