[petsc-users] Load binary matrix created in parallel
Wed May 23 10:48:27 CDT 2018
On Wed, May 23, 2018 at 11:45 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
> Hi,
> How are you evaluating?
> I put the loaded matrix to a linear system and solve it.
Is your claim that you do
  MatView()
and then
  MatLoad()
and get a different matrix? This is unlikely since we test this.
Are you sure you have the same rhs?
    Matt
> Cheers,
> Shidi
> On 2018-05-23 16:42, Jed Brown wrote:
>> "Y. Shidi" <ys453 at cam.ac.uk> writes:
>> Hello,
>>> Is there any way to sequentially load a binary matrix file, which
>>> is created in parallel?
>>> I tried to use PetscViewerBinaryOpen() and MatLoad() to load
>>> the matrix that is created by using 2 cores, and solved a linear
>>> system by using this matrix but the results is not correct.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180523/cafa1480/attachment-0001.html>
