[petsc-users] [SLEPc] Krylov-Schur convergence
Ale Foggia
amfoggia at gmail.com
Tue Nov 13 06:47:13 CST 2018
Thanks Jose for the answer. I tried it an it worked! I send the output of
-eps_view again, just in case:
EPS Object: 1024 MPI processes
type: krylovschur
50% of basis vectors kept after restart
using the locking variant
problem type: non-symmetric eigenvalue problem
selected portion of the spectrum: smallest real parts
number of eigenvalues (nev): 1
number of column vectors (ncv): 16
maximum dimension of projected problem (mpd): 16
maximum number of iterations: 291700777
tolerance: 1e-09
convergence test: relative to the eigenvalue
BV Object: 1024 MPI processes
type: svec
17 columns of global length 2333606220
vector orthogonalization method: classical Gram-Schmidt
orthogonalization refinement: if needed (eta: 0.7071)
block orthogonalization method: GS
doing matmult as a single matrix-matrix product
DS Object: 1024 MPI processes
type: nhep
parallel operation mode: REDUNDANT
ST Object: 1024 MPI processes
type: shift
shift: 0.
number of matrices: 1
k ||Ax-kx||/||kx||
-15.048025 1.85112e-10
-15.047159 3.13104e-10
Iterations performed 18
Why does treating it as non-Hermitian help the convergence? Why doesn't
this happen with Lanczos? I'm lost :/
Ale
El mar., 13 nov. 2018 a las 12:34, Jose E. Roman (<jroman at dsic.upv.es>)
escribió:
> This is really strange. We cannot say what is going on, everything seems
> fine.
> Could you try solving the problem as non-Hermitian to see what happens?
> Just run with -eps_non_hermitian. Depending on the result, we can suggest
> other things to try.
> Jose
> > El 13 nov 2018, a las 10:58, Ale Foggia via petsc-users <
> petsc-users at mcs.anl.gov> escribió:
> > Hello,
> > I'm using SLEPc to get the smallest real eigenvalue (EPS_SMALLEST_REAL)
> of a Hermitian problem (EPS_HEP). The linear size of the matrices I'm
> solving is around 10**9 elements and they are sparse. I've asked a few
> questions before regarding the same problem setting and you suggested me to
> use Krylov-Schur (because I was using Lanczos). I tried KS and up to a
> certain matrix size the convergence (relative to the eigenvalue) is good,
> it's around 10**-9, like with Lanczos, but when I increase the size I start
> getting the eigenvalue with only 3 correct digits. I've used the options:
> -eps_tol 1e-9 -eps_mpd 100 (16 was the default), but the only thing I got
> is one more eigenvalue with the same big error, and the iterations
> performed were only 2. Why didn't it do more in order to reach the
> convergence? Should I set other parameters? I don't know how to work out
> this problem, can you help me with this please? I send the -eps_view output
> and the eigenvalues with its errors:
> > EPS Object: 2048 MPI processes
> > type: krylovschur
> > problem type: symmetric eigenvalue problem
> > number of column vectors (ncv): 101
> > maximum dimension of projected problem (mpd): 100
> > maximum number of iterations: 46210024
> > tolerance: 1e-09
> > BV Object: 2048 MPI processes
> > type: svec
> > 102 columns of global length 2333606220
> > DS Object: 2048 MPI processes
> > type: hep
> > solving the problem with: Implicit QR method (_steqr)
> > ST Object: 2048 MPI processes
> > type: shift
> > shift: 0.
> > k ||Ax-kx||/||kx||
> > -15.093051 0.00323917 (with KS)
> > -15.087320 0.00265215 (with KS)
> > -15.048025 8.67204e-09 (with Lanczos)
> > Iterations performed 2
> > Ale
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181113/9b0e2c49/attachment.html>
