[petsc-users] [petsc-maint] Correct use of PCFactorSetMatOrderingType
Mark Adams
mfadams at lbl.gov
Thu Nov 8 11:10:37 CST 2018
I am not that familiar with hypre's options. AMG is complicated and I
barely keep my options straight.
OpenFOAM seems to have highly specialized solvers so being with 50% of them
is decent.
On Thu, Nov 8, 2018 at 12:03 PM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Yes, it is like you are saying. This is mostly due to the time employed by
> ksp to solve the pressure equation. However, I have worked a lot on the
> problem and I have found out that the default configuration is far to be
> the optimal one, at least in this case.
> Actually my cpu time is decreased by more than twice with respect to the
> default configuration. I put here the changes, maybe they can be usefull to
> other users in the future:
> -pc_hypre_boomeramg_no_CF
> -pc_hypre_boomeramg_agg_nl 1
> pc_hypre_boomeramg_coarsen_type HMIS
> -pc_hypre_boomeramg_interp_type FF1
> The last two seem to be essential in enhancing performances.
> Do you know other configurations that worth to test? Also, I would like
> to know if a list of command options for hypre is available somewhere.
> Looking at hypre's doc there are a lot of options, but I do not exactly
> know which one is available in petsc and their name.
> Thank you very much for the kind support and sorry for the long emal.!
> Il giorno gio 8 nov 2018, 17:32 Mark Adams <mfadams at lbl.gov> ha scritto:
>> To repeat:
>> You seem to be saying that OpenFOAM solves the problem in 10 seconds and
>> PETSc solves it in 14 seconds. Is that correct?
>> On Thu, Nov 8, 2018 at 3:42 AM Edoardo alinovi via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hello Mark,
>>> Yes, there are 5 KSP calls within a time-step (3 for the solution of
>>> momentum equation + 2 for the solution of pressure), this is the classical
>>> non iterative PISO by Issa ( the exact sequence of operations is : solve
>>> momentum implicitly, solve pressure-correction, momentum explicitly,
>>> pressure correction). The pressure correction equation ,which is something
>>> similar to a Poisson equation for incompressible flows, is the one that
>>> determines the overall performance in my code such as in the others.
>>> Usually, when the pressure is being solved for the second time, the
>>> solution is faster since there is a better input guess and, as in my case,
>>> the preconditioner is not recomputed again.
>>> Have you got some advices for the multigrid configuration in this
>>> scenario, which are not the default one, in order to increase performances?
>>> I do not know if this may impact drastically the performance, but I am
>>> running on a E4 workstation with 16 Intel's Xeon processors (2.3GH/12MB
>>> cache) and 128GB of RAM .
>>> Thank you very much for your helpful comments,
>>> Edoardo
>>> Edoardo Alinovi, Ph.D.
>>> DICCA, Scuola Politecnica
>>> Universita' di Genova
>>> 1, via Montallegro
>>> 16145 Genova, Italy
>>> email: edoardo.alinovi at dicca.unige.it
>>> Tel: +39 010 353 2540
>>> Il giorno mer 7 nov 2018 alle ore 17:59 Mark Adams <mfadams at lbl.gov> ha
>>> scritto:
>>>> please respond to petsc-users.
>>>> You are doing 5 solves here in 14 seconds. You seem to be saying that
>>>> the two pressure solves are taking all of this time. I don't know why the
>>>> two solves are different.
>>>> and PETSc solves it in 14 seconds. Is that correct? Hypre seems to be
>>>> running fine.
>>>> On Wed, Nov 7, 2018 at 11:24 AM Edoardo alinovi <
>>>> edoardo.alinovi at gmail.com> wrote:
>>>>> Thanks a lot Mark for your kind replay. The solver is mine and I use
>>>>> PETSc for the solution of momentum and pressure. The first is solved very
>>>>> fast by a standard bcgs + bjacobi, but the pressure is the source of all
>>>>> evils and, unfortunately, I am pretty sure that almost all the time within
>>>>> the time-step is needed by KSP to solve the pressure (see log attached). I
>>>>> have verified this also putting a couple of mpi_wtime around the kspsolve
>>>>> call. The pressure is solved 2 times (1 prediction + 1 correction), the
>>>>> prediction takes around 11s , the correction around 4s (here I am avoiding
>>>>> to recompute the preconditioner), all the rest of the code (flux assembling
>>>>> + mometum solution + others) around 1s. Openfoam does the same procedure
>>>>> with the same tolerance in 10s using its gamg version (50 it to converge).
>>>>> The number of iteration required to solve the pressure with hypre are 12.
>>>>> Gamg performs similarly to hypre in terms of speed, but with 50 iterations
>>>>> to converge. Am I missing something in the setup in your opinion?
