[petsc-users] Linear iterative solver cannot converge
Matthew Knepley
knepley at gmail.com
Fri May 18 04:58:22 CDT 2018
On Fri, May 18, 2018 at 5:54 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
> Hello all,
> I do not have much knowledge on linear iterative solvers,
> so when use PETSc krylov solvers, I try several combinations
> (e.g. cg+jacobi, gmres+hypre, etc). But I cannot get a
> converged solution. I have used 'preonly' and 'lu' check
> that the system is correctly constructed.
> Below is the ksp log output with 500 iterations.
This is only 411 iterations, and we cannot see what solver was used.
In general, the iterative solver is very sensitive to the system. We
recommend
starting with a solver that has worked before for someone by checking the
literature.
Matt
> 0 KSP preconditioned resid norm 7.082525933041e-04 true resid norm
> 6.326394271849e-01 ||r(i)||/||b|| 1.000000000000e+00
> 0 KSP Residual norm 7.082525933041e-04 % max 1.000000000000e+00 min
> 1.000000000000e+00 max/min 1.000000000000e+00
> 1 KSP preconditioned resid norm 7.826722253922e-05 true resid norm
> 1.564088399639e+00 ||r(i)||/||b|| 2.472322040690e+00
> 1 KSP Residual norm 7.826722253922e-05 % max 9.487098101782e-01 min
> 9.487098101782e-01 max/min 1.000000000000e+00
> 2 KSP preconditioned resid norm 1.160749405043e-05 true resid norm
> 6.895674436780e+00 ||r(i)||/||b|| 1.089984933039e+01
> 2 KSP Residual norm 1.160749405043e-05 % max 1.047419854967e+00 min
> 8.139171190265e-01 max/min 1.286887608679e+00
> 3 KSP preconditioned resid norm 2.302649108076e-06 true resid norm
> 3.399636614710e+01 ||r(i)||/||b|| 5.373734972285e+01
> 3 KSP Residual norm 2.302649108076e-06 % max 1.095412865033e+00 min
> 7.524989114835e-01 max/min 1.455700265231e+00
> 4 KSP preconditioned resid norm 1.515706794298e-06 true resid norm
> 7.915135424703e+00 ||r(i)||/||b|| 1.251129013556e+01
> 4 KSP Residual norm 1.515706794298e-06 % max 4.259813886522e+00 min
> 7.476020986409e-01 max/min 5.697969406808e+00
> 5 KSP preconditioned resid norm 1.062659539539e-06 true resid norm
> 1.291636850619e+01 ||r(i)||/||b|| 2.041663537106e+01
> 5 KSP Residual norm 1.062659539539e-06 % max 6.979478925762e+00 min
> 7.421457344352e-01 max/min 9.404458722751e+00
> 6 KSP preconditioned resid norm 4.248015453585e-07 true resid norm
> 7.273048463349e+00 ||r(i)||/||b|| 1.149635661456e+01
> 6 KSP Residual norm 4.248015453585e-07 % max 8.197134494997e+00 min
> 7.249135442935e-01 max/min 1.130774084651e+01
> 7 KSP preconditioned resid norm 1.844877736368e-07 true resid norm
> 1.800911822307e+00 ||r(i)||/||b|| 2.846663905095e+00
> 7 KSP Residual norm 1.844877736368e-07 % max 8.617693175971e+00 min
> 7.171590601865e-01 max/min 1.201643213394e+01
> 8 KSP preconditioned resid norm 1.343329736018e-07 true resid norm
> 8.308030162167e-01 ||r(i)||/||b|| 1.313233068501e+00
> 8 KSP Residual norm 1.343329736018e-07 % max 8.797419513003e+00 min
> 7.151810153432e-01 max/min 1.230096901941e+01
> 9 KSP preconditioned resid norm 8.435244868263e-08 true resid norm
> 1.039165561694e+00 ||r(i)||/||b|| 1.642587415580e+00
> 9 KSP Residual norm 8.435244868263e-08 % max 8.954896895684e+00 min
> 7.106664887897e-01 max/min 1.260070235046e+01
> 10 KSP preconditioned resid norm 3.966928154020e-08 true resid norm
> 5.935564227055e-01 ||r(i)||/||b|| 9.382223067360e-01
> 10 KSP Residual norm 3.966928154020e-08 % max 9.031210516030e+00 min
> 7.020732475337e-01 max/min 1.286363003826e+01
> 11 KSP preconditioned resid norm 2.465535486554e-08 true resid norm
> 4.008826554548e-01 ||r(i)||/||b|| 6.336668854779e-01
> 11 KSP Residual norm 2.465535486554e-08 % max 9.085166722582e+00 min
> 6.977273003895e-01 max/min 1.302108534023e+01
