[petsc-users] SuperLU_dist bug with parallel symbolic factorisation
    Keith Lindsay
    klindsay at ucar.edu
    Tue May 22 15:03:14 CDT 2018
I use SuperLU_dist, outside of PETSc, and use the parallel symbolic
factorization functionality. In my experience it is significantly faster
than the serial symbolic factorization. I don't have clean numbers on hand,
but my recollection is that going from serial to parallel reduced time
spent in the symbolic factorization by around an order of magnitude. Using
ParMETIS also significantly reduced the memory footprint of the symbolic
factorization.
I suspect that the impact of ParMETIS on performance depends on the
application. In my application, I was using a matrix with ~4.2e6 unknowns,
an average of 20 non-zeros per row, and running on 256 cores.
Keith
On Tue, May 22, 2018 at 12:22 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Eric,
> I am curious if the parallel symbolic factoriation is faster than
> the sequential version? Do you have timing?
> Fande,
> On Tue, May 22, 2018 at 12:18 PM, Eric Chamberland <
> Eric.Chamberland at giref.ulaval.ca> wrote:
>> On 22/05/18 02:03 PM, Smith, Barry F. wrote:
>>>     Hmm, why would
>>> the resolution with *sequential* symbolic factorisation gives ans err
>>>> around 1e-6 instead of 1e-16 for parallel one (when it works).
>>>    ? One would think that doing a "sequential" symbolic factorization
>>> won't affect the answer to this huge amount? Perhaps this is the problem
>>> that needs to be addressed.
>> I do agree that this is a huge amount of difference... and if we agree
>> this is also a bug, than it means there are not one but two bugs that
>> deserve to be fixed...
>> Thanks,
>> Eric
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180522/0455f66d/attachment-0001.html>
