[petsc-users] SuperLU_dist bug with parallel symbolic factorisation
Xiaoye S. Li
xsli at lbl.gov
Tue May 22 11:11:46 CDT 2018
Numerical factorization is always parallel (based on number of MPI tasks
and OMP_NUM_THREADS you set), the issue here is only related to symbolic
factorization (figuring out the nonzero pattern in the LU factors). Default
setting is to use sequential symbolic factorization, precisely due to the
ParMETIS bugs.
(The parallel symbolic factorization needs ParMETIS ordering.)
Question for PETSc developers --
Is PT-Scotch an installation option? I can try to use PT_Scotch together
with parallel symbolic factorization, which should be more stable than
ParMETIS.
Sherry
On Tue, May 22, 2018 at 9:00 AM, Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> And I will add a question:
> Shouldn't there be an automatic switch to parallele factorisation when
> num. of process is greater than 1 ?
> Eric
> On 22/05/18 11:55 AM, Eric Chamberland wrote:
>> Exactly: this bug shows up when I activate the parallel symbolic
>> factorisation, otherwise I do not have it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180522/daf09abf/attachment.html>