> 12 KSP preconditioned resid norm 2.030859749117e-08 true resid norm
> 3.813432885130e-01 ||r(i)||/||b|| 6.027814140670e-01
> 12 KSP Residual norm 2.030859749117e-08 % max 9.108740437496e+00 min
> 6.953332846189e-01 max/min 1.309981938012e+01
> 13 KSP preconditioned resid norm 1.822679962077e-08 true resid norm
> 3.872430711288e-01 ||r(i)||/||b|| 6.121070778847e-01
> 13 KSP Residual norm 1.822679962077e-08 % max 9.136924983475e+00 min
> 6.787423686921e-01 max/min 1.346155095796e+01
> 14 KSP preconditioned resid norm 1.695370146944e-08 true resid norm
> 3.791469790845e-01 ||r(i)||/||b|| 5.993097533799e-01
> 14 KSP Residual norm 1.695370146944e-08 % max 9.150838240684e+00 min
> 4.836016572082e-01 max/min 1.892226402513e+01
> 15 KSP preconditioned resid norm 1.670891990697e-08 true resid norm
> 3.742448806985e-01 ||r(i)||/||b|| 5.915611082981e-01
> 15 KSP Residual norm 1.670891990697e-08 % max 9.168112723795e+00 min
> 3.589247137480e-01 max/min 2.554327515667e+01
> 16 KSP preconditioned resid norm 1.664236372933e-08 true resid norm
> 3.722478007586e-01 ||r(i)||/||b|| 5.884043655247e-01
> 16 KSP Residual norm 1.664236372933e-08 % max 9.178525399198e+00 min
> 2.321963324507e-01 max/min 3.952915751220e+01
> 17 KSP preconditioned resid norm 1.663949610587e-08 true resid norm
> 3.719568951825e-01 ||r(i)||/||b|| 5.879445371238e-01
> 17 KSP Residual norm 1.663949610587e-08 % max 9.184089312561e+00 min
> 1.131861415164e-01 max/min 8.114146475459e+01
> 18 KSP preconditioned resid norm 1.663337572879e-08 true resid norm
> 3.719017039287e-01 ||r(i)||/||b|| 5.878572974555e-01
> 18 KSP Residual norm 1.663337572879e-08 % max 9.189859567814e+00 min
> 5.648232511467e-02 max/min 1.627032801705e+02
> 19 KSP preconditioned resid norm 1.662539368980e-08 true resid norm
> 3.720300901295e-01 ||r(i)||/||b|| 5.880602348560e-01
> 19 KSP Residual norm 1.662539368980e-08 % max 9.194407242900e+00 min
> 3.409368279927e-02 max/min 2.696806706695e+02
> 20 KSP preconditioned resid norm 1.660752961666e-08 true resid norm
> 3.720476648171e-01 ||r(i)||/||b|| 5.880880147997e-01
> 20 KSP Residual norm 1.660752961666e-08 % max 9.194602239844e+00 min
> 2.365991044206e-02 max/min 3.886152596545e+02
> 21 KSP preconditioned resid norm 1.660447026728e-08 true resid norm
> 3.719370961482e-01 ||r(i)||/||b|| 5.879132412016e-01
> 21 KSP Residual norm 1.660447026728e-08 % max 9.198469035476e+00 min
> 1.563110293107e-02 max/min 5.884721683453e+02
> 22 KSP preconditioned resid norm 1.660446294321e-08 true resid norm
> 3.719253643667e-01 ||r(i)||/||b|| 5.878946970183e-01
> 22 KSP Residual norm 1.660446294321e-08 % max 9.198477237204e+00 min
> 1.078305273545e-02 max/min 8.530494529592e+02
> 23 KSP preconditioned resid norm 1.660330040466e-08 true resid norm
> 3.721217486420e-01 ||r(i)||/||b|| 5.882051175626e-01
> 23 KSP Residual norm 1.660330040466e-08 % max 9.202933332869e+00 min
> 9.205686060935e-03 max/min 9.997009752398e+02
> 24 KSP preconditioned resid norm 1.660327295939e-08 true resid norm
> 3.721432241387e-01 ||r(i)||/||b|| 5.882390634340e-01
> 24 KSP Residual norm 1.660327295939e-08 % max 9.203266640610e+00 min
> 8.725099522239e-03 max/min 1.054803629134e+03
> 25 KSP preconditioned resid norm 1.660322661301e-08 true resid norm
> 3.721299294797e-01 ||r(i)||/||b|| 5.882180488428e-01
> 25 KSP Residual norm 1.660322661301e-08 % max 9.203403735734e+00 min
> 8.464109615459e-03 max/min 1.087344582462e+03
> 26 KSP preconditioned resid norm 1.660321583344e-08 true resid norm
> 3.721333122477e-01 ||r(i)||/||b|| 5.882233959139e-01
> 26 KSP Residual norm 1.660321583344e-08 % max 9.203842444616e+00 min
> 8.185670305944e-03 max/min 1.124384699190e+03
