[petsc-users] How to use PetscViewerVTKGetDM
陳宗興 barrydog505 at gmail.com
Fri Nov 2 12:14:54 CDT 2018
I will try it.
Thanks a lot.
barry
Matthew Knepley <knepley at gmail.com> 於 2018年11月3日 週六 上午1:10寫道:
> On Fri, Nov 2, 2018 at 1:06 PM 陳宗興 <barrydog505 at gmail.com> wrote:
>> I want to create a VTK file with DMPlex and Vec, and I found these
>> function:
>> PetscViewerVTKOpen,
> Call VTKOpen() to get a PetscViewer object
>> PetscViewerVTKGetDM, and PetscViewerVTKWriteFunction
> Forget these.
> Call VecView(v, viewer) with your Vec and VTK Viewer.
>   Thanks,
>       Matt
>> Are these what I needed, or maybe something else?
>> thank you,
>> Barry
>> Matthew Knepley <knepley at gmail.com> 於 2018年11月3日 週六 上午12:14寫道:
>>> On Fri, Nov 2, 2018 at 12:11 PM 陳宗興 via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hi,
>>>> I have created a DMPlex using DMPlexCreateFromFile,
>>>> and I use PetscObjectSetName to create the name of DM.
>>>> I have occurred some problem when I try to use PetscViewerVTKGetDM.
>>>> This is what I write:
>>>>      DM   dm;
>>>>      PetscObjectSetName((PetscObject) dm, "Mesh");
>>>>      PetscViewerVTKGetDM(viewer, (PetscObject) dm);
>>> 1) GetDM() returns a DM, so you would need PetscViewerVTKGetDM(viewer,
>>> (PetscObject *) &dm)
>>> 2) However, why are you trying to pull out a DM? It does not look like
>>> you want to do this.
>>>   Thanks,
>>>     Matt
>>>> And here is the output of waring:
>>>>      warning: passing argument 2 of ‘PetscViewerVTKGetDM’ from
>>>> incompatible pointer type [-Wincompatible-pointer-types]
>>>>      ierr = PetscViewerVTKGetDM(viewer, (PetscObject) dm);CHKERRQ(ierr);
>>>>      note: expected ‘struct _p_PetscObject **’ but argument is of type
>>>> ‘struct _p_PetscObject *'
>>>>      PETSC_EXTERN PetscErrorCode
>>>> PetscViewerVTKGetDM(PetscViewer,PetscObject*);
>>>> How can I fix it?
>>>> Thank you,
>>>> Barry
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181103/fabd37c4/attachment-0001.html>