>>>>> thanks a lot,
>>>>> Edo
>>>>> 1, via Montallegro
>>>>> 16145 Genova, Italy
>>>>> Il giorno mer 7 nov 2018 alle ore 16:50 Mark Adams <mfadams at lbl.gov>
>>>>> ha scritto:
>>>>>> You can try -pc_type gamg, but hypre is a pretty good solver for the
>>>>>> Laplacian. If hypre is just a little faster than LU on a 3D problem (that
>>>>>> takes 10 seconds to solve) then AMG is not doing well. I would expect that
>>>>>> AMG is taking a lot of iterations (eg, >> 10). You can check that with
>>>>>> -ksp_monitor.
>>>>>> The PISO algorithm is a multistage algorithm with a pressure
>>>>>> correction in it. It also has a solve for the velocity, from what I can
>>>>>> tell. Are you building PISO yourself and using PETSc just for the pressure
>>>>>> correction? Are you sure the time is spent in this solver? You can use
>>>>>> -log_view to see performance numbers and look for KSPSolve to see how much
>>>>>> time is spent in the PETSc solver.
>>>>>> Mark
>>>>>> On Wed, Nov 7, 2018 at 10:26 AM Zhang, Hong via petsc-maint <
>>>>>> petsc-maint at mcs.anl.gov> wrote:
>>>>>>> Edoardo:
>>>>>>> Forwarding your request to petsc-maint where you can get fast and
>>>>>>> expert advise. I do not have suggestion for your application, but someone
>>>>>>> in our team likely will make suggestion.
>>>>>>> Hong
>>>>>>> Hello Hong,
>>>>>>>> Well, using -sub_pc_type lu it super slow. I am
>>>>>>>> desperately triying to enhance performaces of my code (CFD, finite volume,
>>>>>>>> PISO alghoritm), in particular I have a strong bottleneck in the solution
>>>>>>>> of pressure correction equation which takes almost the 90% of computational
>>>>>>>> time. Using multigrid as preconditoner (hypre with default options) is
>>>>>>>> slighlty better, but comparing the results against the multigrid used in
>>>>>>>> openFOAM, my code is losing 10s/iteration which a huge amount of time. Now,
>>>>>>>> since that all the time is employed by KSPSolve, I feel a bit powerless.
>>>>>>>> Do you have any helpful advice?
>>>>>>>> Thank you very much!
>>>>>>>> 1, via Montallegro
>>>>>>>> 16145 Genova, Italy
>>>>>>>> Il giorno mar 6 nov 2018 alle ore 17:15 Zhang, Hong <
>>>>>>>> hzhang at mcs.anl.gov> ha scritto:
>>>>>>>>> Edoardo:
>>>>>>>>> Interesting. I thought it would not affect performance much. What
>>>>>>>>> happens if you use -sub_pc_type lu'?
>>>>>>>>> Hong
>>>>>>>>> Dear Hong and Matt,
>>>>>>>>>> thank you for your kind replay. I have just tested your
>>>>>>>>>> suggestions and applied " -sub_pc_type ilu -sub_pc_factor_mat_ordering_type
>>>>>>>>>> nd/rcm" and, in both cases, I have found a deterioration of
>>>>>>>>>> performances with respect to doing nothing (thus just putting default
>>>>>>>>>> PCBJACOBI). Is it normal? However, I guess this is very problem dependent.
>>>>>>>>>> 1, via Montallegro
>>>>>>>>>> 16145 Genova, Italy
>>>>>>>>>> Il giorno mar 6 nov 2018 alle ore 16:04 Zhang, Hong <
>>>>>>>>>>> Edoardo:
>>>>>>>>>>> You can test runtime option '-sub_pc_factor_mat_ordering_type'
>>>>>>>>>>> and use '-log_view' to get performance on different orderings,
>>>>>>>>>>> e.g.,petsc/src/ksp/ksp/examples/tutorials/ex2.c:
>>>>>>>>>>> mpiexec -n 2 ./ex2 -ksp_view -sub_pc_type ilu
>>>>>>>>>>> -sub_pc_factor_mat_ordering_type nd
>>>>>>>>>>> I do not think the ordering inside block for ilu would affect
>>>>>>>>>>> performance much. Let us know what you will get.
>>>>>>>>>>> Hong
>>>>>>>>>>> Dear users,
>>>>>>>>>>>> I have a question about the correct use of the option
>>>>>>>>>>>> "PCFactorSetMatOrderingType" in PETSc.
>>>>>>>>>>>> I am solving a problem with 2.5M of unknowns distributed along
>>>>>>>>>>>> 16 processors and I am using the block jacobi preconditioner and MPIAIJ
>>>>>>>>>>>> matrix format. I cannot figure out if the above option can be useful or not
>>>>>>>>>>>> in decreasing the computational time. Any suggestion or tips?
>>>>>>>>>>>> Thank you very much for the kind help
>>>>>>>>>>>> 1, via Montallegro
>>>>>>>>>>>> 16145 Genova, Italy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181108/6a7faaad/attachment.html>