> 27 KSP preconditioned resid norm 1.659716957149e-08 true resid norm
> 3.722220312184e-01 ||r(i)||/||b|| 5.883636321479e-01
> 27 KSP Residual norm 1.659716957149e-08 % max 9.203846515427e+00 min
> 7.896672970975e-03 max/min 1.165534719401e+03
> 28 KSP preconditioned resid norm 1.659174589261e-08 true resid norm
> 3.723499490782e-01 ||r(i)||/||b|| 5.885658292514e-01
> 28 KSP Residual norm 1.659174589261e-08 % max 9.204684093512e+00 min
> 7.626673798499e-03 max/min 1.206906750794e+03
> 29 KSP preconditioned resid norm 1.658497009797e-08 true resid norm
> 3.724237904064e-01 ||r(i)||/||b|| 5.886825487050e-01
> 29 KSP Residual norm 1.658497009797e-08 % max 9.204686109552e+00 min
> 7.248769500402e-03 max/min 1.269827397470e+03
> 30 KSP preconditioned resid norm 1.658420583638e-08 true resid norm
> 3.724329227626e-01 ||r(i)||/||b|| 5.886969840306e-01
> 30 KSP Residual norm 1.658420583638e-08 % max 9.205127707991e+00 min
> 6.913923297310e-03 max/min 1.331389908762e+03
> 31 KSP preconditioned resid norm 1.658394997001e-08 true resid norm
> 3.724106820061e-01 ||r(i)||/||b|| 5.886618285289e-01
> 31 KSP Residual norm 1.658394997001e-08 % max 9.205128428478e+00 min
> 6.644030177187e-03 max/min 1.385473603068e+03
> 32 KSP preconditioned resid norm 1.658394544037e-08 true resid norm
> 3.724013538135e-01 ||r(i)||/||b|| 5.886470836487e-01
> 32 KSP Residual norm 1.658394544037e-08 % max 9.205133034961e+00 min
> 6.415376763387e-03 max/min 1.434854627322e+03
> 33 KSP preconditioned resid norm 1.658256686670e-08 true resid norm
> 3.725160103788e-01 ||r(i)||/||b|| 5.888283188996e-01
> 33 KSP Residual norm 1.658256686670e-08 % max 9.205322724899e+00 min
> 6.129032159846e-03 max/min 1.501921100236e+03
> 34 KSP preconditioned resid norm 1.658198817115e-08 true resid norm
> 3.725196207066e-01 ||r(i)||/||b|| 5.888340256696e-01
> 34 KSP Residual norm 1.658198817115e-08 % max 9.205896491877e+00 min
> 5.825724791452e-03 max/min 1.580214792396e+03
> 35 KSP preconditioned resid norm 1.658171734588e-08 true resid norm
> 3.725087580299e-01 ||r(i)||/||b|| 5.888168552622e-01
> 35 KSP Residual norm 1.658171734588e-08 % max 9.205945192996e+00 min
> 5.605660067611e-03 max/min 1.642258910095e+03
> 36 KSP preconditioned resid norm 1.658129588997e-08 true resid norm
> 3.724965685568e-01 ||r(i)||/||b|| 5.887975876153e-01
> 36 KSP Residual norm 1.658129588997e-08 % max 9.206318976719e+00 min
> 5.485984644166e-03 max/min 1.678152523906e+03
> 37 KSP preconditioned resid norm 1.658089864613e-08 true resid norm
> 3.725244893116e-01 ||r(i)||/||b|| 5.888417213724e-01
> 37 KSP Residual norm 1.658089864613e-08 % max 9.206643625524e+00 min
> 5.409333758549e-03 max/min 1.701992155868e+03
> 38 KSP preconditioned resid norm 1.658010080967e-08 true resid norm
> 3.725552388317e-01 ||r(i)||/||b|| 5.888903265001e-01
> 38 KSP Residual norm 1.658010080967e-08 % max 9.222413265296e+00 min
> 5.329794244440e-03 max/min 1.730350711928e+03
> 39 KSP preconditioned resid norm 1.657990108602e-08 true resid norm
> 3.725613932319e-01 ||r(i)||/||b|| 5.889000546327e-01
> 39 KSP Residual norm 1.657990108602e-08 % max 9.265183049042e+00 min
> 5.255818039127e-03 max/min 1.762843192072e+03
> 40 KSP preconditioned resid norm 1.657960808250e-08 true resid norm
> 3.725537447923e-01 ||r(i)||/||b|| 5.888879649031e-01
> 40 KSP Residual norm 1.657960808250e-08 % max 9.295348987310e+00 min
> 5.172817833368e-03 max/min 1.796960435635e+03
> 41 KSP preconditioned resid norm 1.657958687100e-08 true resid norm
> 3.725506176790e-01 ||r(i)||/||b|| 5.888830219400e-01
> 41 KSP Residual norm 1.657958687100e-08 % max 9.313105724221e+00 min
> 5.071725615663e-03 max/min 1.836279489462e+03
> 42 KSP preconditioned resid norm 1.657921742619e-08 true resid norm
