[petsc-users] DIVERGED_NANORING with PC GAMG
Mark Adams mfadams at lbl.gov
Mon Nov 5 15:50:12 CST 2018
On Mon, Nov 5, 2018 at 4:11 PM Appel, Thibaut <t.appel17 at imperial.ac.uk>
wrote:
> "Local" as in serial?
Block Jacobi with ILU as the solver on each block. Each block corresponds
to an MPI process by default. So it is completely parallel it is just not a
true ILU. I the limit of one equation per processor it is just (point)
Jacobi.
> Thibaut
> On 5 Nov 2018, at 20:12, Mark Adams <mfadams at lbl.gov> wrote:
> On Mon, Nov 5, 2018 at 12:50 PM Thibaut Appel <t.appel17 at imperial.ac.uk>
> wrote:
>> Hi Mark,
>> Yes it doesn't seem to be usable. Unfortunately we're aiming to do 3D so
>> direct solvers are not a viable solution and PETSc' ILU is not parallel and
>> we can't use HYPRE (complex arithmetic)
> I think SuperLU has a parallel ILU but in my opinion parallel ILU is not a
> big deal. Neither is optimal and the math win (faster convergence) with
> parallel is offset by the cost of synchronization, in some form, for a true
> parallel ILU. So I think the PETSc default gmres/(local)ILU is your
> best option.
>> Thibaut
>> On 01/11/2018 20:42, Mark Adams wrote:
>> On Wed, Oct 31, 2018 at 8:11 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>>> > On Oct 31, 2018, at 5:39 PM, Appel, Thibaut via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> > Well yes naturally for the residual but adding -ksp_true_residual just
>>> gives
>>> >   0 KSP unpreconditioned resid norm 3.583290589961e+00 true resid norm
>>> 3.583290589961e+00 ||r(i)||/||b|| 1.000000000000e+00
>>> >   1 KSP unpreconditioned resid norm 0.000000000000e+00 true resid norm
>>> > Linear solve converged due to CONVERGED_ATOL iterations 1
>>>    Very bad stuff is happening in the preconditioner. The preconditioner
>>> must have a null space (which it shouldn't have to be a useful
>>> preconditioner).
>> Yea, you are far away from an optimal preconditioner for this system. In
>> low frequency (indefinite) Helmholtz is very very hard. Now, something very
>> bad is going on here but even if you fix it standard AMG is not good for
>> these problems. I would use direct solvers or grind away it with ILU.
>>> > Mark - if that helps - a Poisson equation is used for the pressure so
>>> the Helmholtz is the same as for the velocity in the interior.
>>> > Thibaut
>>> >> Le 31 oct. 2018 à 21:05, Mark Adams <mfadams at lbl.gov> a écrit :
>>> >> These are indefinite (bad) Helmholtz problems. Right?
>>> >> On Wed, Oct 31, 2018 at 2:38 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> >> On Wed, Oct 31, 2018 at 2:13 PM Thibaut Appel <
>>> t.appel17 at imperial.ac.uk> wrote:
>>> >> Hi Mark, Matthew,
>>> >> Thanks for taking the time.
>>> >> 1) You're not suggesting having -fieldsplit_X_ksp_type fgmres for
>>> each field, are you?
>>> >> 2) No, the matrix has pressure in one of the fields. Here it's a 2D
>>> problem (but we're also doing 3D), the unknowns are (p,u,v) and those are
>>> my 3 fields. We are dealing with subsonic/transsonic flows so it is
>>> convection dominated indeed.
>>> >> 3) We are in frequency domain with respect to time, i.e.
>>> \partial{phi}/\partial{t} = -i*omega*phi.
>>> >> 4) Hypre is unfortunately not an option since we are in complex
>>> arithmetic.
>>> >>> I'm not sure about "-fieldsplit_pc_type gamg" GAMG should work on
>>> one block, and hence be a subpc. I'm not up on fieldsplit syntax.
>>> >> According to the online manual page this syntax applies the suffix to
>>> all the defined fields?
>>> >>> Mark is correct. I wanted you to change the smoother. He shows how
>>> to change it to Richardson (make sure you add the self-scale option), which
>>> is probably the best choice.
