[petsc-users] PETSc (3.9.0) GAMG weak scaling test issue
"Alberto F. Martín" amartin at cimne.upc.edu
Thu Nov 8 06:08:09 CST 2018
On 08/11/18 13:01, Matthew Knepley wrote:
> On Thu, Nov 8, 2018 at 6:41 AM "Alberto F. Martín" via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>     Dear Mark,
>     thanks for your quick and comprehensive reply.
>     Before moving to the results of the experiments that u suggested,
>     let me clarify two points
>     on my original e-mail and your answer:
>     (1) The raw timings and #iters. provided in my first e-mail were
>     actually
>           obtained with "-pc_gamg_square_graph 1" (and not 0); sorry
>     about that, my mistake.
>           (the logs, though, were consistent with the solver
>     configuration provided).
>           The raw figures with "-pc_gamg_square_graph 0" are actually
>     as follows:
>           (load3): [0.25074561, 0.3650926566, 0.6251466936,
>     0.8709517661, 15.52180776]
>           (load3): [0.148803731, 0.325266364, 0.5538515123,
>     0.7537377281, 1.475100923]
>           (load3): [8, 9, 11, 12, 12]
>           Bottom line: significant improvement of absolute times for
>     the first 4x problems, marginal improvement for
>                                the largest problem (compared to
>     "-pc_gamg_square_graph 1")
>     (2) <</The PC setup times are large (I see 48 seconds at 16K but
>     you report 16). //
>     //          -pc_gamg_square_graph 10 should help that./>>
>          This disagreement is justified by the following note on my
>     original e-mail:
>                  <</Please note that within each run, I execute these
>     two stages up-to//
>     //             three times, and this influences absolute timings
>     given in  -log_view./>>
>     I tried new configurations based on your suggestions. Find
>     attached the results.
>     (legends indicate changes with respect to the solver configuration
>     provided
>     in my first e-mail).
>     Bottom lines: (1) the configuration provided in my original e-mail
>     leads to fastest execution
>     and less number of iteration for the first 4x problems. (2) *The
>     (new) parameter-value combinations**
>     **suggested seem to have almost no impact into the preconditioner
>     set up time of the last problem.*
> Mark, could this bad setup just be non-scalability in ParMetis? How do
> we see the ParMetis time?
>   Thanks,
>     Matt
Dear Matt,
I did not configured PETSc with ParMetis support. Should I?
I figured it out when I tried to use "-pc_gamg_repartition". PETSc
complained that it was not compiled with ParMetis support.
Thanks!
Best regards,
  Alberto.
>     *I also tried HYPRE-BoomerAMG as suggested, with two different
>     configurations.
>     *** SYMMETRIC CONFIGURATION ***
>     -ksp_type cg
>     -ksp_monitor
>     -ksp_rtol 1.0e-6
>     -ksp_converged_reason
>     -ksp_max_it 500
>     -ksp_norm_type unpreconditioned
>     -ksp_view
>     -log_view
>     -pc_type hypre
>     -pc_hypre_type boomeramg
>     -pc_hypre_boomeramg_print_statistics 1
>     -pc_hypre_boomeramg_strong_threshold 0.25
>     -pc_hypre_boomeramg_coarsen_type HMIS
>     -pc_hypre_boomeramg_relax_type_down symmetric-SOR/Jacobi
>     -pc_hypre_boomeramg_relax_type_up symmetric-SOR/Jacobi
>     -pc_hypre_boomeramg_relax_type_coarse Gaussian-elimination
>     *** UNSYMMETRIC CONFIGURATION ***
>     -ksp_type gmres
>     -ksp_gmres_restart 500
>     -ksp_monitor
>     -ksp_rtol 1.0e-6
>     -ksp_max_it 500
>     -ksp_pc_side right
>     -pc_type hypre
>     -pc_hypre_boomeramg_relax_type_down SOR/Jacobi
>     -pc_hypre_boomeramg_relax_type_up SOR/Jacobi
>     The raw results were:
>     (load3):  [0.1828534687, 0.3055133289, 0.3582984209, 0.4280304033,
>     1.343549139]
>     (load3):  [0.2102472978, 0.4572948301, 0.7153297188, 0.9989531627,
>     N/A]
>     (load3):  [19, 23, 26, 28, 'DIVERGED_INDEFINITE_PC']
>     (load3): [0.1841227429, 0.3082743008, 0.3652294828, 0.4654760892,
>     1.331299786]
>     (load3): [0.1194557019, 0.2830136018, 0.5046830242, 1.363314636, N/A]
>     (load3): [15, 19, 24, 48, DIVERGED_ITS]
>     Thus, the largest problem also seems to cause (even more severe)
>     issues to HYPRE, in particular,
>     INDEFINITE PRECONDITIONER with CG, and not convergence within 500
>     iterations for GMRES.
