[petsc-users] Correct use of PCFactorSetMatOrderingType
Tue Nov 6 09:03:48 CST 2018
On Tue, Nov 6, 2018 at 9:47 AM Edoardo alinovi via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear users,
> I have a question about the correct use of the option
> "PCFactorSetMatOrderingType" in PETSc.
> I am solving a problem with 2.5M of unknowns distributed along 16
> processors and  I am using the block jacobi preconditioner and MPIAIJ
> matrix format. I cannot figure out if the above option can be useful or not
> in decreasing the computational time. Any suggestion or tips?
It depends on where the matrix comes from. If the initial ordering is bad,
it can make a big difference. If not, then it won't.
     Matt
> Thank you very much for the kind help
> Edoardo Alinovi, Ph.D.
> DICCA, Scuola Politecnica
> Universita' di Genova
> 1, via Montallegro
> 16145 Genova, Italy
> email: edoardo.alinovi at dicca.unige.it
> Tel: +39 010 353 2540
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181106/78a4f13b/attachment.html>