> 3.725582418972e-01 ||r(i)||/||b|| 5.888950733833e-01
> 42 KSP Residual norm 1.657921742619e-08 % max 9.322955878206e+00 min
> 4.963104015890e-03 max/min 1.878452647447e+03
> 43 KSP preconditioned resid norm 1.657684473798e-08 true resid norm
> 3.725895709563e-01 ||r(i)||/||b|| 5.889445945762e-01
> 43 KSP Residual norm 1.657684473798e-08 % max 9.329772550486e+00 min
> 4.863208011283e-03 max/min 1.918439953389e+03
> 44 KSP preconditioned resid norm 1.657659296508e-08 true resid norm
> 3.725990953050e-01 ||r(i)||/||b|| 5.889596495163e-01
> 44 KSP Residual norm 1.657659296508e-08 % max 9.338931498127e+00 min
> 4.781973618640e-03 max/min 1.952945006163e+03
> 45 KSP preconditioned resid norm 1.657642406464e-08 true resid norm
> 3.726031709829e-01 ||r(i)||/||b|| 5.889660918557e-01
> 45 KSP Residual norm 1.657642406464e-08 % max 9.367754233355e+00 min
> 4.692163450780e-03 max/min 1.996468011318e+03
> 46 KSP preconditioned resid norm 1.657554485219e-08 true resid norm
> 3.725847080302e-01 ||r(i)||/||b|| 5.889369078499e-01
> 46 KSP Residual norm 1.657554485219e-08 % max 9.525984789796e+00 min
> 4.602804961008e-03 max/min 2.069604267505e+03
> 47 KSP preconditioned resid norm 1.657502492412e-08 true resid norm
> 3.726033324164e-01 ||r(i)||/||b|| 5.889663470303e-01
> 47 KSP Residual norm 1.657502492412e-08 % max 9.649033152731e+00 min
> 4.528495247014e-03 max/min 2.130737171270e+03
> 48 KSP preconditioned resid norm 1.657431464097e-08 true resid norm
> 3.726349240386e-01 ||r(i)||/||b|| 5.890162832513e-01
> 48 KSP Residual norm 1.657431464097e-08 % max 9.706832936743e+00 min
> 4.483584175077e-03 max/min 2.164971718542e+03
> 49 KSP preconditioned resid norm 1.657430235052e-08 true resid norm
> 3.726384684009e-01 ||r(i)||/||b|| 5.890218857511e-01
> 49 KSP Residual norm 1.657430235052e-08 % max 9.727915700790e+00 min
> 4.452026131090e-03 max/min 2.185053594555e+03
> 50 KSP preconditioned resid norm 1.657409874525e-08 true resid norm
> 3.726369422798e-01 ||r(i)||/||b|| 5.890194734432e-01
> 50 KSP Residual norm 1.657409874525e-08 % max 9.739354480687e+00 min
> 4.417847429271e-03 max/min 2.204547494365e+03
> 51 KSP preconditioned resid norm 1.657402591687e-08 true resid norm
> 3.726432094382e-01 ||r(i)||/||b|| 5.890293798102e-01
> 51 KSP Residual norm 1.657402591687e-08 % max 9.745116733535e+00 min
> 4.373866876163e-03 max/min 2.228032313156e+03
> 52 KSP preconditioned resid norm 1.657322689294e-08 true resid norm
> 3.726746392101e-01 ||r(i)||/||b|| 5.890790601978e-01
> 52 KSP Residual norm 1.657322689294e-08 % max 9.748668028325e+00 min
> 4.324537557867e-03 max/min 2.254268323000e+03
> 53 KSP preconditioned resid norm 1.657285683191e-08 true resid norm
> 3.726927767005e-01 ||r(i)||/||b|| 5.891077297521e-01
> 53 KSP Residual norm 1.657285683191e-08 % max 9.752597336655e+00 min
> 4.266519999816e-03 max/min 2.285843576750e+03
> 54 KSP preconditioned resid norm 1.657191968374e-08 true resid norm
> 3.727170337719e-01 ||r(i)||/||b|| 5.891460724009e-01
> 54 KSP Residual norm 1.657191968374e-08 % max 9.754248539341e+00 min
> 4.180253974132e-03 max/min 2.333410505606e+03
> 55 KSP preconditioned resid norm 1.657127209230e-08 true resid norm
> 3.727281752171e-01 ||r(i)||/||b|| 5.891636834519e-01
> 55 KSP Residual norm 1.657127209230e-08 % max 9.755352416617e+00 min
> 4.058383922487e-03 max/min 2.403752972351e+03
> 56 KSP preconditioned resid norm 1.657120137140e-08 true resid norm
> 3.727397473887e-01 ||r(i)||/||b|| 5.891819753432e-01
> 56 KSP Residual norm 1.657120137140e-08 % max 9.756044425698e+00 min
> 3.878156481600e-03 max/min 2.515639704583e+03
> 57 KSP preconditioned resid norm 1.657119611240e-08 true resid norm
> 3.727422879145e-01 ||r(i)||/||b|| 5.891859910995e-01