>>> >>>   Thanks,
>>> >>>      Matt
>>> >> You did tell me to set it to GMRES if I'm not mistaken, that's why I
>>> tried "-fieldsplit_mg_levels_ksp_type gmres" (mentioned in the email).
>>> Also, it wasn't clear whether these should be applied to each block or the
>>> whole system, as the online manual pages + .pdf manual barely mention
>>> smoothers and how to manipulate MG objects with KSP/PC, this especially
>>> with PCFIELDSPLIT where examples are scarce.
>>> >> From what I can gather from your suggestions I tried (lines with X
>>> are repeated for X={0,1,2})
>>> >> This looks good. How can an identically zero vector produce a 0
>>> residual? You should always monitor with
>>> >>   -ksp_monitor_true_residual.
>>> >>    Thanks,
>>> >>     Matt
>>> >> -ksp_view_pre -ksp_monitor -ksp_converged_reason \
>>> >> -ksp_type fgmres -ksp_rtol 1.0e-8 \
>>> >> -pc_type fieldsplit \
>>> >> -pc_fieldsplit_type multiplicative \
>>> >> -pc_fieldsplit_block_size 3 \
>>> >> -pc_fieldsplit_0_fields 0 \
>>> >> -pc_fieldsplit_1_fields 1 \
>>> >> -pc_fieldsplit_2_fields 2 \
>>> >> -fieldsplit_X_pc_type gamg \
>>> >> -fieldsplit_X_ksp_type gmres \
>>> >> -fieldsplit_X_ksp_rtol 1e-10 \
>>> >> -fieldsplit_X_mg_levels_ksp_type richardson \
>>> >> -fieldsplit_X_mg_levels_pc_type sor \
>>> >> -fieldsplit_X_pc_gamg_agg_nsmooths 0 \
>>> >> -fieldsplit_X_mg_levels_ksp_richardson_self_scale \
>>> >> -log_view
>>> >> which yields
>>> >> KSP Object: 1 MPI processes
>>> >>   type: fgmres
>>> >>     restart=30, using Classical (unmodified) Gram-Schmidt
>>> Orthogonalization with no iterative refinement
>>> >>     happy breakdown tolerance 1e-30
>>> >>   maximum iterations=10000, initial guess is zero
>>> >>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>>> >>   left preconditioning
>>> >>   using DEFAULT norm type for convergence test
>>> >> PC Object: 1 MPI processes
>>> >>   type: fieldsplit
>>> >>   PC has not been set up so information may be incomplete
>>> >>     FieldSplit with MULTIPLICATIVE composition: total splits = 3,
>>> blocksize = 3
>>> >>     Solver info for each split is in the following KSP objects:
>>> >>   Split number 0 Fields  0
>>> >>   KSP Object: (fieldsplit_0_) 1 MPI processes
>>> >>     type: preonly
>>> >>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>> >>   PC Object: (fieldsplit_0_) 1 MPI processes
>>> >>     type not yet set
>>> >>   Split number 1 Fields  1
>>> >>   KSP Object: (fieldsplit_1_) 1 MPI processes
>>> >>     type: preonly
>>> >>   PC Object: (fieldsplit_1_) 1 MPI processes
>>> >>     type not yet set
>>> >>   Split number 2 Fields  2
>>> >>   KSP Object: (fieldsplit_2_) 1 MPI processes
>>> >>     type: preonly
>>> >>   PC Object: (fieldsplit_2_) 1 MPI processes
>>> >>     type not yet set
>>> >>   linear system matrix = precond matrix:
>>> >>   Mat Object: 1 MPI processes
>>> >>     type: seqaij
>>> >>     rows=52500, cols=52500
>>> >>     total: nonzeros=1127079, allocated nonzeros=1128624
>>> >>     total number of mallocs used during MatSetValues calls =0
>>> >>       not using I-node routines
>>> >>   0 KSP Residual norm 3.583290589961e+00
>>> >>   1 KSP Residual norm 0.000000000000e+00
>>> >> so something must not be set correctly. The solution is identically
>>> zero everywhere.
