[petsc-users] Solution "jumps" after setting timestep
Moritz.Huck at isea.rwth-aachen.de Moritz.Huck at isea.rwth-aachen.de
Sat Nov 3 04:56:23 CDT 2018
I am using the IMEX Runge Kutta to solve an implicit DAE (G=0).
When I manually set the time step (TSSetTimestep) my solution jumps.
If I go from  a steady state to the  same state, it oscilates a few time and
comes back to the steady solution.
Can this be prevented?
Thank you,
Moritz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181103/ef717002/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181103/ef717002/attachment.p7s>