> 57 KSP Residual norm 1.657119611240e-08 % max 9.756250547216e+00 min
> 3.666552757137e-03 max/min 2.660878267257e+03
> 58 KSP preconditioned resid norm 1.657111258731e-08 true resid norm
> 3.727518818995e-01 ||r(i)||/||b|| 5.892011561122e-01
> 58 KSP Residual norm 1.657111258731e-08 % max 9.756370020073e+00 min
> 3.468718193201e-03 max/min 2.812673003877e+03
> 59 KSP preconditioned resid norm 1.657094596592e-08 true resid norm
> 3.727705204449e-01 ||r(i)||/||b|| 5.892306176738e-01
> 59 KSP Residual norm 1.657094596592e-08 % max 9.756371302765e+00 min
> 3.286906229078e-03 max/min 2.968253616867e+03
> 60 KSP preconditioned resid norm 1.657094109276e-08 true resid norm
> 3.727697067525e-01 ||r(i)||/||b|| 5.892293314871e-01
> 60 KSP Residual norm 1.657094109276e-08 % max 9.756462036212e+00 min
> 3.176741626112e-03 max/min 3.071216732270e+03
> 61 KSP preconditioned resid norm 1.657074458504e-08 true resid norm
> 3.727879098160e-01 ||r(i)||/||b|| 5.892581046914e-01
> 61 KSP Residual norm 1.657074458504e-08 % max 9.756473123113e+00 min
> 3.125891922048e-03 max/min 3.121180567471e+03
> 62 KSP preconditioned resid norm 1.657036224624e-08 true resid norm
> 3.728005388067e-01 ||r(i)||/||b|| 5.892780670746e-01
> 62 KSP Residual norm 1.657036224624e-08 % max 9.756473207720e+00 min
> 3.096484756596e-03 max/min 3.150822295164e+03
> 63 KSP preconditioned resid norm 1.657008856448e-08 true resid norm
> 3.728158759902e-01 ||r(i)||/||b|| 5.893023102419e-01
> 63 KSP Residual norm 1.657008856448e-08 % max 9.756531519156e+00 min
> 3.069291385183e-03 max/min 3.178757014161e+03
> 64 KSP preconditioned resid norm 1.656933678892e-08 true resid norm
> 3.728618516341e-01 ||r(i)||/||b|| 5.893749829871e-01
> 64 KSP Residual norm 1.656933678892e-08 % max 9.756534097563e+00 min
> 3.030347211416e-03 max/min 3.219609311041e+03
> 65 KSP preconditioned resid norm 1.656929382536e-08 true resid norm
> 3.728620592926e-01 ||r(i)||/||b|| 5.893753112286e-01
> 65 KSP Residual norm 1.656929382536e-08 % max 9.756542682563e+00 min
> 2.980473130456e-03 max/min 3.273487884479e+03
> 66 KSP preconditioned resid norm 1.656925076679e-08 true resid norm
> 3.728588689809e-01 ||r(i)||/||b|| 5.893702683692e-01
> 66 KSP Residual norm 1.656925076679e-08 % max 9.756768124123e+00 min
> 2.899706071757e-03 max/min 3.364743833574e+03
> 67 KSP preconditioned resid norm 1.656919627951e-08 true resid norm
> 3.728539364727e-01 ||r(i)||/||b|| 5.893624716560e-01
> 67 KSP Residual norm 1.656919627951e-08 % max 9.756860985294e+00 min
> 2.765552951215e-03 max/min 3.527996446790e+03
> 68 KSP preconditioned resid norm 1.656919067597e-08 true resid norm
> 3.728560345126e-01 ||r(i)||/||b|| 5.893657879842e-01
> 68 KSP Residual norm 1.656919067597e-08 % max 9.756861143601e+00 min
> 2.585147683296e-03 max/min 3.774198745644e+03
> 69 KSP preconditioned resid norm 1.656919023495e-08 true resid norm
> 3.728555414719e-01 ||r(i)||/||b|| 5.893650086449e-01
> 69 KSP Residual norm 1.656919023495e-08 % max 9.756912528517e+00 min
> 2.353080610226e-03 max/min 4.146442109171e+03
> 70 KSP preconditioned resid norm 1.656817007273e-08 true resid norm
> 3.728377336313e-01 ||r(i)||/||b|| 5.893368601612e-01
> 70 KSP Residual norm 1.656817007273e-08 % max 9.756913153950e+00 min
> 2.015051177738e-03 max/min 4.842017543646e+03
> 71 KSP preconditioned resid norm 1.656803992911e-08 true resid norm
> 3.728311872625e-01 ||r(i)||/||b|| 5.893265124520e-01
> 71 KSP Residual norm 1.656803992911e-08 % max 9.756913653213e+00 min
> 1.699244792218e-03 max/min 5.741911758620e+03
> 72 KSP preconditioned resid norm 1.656718546555e-08 true resid norm
> 3.728063898356e-01 ||r(i)||/||b|| 5.892873156745e-01
