[petsc-users] SuperLU_dist bug with parallel symbolic factorisation
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Tue May 22 09:53:10 CDT 2018
The given matrix+vector is bogus with SuperLU_Dist on some of our
nighlty validation tests since I activated the parallel symbolic
factorisation. (with -mat_superlu_dist_colperm PARMETIS
-mat_superlu_dist_parsymbfact 1 )
I extracted an example system and reproduced the bug with
src/ksp/ksp/examples/tests/ex6.c that I can run it with 2 or 3
processes, but with 4 it gives a FPE on process #1:
mpirun -n 4 ./ex6 -f AssembleurGD_resolution_no_0_0 -ksp_view -ksp_type
preonly -pc_type lu -pc_factor_mat_solver_type superlu_dist
-mat_superlu_dist_colperm PARMETIS -mat_superlu_dist_parsymbfact 1
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
X to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: --------------------- Stack Frames
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR: INSTEAD the line number of the start of the function
[1]PETSC ERROR: is given.
[1]PETSC ERROR: [1] SuperLU_DIST:pdgssvx line 467
/home/mefpp_ericc/petsc-3.9.2-debug/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[1]PETSC ERROR: [1] MatLUFactorNumeric_SuperLU_DIST line 314
[1]PETSC ERROR: [1] MatLUFactorNumeric line 3014
/home/mefpp_ericc/petsc-3.9.2-debug/src/mat/interface/matrix.c
[1]PETSC ERROR: [1] PCSetUp_LU line 59
/home/mefpp_ericc/petsc-3.9.2-debug/src/ksp/pc/impls/factor/lu/lu.c
[1]PETSC ERROR: [1] PCSetUp line 885
/home/mefpp_ericc/petsc-3.9.2-debug/src/ksp/pc/interface/precon.c
[1]PETSC ERROR: [1] KSPSetUp line 294
/home/mefpp_ericc/petsc-3.9.2-debug/src/ksp/ksp/interface/itfunc.c
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.9.2, May, 20, 2018
[1]PETSC ERROR: ./ex6 on a named lorien by eric Tue May 22 10:39:15 2018
[1]PETSC ERROR: Configure options
--prefix=/opt/petsc-3.9.2_debug_openmpi-1.10.2 --with-mpi-compilers=1
--with-mpi-dir=/opt/openmpi-1.10.2 --with-make-np=12
--with-shared-libraries=1 --with-debugging=yes --with-memalign=64
--with-visibility=0 --with-64-bit-indices=0 --download-ml=yes
--download-mumps=yes --download-superlu=yes --download-superlu_dist=yes
--download-parmetis=yes --download-ptscotch=yes --download-metis=yes
--download-suitesparse=yes --download-hypre=yes
--with-blaslapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64
--with-mkl_pardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl
--with-mkl_cpardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl
--with-scalapack=1
--with-scalapack-include=/opt/intel/composer_xe_2015.2.164/mkl/include
--with-scalapack-lib="-L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64
-lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
[1]PETSC ERROR: #1 User provided function() line 0 in unknown file
The given Matrix+Vector are available here:
http://www.giref.ulaval.ca/~ericc/bug_superlu_dist_parallel_factorisation/AssembleurGD_resolution_no_0_0
http://www.giref.ulaval.ca/~ericc/bug_superlu_dist_parallel_factorisation/AssembleurGD_resolution_no_0_0.info
If I run with -on_error_attach_debugger, I can see a division by zero here:
#8 <signal handler called>
(gdb)
#9 0x00007f96a2148e52 in libmetis__FM_2WayCutRefine (ctrl=0x2784d20,
graph=0x2784940, ntpwgts=0x7ffdfa323060, niter=4)
at
/home/mefpp_ericc/petsc-3.9.2-debug/arch-linux2-c-debug/externalpackages/git.metis/libmetis/fm.c:60
60 avgvwgt = gk_min((pwgts[0]+pwgts[1])/20,
2*(pwgts[0]+pwgts[1])/nvtxs);
and nvtxs value is "0"...
Thanks!
Eric
