[petsc-users] Re-configuring PETSc
Najeeb Ahmad nahmad16 at ku.edu.tr
Mon May 28 10:32:45 CDT 2018
Thanks a lot Satish for your prompt reply.
I just checked that SuperLU_dist package works only for matrices of type
aij. and uses lu preconditioner. I am currently working with baij matrix.
What is the best preconditioner choice for baij matrices on parallel
machines?
Thanks
On Mon, May 28, 2018 at 8:23 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 28 May 2018, Najeeb Ahmad wrote:
> > Hi All,
> > I have Petsc release version 3.9.2 configured with the following options:
> > Configure options --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort
> > --download-fblaslapack=1
> > Now I want to use PCILU in my code and when I set the PC type to PCILU in
> > the code, I get the following error:
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: See
> > http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html for
> > possible LU and Cholesky solvers
> > [0]PETSC ERROR: Could not locate a solver package. Perhaps you must
> > ./configure with --download-<package>
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for
> > trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.9.2, unknown
> > [0]PETSC ERROR: ./main on a arch-linux2-c-debug named Karachi by nahmad
> Mon
> > May 28 17:52:41 2018
> > [0]PETSC ERROR: Configure options --with-cc=mpiicc --with-cxx=mpiicpc
> > --with-fc=mpiifort --download-fblaslapack=1
> > [0]PETSC ERROR: #1 MatGetFactor() line 4318 in
> > /home/nahmad/PETSc/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #2 PCSetUp_ILU() line 142 in
> > /home/nahmad/PETSc/petsc/src/ksp/pc/impls/factor/ilu/ilu.c
> > [0]PETSC ERROR: #3 PCSetUp() line 923 in
> > /home/nahmad/PETSc/petsc/src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: #4 KSPSetUp() line 381 in
> > /home/nahmad/PETSc/petsc/src/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: #5 KSPSolve() line 612 in
> > [0]PETSC ERROR: #6 SolveSystem() line 60 in
> > /home/nahmad/Aramco/petsc/petsc/BlockSolveTest/src/main.c
> > I assume that I am missing LU package like SuperLU_dist for instance and
> I
> > need to download and configure it with Petsc.
> yes - petsc has sequential LU - but you need superlu_dist/mumps for
> parallel lu.
> > I am wondering what is the best way to reconfigure Petsc to download and
> > use the appropriate package to support PCILU?
> Rerun configure with the additional option --download-superlu_dist=1.
> You can do this with current PETSC_ARCH you are using [i.e reinstall
> over the current build] - or use a different PETSC_ARCH - so both
> builds exist and useable.
> Satish
> > You advice is highly appreciated.
*Najeeb Ahmad*
*Research and Teaching Assistant*
*PARallel and MultiCORE Computing Laboratory (ParCoreLab) *
*Computer Science and Engineering*
*Koç University, Istanbul, Turkey*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180528/6a46d611/attachment.html>