> 72 KSP Residual norm 1.656718546555e-08 % max 9.756940076063e+00 min
> 1.425792038708e-03 max/min 6.843171943156e+03
> 73 KSP preconditioned resid norm 1.656661764862e-08 true resid norm
> 3.727786721034e-01 ||r(i)||/||b|| 5.892435028310e-01
> 73 KSP Residual norm 1.656661764862e-08 % max 9.756965888951e+00 min
> 1.158185964332e-03 max/min 8.424351692586e+03
> 74 KSP preconditioned resid norm 1.656636420620e-08 true resid norm
> 3.727518398420e-01 ||r(i)||/||b|| 5.892010896329e-01
> 74 KSP Residual norm 1.656636420620e-08 % max 9.757003390346e+00 min
> 9.438943306994e-04 max/min 1.033696577361e+04
> 75 KSP preconditioned resid norm 1.656520179659e-08 true resid norm
> 3.726868430624e-01 ||r(i)||/||b|| 5.890983505736e-01
> 75 KSP Residual norm 1.656520179659e-08 % max 9.757006096169e+00 min
> 7.903213567346e-04 max/min 1.234561866895e+04
> 76 KSP preconditioned resid norm 1.656424480034e-08 true resid norm
> 3.726173157679e-01 ||r(i)||/||b|| 5.889884502235e-01
> 76 KSP Residual norm 1.656424480034e-08 % max 9.757008722883e+00 min
> 6.669508794331e-04 max/min 1.462927634367e+04
> 77 KSP preconditioned resid norm 1.656223746236e-08 true resid norm
> 3.725149253621e-01 ||r(i)||/||b|| 5.888266038361e-01
> 77 KSP Residual norm 1.656223746236e-08 % max 9.757108556440e+00 min
> 5.550476575711e-04 max/min 1.757886628896e+04
> 78 KSP preconditioned resid norm 1.655570645923e-08 true resid norm
> 3.723230681871e-01 ||r(i)||/||b|| 5.885233391852e-01
> 78 KSP Residual norm 1.655570645923e-08 % max 9.757706826959e+00 min
> 4.399820830439e-04 max/min 2.217750950096e+04
> 79 KSP preconditioned resid norm 1.654641744591e-08 true resid norm
> 3.720276670884e-01 ||r(i)||/||b|| 5.880564048053e-01
> 79 KSP Residual norm 1.654641744591e-08 % max 9.794972447526e+00 min
> 3.582518455199e-04 max/min 2.734102439392e+04
> 80 KSP preconditioned resid norm 1.653478342204e-08 true resid norm
> 3.716527795590e-01 ||r(i)||/||b|| 5.874638278755e-01
> 80 KSP Residual norm 1.653478342204e-08 % max 9.836802284188e+00 min
> 3.026308703663e-04 max/min 3.250429234890e+04
> 81 KSP preconditioned resid norm 1.652174198034e-08 true resid norm
> 3.711834567643e-01 ||r(i)||/||b|| 5.867219790838e-01
> 81 KSP Residual norm 1.652174198034e-08 % max 9.856229987881e+00 min
> 2.557127305560e-04 max/min 3.854415056477e+04
> 82 KSP preconditioned resid norm 1.649703927678e-08 true resid norm
> 3.702808970873e-01 ||r(i)||/||b|| 5.852953217522e-01
> 82 KSP Residual norm 1.649703927678e-08 % max 9.865801022673e+00 min
> 2.113312927870e-04 max/min 4.668405181535e+04
> 83 KSP preconditioned resid norm 1.647272703733e-08 true resid norm
> 3.691356976009e-01 ||r(i)||/||b|| 5.834851287146e-01
> 83 KSP Residual norm 1.647272703733e-08 % max 9.870514331986e+00 min
> 1.772107156780e-04 max/min 5.569930855605e+04
> 84 KSP preconditioned resid norm 1.644833370624e-08 true resid norm
> 3.678694491788e-01 ||r(i)||/||b|| 5.814835961391e-01
> 84 KSP Residual norm 1.644833370624e-08 % max 9.875179985385e+00 min
> 1.531203216170e-04 max/min 6.449294176698e+04
> 85 KSP preconditioned resid norm 1.641503406416e-08 true resid norm
> 3.663991314975e-01 ||r(i)||/||b|| 5.791594955248e-01
> 85 KSP Residual norm 1.641503406416e-08 % max 9.878712452345e+00 min
> 1.354454765823e-04 max/min 7.293497502916e+04
> 86 KSP preconditioned resid norm 1.638631902117e-08 true resid norm
> 3.650020055391e-01 ||r(i)||/||b|| 5.769510875465e-01
> 86 KSP Residual norm 1.638631902117e-08 % max 9.884296885865e+00 min
> 1.217649759756e-04 max/min 8.117520499364e+04
> 87 KSP preconditioned resid norm 1.635837174633e-08 true resid norm
> 3.637826153071e-01 ||r(i)||/||b|| 5.750236227386e-01
> 87 KSP Residual norm 1.635837174633e-08 % max 9.888595738642e+00 min
