[petsc-users] Segmentation violation in DMPlexDistribute on MacOS
Tue Nov 6 08:21:33 CST 2018
On Tue, Nov 6, 2018 at 5:24 AM Stefano Zampini via petsc-users <
petsc-users at mcs.anl.gov> wrote:
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> Have you tried what PETSc suggests here (-on_error_attach_debugger)?
> You may need to specify "-on_error_attach_debugger lldb" on a MacOS
1) So that error occurs with the smallest BoxMesh? That would be 6 tets.
2) I would really need a stack to tell you anything. You can get this by
running in the debugger.
This is something we run every night (exactly this), so I suspect its some
inconsistency in that build.
    Matt
> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181106/65c224e9/attachment-0001.html>