>>> >> Is that option list what you meant? If you could let me know what
>>> should be corrected.
>>> >> Thanks for your support,
>>> >> Thibaut
>>> >> On 31/10/2018 16:43, Mark Adams wrote:
>>> >>> On Tue, Oct 30, 2018 at 5:23 PM Appel, Thibaut via petsc-users <
>>> >>> Dear users,
>>> >>> Following a suggestion from Matthew Knepley I’ve been trying to
>>> apply fieldsplit/gamg for my set of PDEs but I’m still encountering issues
>>> despite various tests. pc_gamg simply won’t start.
>>> >>> Note that direct solvers always yield the correct, physical result.
>>> >>> Removing the fieldsplit to focus on the gamg bit and trying to solve
>>> the linear system on a modest size problem still gives, with
>>> >>> '-ksp_monitor -ksp_rtol 1.0e-10 -ksp_gmres_restart 300 -ksp_type
>>> gmres -pc_type gamg'
>>> >>> [3]PETSC ERROR: --------------------- Error Message
>>> >>> [3]PETSC ERROR: Petsc has generated inconsistent data
>>> >>> [3]PETSC ERROR: Have un-symmetric graph (apparently). Use
>>> '-(null)pc_gamg_sym_graph true' to symetrize the graph or
>>> '-(null)pc_gamg_threshold -1' if the matrix is structurally symmetric.
>>> >>> And since then, after adding '-pc_gamg_sym_graph true' I have been
>>> getting
>>> >>> [0]PETSC ERROR: --------------------- Error Message
>>> >>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>> >>> [0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at
>>> iteration
>>> >>> -ksp_chebyshev_esteig_noisy 0/1 does not change anything
>>> >>> Knowing that Chebyshev eigen estimator needs a positive spectrum I
>>> tried ‘-mg_levels_ksp_type gmres’ but iterations would just go on endlessly.
>>> >>> This is OK, but you need to use '-ksp_type fgmres' (this could be
>>> why it is failing ...).
>>> >>> It looks like your matrix is 1) just the velocity field and 2) very
>>> unsymmetric (eg, convection dominated). I would start with
>>> ‘-mg_levels_ksp_type richardson -mg_levels_pc_type sor’.
>>> >>> I would also start with unsmoothed aggregation: '-pc_gamg_nsmooths
>>> 0'
>>> >>> It seems that I have indeed eigenvalues of rather high magnitude in
>>> the spectrum of my operator without being able to determine the reason.
>>> >>> The eigenvectors look like small artifacts at the wall-inflow or
>>> wall-outflow corners with zero anywhere else but I do not know how to
>>> interpret this.
>>> >>> Equations are time-harmonic linearized Navier-Stokes to which a
>>> forcing is applied, there’s no time-marching.
>>> >>> You mean you are in frequency domain?
>>> >>> Matrix is formed with a MPIAIJ type. The formulation is
>>> incompressible, in complex arithmetic and the 2D physical domain is mapped
>>> to a logically rectangular,
>>> >>> This kind of messes up the null space that AMG depends on but AMG
>>> theory is gone for NS anyway.
>>> >>> regular collocated grid with a high-order finite difference method.
>>> >>> I determine the ownership of the rows/degrees of freedom of the
>>> matrix with PetscSplitOwnership and I’m not using DMDA.
>>> >>> Our iterative solvers are probably not going to work well on this
>>> but you should test hypre also (-pc_type hypre -pc_hypre_type boomeramg).
>>> You need to configure PETSc to download hypre.
>>> >>> Mark
>>> >>> The Fortran application code is memory-leak free and has undergone a
>>> strict verification/validation procedure for different variations of the
>>> PDEs.
>>> >>> If there’s any problem with the matrix what could help for the
>>> diagnostic? At this point I’m running out of ideas so I would really
>>> appreciate additional suggestions and discussions.
>>> >>> Thanks for your continued support,
>>> >>> Thibaut
>>> >> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> >> -- Norbert Wiener
>>> >> https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181105/05ff6c17/attachment-0001.html>
