[petsc-users] Matrix-free preconditioner using shell matrix
Jed Brown jed at jedbrown.org
Fri May 18 09:29:19 CDT 2018
Praveen C <cpraveen at gmail.com> writes:
>> On 18-May-2018, at 7:46 PM, Jed Brown <jed at jedbrown.org> wrote:
>> You don't need to use a shell matrix to implement a shell
>> preconditioner.  When using a shell PC, you need to call KSPSetPC() --
>> you can unwrap that from TS -> SNES -> KSP.
> Thanks Jed.
> Is it the case that I cannot use a shell matrix to implement a shell preconditioner ?
They are two different concepts.  You can use either or both.
