[petsc-users] [SLEPc] Krylov-Schur convergence
Tue Nov 13 12:00:25 CST 2018
On Tue, Nov 13, 2018 at 11:14 AM Ale Foggia <amfoggia at gmail.com> wrote:
> Thanks for the answers. I've checked with PETSc function MatIsSymmetric
> (mpiaij does not support MatIsHermitian) for the size that was giving the
> wrong eigenvalue and indeed it is not symmetric, for a tolerance of 1e-14.
> I also wanted to check for smaller sizes, for which the eigenvalue was
> correct, but I get a "Bus error, possibly illegal memory access" when the
> program arrives to that function call. Any idea why it works for one case
> and not for the other? I'm using PETSc 3.9.3 and SLEPc 3.9.2.
Looking at the failure in the debugger would really help us, for example
with a stack trace.
    Matt
> The matrix has to be symmetric at all times, by construction and because
> the physics problem I'm dealing with implies a symmetric matrix. What it's
> strange for me is that I do unit testing for the construction for smaller
> sizes and I obtain real symmetric matrices, as expected. So, maybe when
> growing in size it gets asymmetric for some reason? Are there any more test
> I can do to check this?
> El mar., 13 nov. 2018 a las 14:52, Jose E. Roman (<jroman at dsic.upv.es>)
> escribió:
>> As Matt points out, the probable cause is that your matrix is not exactly
>> Hermitian. In our implementation of Lanczos we assume symmetry, so if
>> ||A-A^*|| is non-negligible then some information is being discarded, which
>> may confuse Lanczos giving some eigenpair as converged when it is not.
>> Why doesn't this happen with the basic Lanczos solver? I don't know,
>> probably due to the restart scheme. In symmetric Krylov-Schur, restart is
>> done with eigenvectors of the projected problem (thick-restart Lanczos),
>> while non-symmetric Krylov-Schur uses Schur vectors. In the basic Lanczos,
>> restart is done building a new initial vector explicitly, which is harmless
>> in this case.
>> Suggestion: either use non-Hermitian Krylov-Schur or symmetrize your
>> matrix as (A+A^*)/2 (or better when contructing it, note that transposing a
>> parallel matrix with 1024 processes requires a lot of communication).
>> Jose
>> > El 13 nov 2018, a las 13:56, Matthew Knepley <knepley at gmail.com>
>> escribió:
>> > On Tue, Nov 13, 2018 at 7:48 AM Ale Foggia via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> > Thanks Jose for the answer. I tried it an it worked! I send the output
>> of -eps_view again, just in case:
>> > EPS Object: 1024 MPI processes
>> >   type: krylovschur
>> >     50% of basis vectors kept after restart
>> >     using the locking variant
>> >   problem type: non-symmetric eigenvalue problem
>> >   selected portion of the spectrum: smallest real parts
>> >   number of eigenvalues (nev): 1
>> >   number of column vectors (ncv): 16
>> >   maximum dimension of projected problem (mpd): 16
>> >   maximum number of iterations: 291700777
>> >   tolerance: 1e-09
>> >   convergence test: relative to the eigenvalue
>> > BV Object: 1024 MPI processes
>> >   type: svec
>> >   17 columns of global length 2333606220
>> >   vector orthogonalization method: classical Gram-Schmidt
>> >   orthogonalization refinement: if needed (eta: 0.7071)
>> >   block orthogonalization method: GS
>> >   doing matmult as a single matrix-matrix product
>> > DS Object: 1024 MPI processes
>> >   type: nhep
>> >   parallel operation mode: REDUNDANT
>> > ST Object: 1024 MPI processes
>> >   type: shift
>> >   shift: 0.
>> >   number of matrices: 1
>> >               k               ||Ax-kx||/||kx||
>> >      -15.048025        1.85112e-10
>> >      -15.047159        3.13104e-10
>> > Iterations performed 18
>> > Why does treating it as non-Hermitian help the convergence? Why doesn't
>> this happen with Lanczos? I'm lost :/
>> > Are you sure your matrix is Hermitian? Lanczos will work for
>> non-Hermitian things (I believe).
>> >   Thanks,
>> >      Matt
>> > Ale
>> > El mar., 13 nov. 2018 a las 12:34, Jose E. Roman (<jroman at dsic.upv.es>)
>> escribió:
>> > This is really strange. We cannot say what is going on, everything
>> seems fine.
>> > Could you try solving the problem as non-Hermitian to see what happens?
>> Just run with -eps_non_hermitian. Depending on the result, we can suggest
>> other things to try.
>> > Jose
>> > > El 13 nov 2018, a las 10:58, Ale Foggia via petsc-users <
>> petsc-users at mcs.anl.gov> escribió:
>> > > Hello,
>> > > I'm using SLEPc to get the smallest real eigenvalue
>> (EPS_SMALLEST_REAL) of a Hermitian problem (EPS_HEP). The linear size of
>> the matrices I'm solving is around 10**9 elements and they are sparse. I've
>> asked a few questions before regarding the same problem setting and you
>> suggested me to use Krylov-Schur (because I was using Lanczos). I tried KS
>> and up to a certain matrix size the convergence (relative to the
>> eigenvalue) is good, it's around 10**-9, like with Lanczos, but when I
>> increase the size I start getting the eigenvalue with only 3 correct
>> digits. I've used the options: -eps_tol 1e-9 -eps_mpd 100 (16 was the
>> default), but the only thing I got is one more eigenvalue with the same big
>> error, and the iterations performed were only 2. Why didn't it do more in
>> order to reach the convergence? Should I set other parameters? I don't know
>> how to work out this problem, can you help me with this please? I send the
>> -eps_view output and the eigenvalues with its errors:
>> > > EPS Object: 2048 MPI processes
>> > >   type: krylovschur
>> > >   problem type: symmetric eigenvalue problem
>> > >   number of column vectors (ncv): 101
>> > >   maximum dimension of projected problem (mpd): 100
>> > >   maximum number of iterations: 46210024
>> > >   tolerance: 1e-09
>> > > BV Object: 2048 MPI processes
>> > >   type: svec
>> > >   102 columns of global length 2333606220
>> > > DS Object: 2048 MPI processes
>> > >   type: hep
>> > >   solving the problem with: Implicit QR method (_steqr)
>> > > ST Object: 2048 MPI processes
>> > >   type: shift
>> > >   shift: 0.
>> > >               k                ||Ax-kx||/||kx||
>> > >      -15.093051         0.00323917 (with KS)
>> > >      -15.087320         0.00265215 (with KS)
>> > >      -15.048025         8.67204e-09 (with Lanczos)
>> > > Iterations performed 2
>> > > Ale
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
>> > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181113/86f0fd7d/attachment.html>
