[petsc-users] Load binary matrix created in parallel
Matthew Knepley
knepley at gmail.com
Wed May 23 11:01:24 CDT 2018
On Wed, May 23, 2018 at 11:54 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
> Hello,
> Is your claim that you do
>> MatView()
> I did not call this function; I called MatLoad() directly.
This is the output function.
> and get a different matrix? This is unlikely since we test this.
>> Are you sure you have the same rhs?
> I will check this again.
> So if a binary matrix file is created,
> it doesn't matter if different number of processors is used.
Right.
Matt
> Thanks,
> Shidi
> On 2018-05-23 16:48, Matthew Knepley wrote:
>> On Wed, May 23, 2018 at 11:45 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>> Hi,
>>> How are you evaluating?
>>> I put the loaded matrix to a linear system and solve it.
>> MatView()
>> and then
>> MatLoad()
>> Thanks,
>> Matt
>> Cheers,
>>> Shidi
>>> On 2018-05-23 16:42, Jed Brown wrote:
>>> "Y. Shidi" <ys453 at cam.ac.uk> writes:
>>> Hello,
>>> Is there any way to sequentially load a binary matrix file, which
>>> is created in parallel?
>>> I tried to use PetscViewerBinaryOpen() and MatLoad() to load
>>> the matrix that is created by using 2 cores, and solved a linear
>>> system by using this matrix but the results is not correct.
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ [1]
>> Links:
>> [1] http://www.caam.rice.edu/~mk51/
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180523/4c69da6d/attachment.html>