> 1.129410821511e-04 max/min 8.755534788848e+04
> 88 KSP preconditioned resid norm 1.633085122612e-08 true resid norm
> 3.627922390431e-01 ||r(i)||/||b|| 5.734581555524e-01
> 88 KSP Residual norm 1.633085122612e-08 % max 9.892636665772e+00 min
> 1.069969658571e-04 max/min 9.245717003771e+04
> 89 KSP preconditioned resid norm 1.630349445652e-08 true resid norm
> 3.617701380674e-01 ||r(i)||/||b|| 5.718425417733e-01
> 89 KSP Residual norm 1.630349445652e-08 % max 9.895013763062e+00 min
> 1.017466157066e-04 max/min 9.725152718198e+04
> 90 KSP preconditioned resid norm 1.627361015004e-08 true resid norm
> 3.606744164091e-01 ||r(i)||/||b|| 5.701105573107e-01
> 90 KSP Residual norm 1.627361015004e-08 % max 9.896088200035e+00 min
> 9.710482756506e-05 max/min 1.019113925454e+05
> 91 KSP preconditioned resid norm 1.624399979693e-08 true resid norm
> 3.595515169218e-01 ||r(i)||/||b|| 5.683356134185e-01
> 91 KSP Residual norm 1.624399979693e-08 % max 9.898456960605e+00 min
> 9.277670680089e-05 max/min 1.066911868498e+05
> 92 KSP preconditioned resid norm 1.621187417344e-08 true resid norm
> 3.581993711865e-01 ||r(i)||/||b|| 5.661983047444e-01
> 92 KSP Residual norm 1.621187417344e-08 % max 9.900133841601e+00 min
> 8.846853223877e-05 max/min 1.119057091948e+05
> 93 KSP preconditioned resid norm 1.617899333556e-08 true resid norm
> 3.567416069788e-01 ||r(i)||/||b|| 5.638940471450e-01
> 93 KSP Residual norm 1.617899333556e-08 % max 9.903319235139e+00 min
> 8.477730005240e-05 max/min 1.168156951096e+05
> 94 KSP preconditioned resid norm 1.613800415846e-08 true resid norm
> 3.548922412073e-01 ||r(i)||/||b|| 5.609707930891e-01
> 94 KSP Residual norm 1.613800415846e-08 % max 9.906628476064e+00 min
> 8.053311577407e-05 max/min 1.230131031296e+05
> 95 KSP preconditioned resid norm 1.605124840571e-08 true resid norm
> 3.510853485394e-01 ||r(i)||/||b|| 5.549533169339e-01
> 95 KSP Residual norm 1.605124840571e-08 % max 9.909345975071e+00 min
> 7.312347368914e-05 max/min 1.355152521500e+05
> 96 KSP preconditioned resid norm 1.588326672478e-08 true resid norm
> 3.439633921057e-01 ||r(i)||/||b|| 5.436957883518e-01
> 96 KSP Residual norm 1.588326672478e-08 % max 9.911160469884e+00 min
> 6.360279448537e-05 max/min 1.558290095597e+05
> 97 KSP preconditioned resid norm 1.563012116603e-08 true resid norm
> 3.340016328594e-01 ||r(i)||/||b|| 5.279494424584e-01
> 97 KSP Residual norm 1.563012116603e-08 % max 9.912448943622e+00 min
> 5.488437852775e-05 max/min 1.806060159470e+05
> 98 KSP preconditioned resid norm 1.532053893409e-08 true resid norm
> 3.219757242443e-01 ||r(i)||/||b|| 5.089403385385e-01
> 98 KSP Residual norm 1.532053893409e-08 % max 9.912462355327e+00 min
> 4.767224242002e-05 max/min 2.079294334005e+05
> 99 KSP preconditioned resid norm 1.497377114129e-08 true resid norm
> 3.092597005441e-01 ||r(i)||/||b|| 4.888403840403e-01
> 99 KSP Residual norm 1.497377114129e-08 % max 9.912980027078e+00 min
> 4.250681360104e-05 max/min 2.332092007677e+05
> 100 KSP preconditioned resid norm 1.467327275303e-08 true resid norm
> 2.986174217023e-01 ||r(i)||/||b|| 4.720183549595e-01
> 100 KSP Residual norm 1.467327275303e-08 % max 9.912991792085e+00 min
> 3.923846350091e-05 max/min 2.526345556791e+05
> 101 KSP preconditioned resid norm 1.442486143582e-08 true resid norm
> 2.895399487479e-01 ||r(i)||/||b|| 4.576697820373e-01
> 101 KSP Residual norm 1.442486143582e-08 % max 9.913176892700e+00 min
> 3.690617907051e-05 max/min 2.686048012112e+05
> 102 KSP preconditioned resid norm 1.420878540463e-08 true resid norm
> 2.818595095401e-01 ||r(i)||/||b|| 4.455294713363e-01
> 102 KSP Residual norm 1.420878540463e-08 % max 9.913184584644e+00 min
