[petsc-users] How to use PetscViewerVTKGetDM
陳宗興
barrydog505 at gmail.com
Fri Nov 2 12:05:37 CDT 2018
I want to create a VTK file with DMPlex and Vec, and I found these function:
PetscViewerVTKOpen, PetscViewerVTKGetDM, and PetscViewerVTKWriteFunction
Are these what I needed, or maybe something else?
thank you,
Barry
Matthew Knepley <knepley at gmail.com> 於 2018年11月3日 週六 上午12:14寫道:
> On Fri, Nov 2, 2018 at 12:11 PM 陳宗興 via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> I have created a DMPlex using DMPlexCreateFromFile,
>> and I use PetscObjectSetName to create the name of DM.
>> I have occurred some problem when I try to use PetscViewerVTKGetDM.
>> This is what I write:
>> DM dm;
>> PetscObjectSetName((PetscObject) dm, "Mesh");
>> PetscViewerVTKGetDM(viewer, (PetscObject) dm);
> 1) GetDM() returns a DM, so you would need PetscViewerVTKGetDM(viewer,
> (PetscObject *) &dm)
> 2) However, why are you trying to pull out a DM? It does not look like you
> want to do this.
> Thanks,
> Matt
>> And here is the output of waring:
>> warning: passing argument 2 of ‘PetscViewerVTKGetDM’ from
>> incompatible pointer type [-Wincompatible-pointer-types]
>> ierr = PetscViewerVTKGetDM(viewer, (PetscObject) dm);CHKERRQ(ierr);
>> note: expected ‘struct _p_PetscObject **’ but argument is of type
>> ‘struct _p_PetscObject *'
>> PETSC_EXTERN PetscErrorCode
>> PetscViewerVTKGetDM(PetscViewer,PetscObject*);
>> How can I fix it?
>> Thank you,
>> Barry
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181103/46a78595/attachment.html>