>     The preconditioner set up stage time, though, scales reasonably
>     well with the same data distribution
>     that we used to feed GAMG (although the preconditioner computed
>     for the largest problem seems to be
>     totally useless).
>     I have logs for all these results if required.
>     Thanks for your help!
>     Best regards,
>      Alberto.
>     On 07/11/18 19:46, Mark Adams wrote:
>>     First I would add -gamg_est_ksp_type cg
>>     You seem to be converging well so I assume you are setting the
>>     null space for GAMG.
>>     Note, you should test hypre also.
>>     You probably want a bigger "-pc_gamg_process_eq_limit 50". 200 at
>>     least but you test your machine with a range on the largest
>>     problem. This is a parameter for reducing the number of active
>>     processors (on coarse grids).
>>     I would only worry about "load3". This has 16K equations per
>>     process, which is where you start noticing "strong scaling"
>>     problems, depending on the machine.
>>     An important parameter is "-pc_gamg_square_graph 0". I would
>>     probably start with infinity (eg, 10).
>>     Now, I'm not sure about your domain, problem sizes, and thus the
>>     weak scaling design. You seem to be scaling on the background
>>     mesh, but that may not be a good proxy for complexity.
>>     You can look at the number of flops and scale it appropriately by
>>     the number of solver iterations to get a relative size of the
>>     problem. I would recommend scaling the number of processors with
>>     this. For instance here the MatMult line for the 4 proc and 16K
>>     proc run:
>>     Event           Count      Time (sec)     Flop
>>          --- Global ---  --- Stage ---   Total
>>            Max Ratio  Max     Ratio   Max  Ratio Mess   Avg len
>>     Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>     MatMult           636 1.0 1.9035e-01 1.0 3.12e+08 1.1 7.6e+03
>>     3.0e+03 0.0e+00  0 47 62 44  0   0 47 62 44  0  6275 [2 procs]
>>     MatMult          1416 1.0 1.9601e+002744.6 4.82e+08 0.0 4.3e+08
>>     7.2e+02 0.0e+00  0 48 50 48  0   0 48 50 48  0 2757975 [16K procs]
>>     Now, you have empty processors. See the massive load imbalance on
>>     time and the zero on Flops. The "Ratio" is max/min and cleary
>>     min=0 so PETSc reports a ratio of 0 (it is infinity really).
>>     Also, weak scaling on a thin body (I don't know your domain) is a
>>     little funny because as the problem scales up the mesh becomes
>>     more 3D and this causes the cost per equation to go up. That is
>>     why I prefer to use the number of non-zeros as the processor
>>     scaling function but number of equations is easier ...
>>     The PC setup times are large (I see 48 seconds at 16K bu you
>>     report 16). -pc_gamg_square_graph 10 should help that.
>>     The max number of flops per processor in MatMult goes up by 50%
>>     and the max time goes up by 10x and the number of iterations goes
>>     up by 13/8. If I put all of this together I get that 75% of the
>>     time at 16K is in communication at 16K. I think that and the
>>     absolute time can be improved some by optimizing parameters as
>>     I've suggested.
>>     Mark
>>     On Wed, Nov 7, 2018 at 11:03 AM "Alberto F. Martín" via
>>     petsc-users <petsc-users at mcs.anl.gov
>>         Dear All,
>>         we are performing a weak scaling test of the PETSc (v3.9.0)
>>         GAMG preconditioner when applied to the linear system arising
>>         from the *conforming unfitted FE discretization *(using Q1
>>         Lagrangian FEs) of a 3D PDE Poisson problem, where
>>         the boundary of the domain (a popcorn flake)  is described as
>>         a zero-level-set embedded within a uniform background
>>         (Cartesian-like) hexahedral mesh. Details underlying the FEM
>>         formulation can be made available on demand if you
>>         believe that this might be helpful, but let me just point out
>>         that it is designed such that it addresses the well-known
>>         ill-conditioning issues of unfitted FE discretizations due to
>>         the small cut cell problem.
>>         The weak scaling test is set up as follows. We start from a
>>         single cube background mesh, and refine it uniformly several
>>         steps, until we have approximately either 10**3 (load1),
>>         20**3 (load2), or 40**3 (load3) hexahedra/MPI task when
>>         distributing it over 4 MPI tasks. The benchmark is scaled
>>         such that the next larger scale problem to be tested is obtained
>>         by uniformly refining the mesh from the previous scale and
>>         running it on 8x times the number of MPI tasks that we used
>>         in the previous scale.  As a result, we obtain three weak
>>         scaling curves for each of the three fixed loads per MPI task
>>         above, on the following total number of MPI tasks: 4, 32,
>>         262, 2097, 16777. The underlying mesh is not partitioned among
>>         MPI tasks using ParMETIS (unstructured multilevel graph
>>         partitioning)  nor optimally by hand, but following the
>>         so-called
>>         z-shape space-filling curves provided by an underlying
>>         octree-like mesh handler (i.e., p4est library).
