[petsc-users] Solution "jumps" after setting timestep
Jed Brown
jed at jedbrown.org
Sat Nov 3 09:53:59 CDT 2018
What is the index of your DAE? Can you show us code that exhibits this behavior?
"Moritz.Huck--- via petsc-users" <petsc-users at mcs.anl.gov> writes:
> Hi,
> I am using the IMEX Runge Kutta to solve an implicit DAE (G=0).
> When I manually set the time step (TSSetTimestep) my solution jumps.
> If I go from a steady state to the same state, it oscilates a few time and
> comes back to the steady solution.
> Can this be prevented?
> Thank you,
> Moritz