>>         I configured the preconditioned linear solver as follows:
>>         -ksp_type cg
>>         -ksp_monitor
>>         -ksp_rtol 1.0e-6
>>         -ksp_max_it 500
>>         -ksp_view
>>         -log_view
>>         -pc_type gamg
>>         -pc_gamg_type agg
>>         -mg_levels_esteig_ksp_type cg
>>         -mg_coarse_sub_pc_type cholesky
>>         -mg_coarse_sub_pc_factor_mat_ordering_type nd
>>         -pc_gamg_agg_nsmooths 1
>>         Raw timings (in seconds) of the preconditioner set up and PCG
>>         iterative solution stage, and number of iterations are as
>>         follows:
>>         **preconditioner set up**
>>         (load1): [0.02542160451, 0.05169247743, 0.09266782179,
>>         0.2426272957, 13.64161944]
>>         (load2): [0.1239175797  , 0.1885528499  , 0.2719282564  ,
>>         0.4783878336, 13.37947339]
>>         (load3): [0.6565349903  , 0.9435049873  , 1.299908397    ,
>>         1.916243652  , 16.02904088]
>>         **PCG stage**
>>         (load1): [0.003287350759, 0.008163803257, 0.03565631993,
>>         0.08343045413, 0.6937994603]
>>         (load2): [0.0205939794    , 0.03594723623  , 0.07593298424,
>>         0.1212046621  , 0.6780373845]
>>         (load3): [0.1310882876    , 0.3214917686    , 0.5532023879  ,
>>         0.766881627    , 1.485446003]
>>         **number of PCG iterations**
>>         (load1): [5, 8, 11, 13, 13]
>>         (load2): [7, 10, 12, 13, 13]
>>         (load3): [8, 10, 12, 13, 13]
>>         It can be observed that both the number of linear solver
>>         iterations and the PCG stage timings (weakly)
>>         scale remarkably, but t*here is a significant time increase
>>         when scaling the problem from 2097 to 16777 MPI tasks **
>>         **for the preconditioner setup stage* (e.g., 1.916243652 vs
>>         16.02904088 sec. with 40**3 cells per MPI task).
>>         I gathered the combined output of -ksp_view and -log_view
>>         (only) for all the points involving the load3 weak scaling
>>         test (find them attached to this message). Please note that
>>         within each run, I execute the these two stages up-to
>>         three times, and this influences absolute timings given in
>>         -log_view.
>>         Looking at the output of -log_view, it is very strange to me,
>>         e.g., that the stage labelled as "Graph"
>>         does not scale properly as it is just a call to MatDuplicate
>>         if the block size of the matrix is 1 (our case), and
>>         I guess that it is just a local operation that does not
>>         require any communication.
>>         What I am missing here? The load does not seem to be
>>         unbalanced looking at the "Ratio" column.
>>         I wonder whether the observed behaviour is as expected, or
>>         this a miss-configuration of the solver from our side.
>>         I played (quite a lot) with several parameter-value
>>         combinations, and the configuration above is the one that led
>>         to fastest
>>         execution  (from the ones tested, that might be incomplete, I
>>         can also provide further feedback if helpful).
>>         Any feedback that we can get from your experience in order to
>>         find the cause(s) of this issue and a mitigating solution
>>         will be of high added value.
>>         Thanks very much in advance!
>>         Best regards,
>>          Alberto.
>>         Alberto F. Martín-Huertas
>>         Senior Researcher, PhD. Computational Science
>>         Centre Internacional de Mètodes Numèrics a l'Enginyeria (CIMNE)
>>         Parc Mediterrani de la Tecnologia, UPC
>>         Esteve Terradas 5, Building C3, Office 215,
>>         08860 Castelldefels (Barcelona, Spain)
>>         Tel.: (+34) 9341 34223
>>         e-mail:amartin at cimne.upc.edu  <mailto:e-mail:amartin at cimne.upc.edu>
>>         FEMPAR project co-founder
>>         web:http://www.fempar.org
>>         ________________
>>         IMPORTANT NOTICE
>>         All personal data contained on this mail will be processed confidentially and registered in a file property of CIMNE in
>>         order to manage corporate communications. You may exercise the rights of access, rectification, erasure and object by
>>         letter sent to Ed. C1 Campus Norte UPC. Gran Capitán s/n Barcelona.
>     ________________
>     IMPORTANT NOTICE
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
web: http://www.fempar.org
________________
IMPORTANT NOTICE
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181108/0793a207/attachment-0001.html>