> 3.525622450935e-05 max/min 2.811754441266e+05
> 103 KSP preconditioned resid norm 1.394867857384e-08 true resid norm
> 2.728700074720e-01 ||r(i)||/||b|| 4.313199521665e-01
> 103 KSP Residual norm 1.394867857384e-08 % max 9.913184754083e+00 min
> 3.359065177627e-05 max/min 2.951173683711e+05
> 104 KSP preconditioned resid norm 1.361967798602e-08 true resid norm
> 2.618731154865e-01 ||r(i)||/||b|| 4.139373934561e-01
> 104 KSP Residual norm 1.361967798602e-08 % max 9.913195023405e+00 min
> 3.179302216209e-05 max/min 3.118041113822e+05
> 105 KSP preconditioned resid norm 1.325728782686e-08 true resid norm
> 2.505110349419e-01 ||r(i)||/||b|| 3.959775887769e-01
> 105 KSP Residual norm 1.325728782686e-08 % max 9.913373149107e+00 min
> 3.017902902755e-05 max/min 3.284854903734e+05
> 106 KSP preconditioned resid norm 1.274686747953e-08 true resid norm
> 2.359244406376e-01 ||r(i)||/||b|| 3.729208621843e-01
> 106 KSP Residual norm 1.274686747953e-08 % max 9.913956033293e+00 min
> 2.841281476492e-05 max/min 3.489255153112e+05
> 107 KSP preconditioned resid norm 1.226462735794e-08 true resid norm
> 2.229402253412e-01 ||r(i)||/||b|| 3.523969828015e-01
> 107 KSP Residual norm 1.226462735794e-08 % max 9.914139670727e+00 min
> 2.702981177754e-05 max/min 3.667853758037e+05
> 108 KSP preconditioned resid norm 1.178822925406e-08 true resid norm
> 2.110417020056e-01 ||r(i)||/||b|| 3.335892341467e-01
> 108 KSP Residual norm 1.178822925406e-08 % max 9.914145602125e+00 min
> 2.587391774620e-05 max/min 3.831714122064e+05
> 109 KSP preconditioned resid norm 1.124711770554e-08 true resid norm
> 1.987259952756e-01 ||r(i)||/||b|| 3.141220523670e-01
> 109 KSP Residual norm 1.124711770554e-08 % max 9.914354741568e+00 min
> 2.476929124966e-05 max/min 4.002680028927e+05
> 110 KSP preconditioned resid norm 1.066970872129e-08 true resid norm
> 1.861895786153e-01 ||r(i)||/||b|| 2.943059989856e-01
> 110 KSP Residual norm 1.066970872129e-08 % max 9.914357883390e+00 min
> 2.374270452184e-05 max/min 4.175749175613e+05
> 111 KSP preconditioned resid norm 1.012599205842e-08 true resid norm
> 1.757986089120e-01 ||r(i)||/||b|| 2.778812090393e-01
> 111 KSP Residual norm 1.012599205842e-08 % max 9.914370592801e+00 min
> 2.292071171331e-05 max/min 4.325507303965e+05
> 112 KSP preconditioned resid norm 9.672164972334e-09 true resid norm
> 1.683403272714e-01 ||r(i)||/||b|| 2.660920581894e-01
> 112 KSP Residual norm 9.672164972334e-09 % max 9.914736313673e+00 min
> 2.232161659891e-05 max/min 4.441764452741e+05
> 113 KSP preconditioned resid norm 9.299198823689e-09 true resid norm
> 1.629158622006e-01 ||r(i)||/||b|| 2.575177189407e-01
> 113 KSP Residual norm 9.299198823689e-09 % max 9.914935691241e+00 min
> 2.188325766675e-05 max/min 4.530831671515e+05
> 114 KSP preconditioned resid norm 9.034077005430e-09 true resid norm
> 1.595873484943e-01 ||r(i)||/||b|| 2.522564064722e-01
> 114 KSP Residual norm 9.034077005430e-09 % max 9.914996347981e+00 min
> 2.160694766564e-05 max/min 4.588800094031e+05
> 115 KSP preconditioned resid norm 8.888865878467e-09 true resid norm
> 1.580113210268e-01 ||r(i)||/||b|| 2.497652125950e-01
> 115 KSP Residual norm 8.888865878467e-09 % max 9.915030824457e+00 min
> 2.147558458967e-05 max/min 4.616885180964e+05
> 116 KSP preconditioned resid norm 8.771135905853e-09 true resid norm
> 1.568621931485e-01 ||r(i)||/||b|| 2.479488100300e-01
> 116 KSP Residual norm 8.771135905853e-09 % max 9.915048169257e+00 min
> 2.137210965771e-05 max/min 4.639246348655e+05
> 117 KSP preconditioned resid norm 8.659171467993e-09 true resid norm
> 1.558355526791e-01 ||r(i)||/||b|| 2.463260207675e-01
> 117 KSP Residual norm 8.659171467993e-09 % max 9.915307398147e+00 min
> 2.127637945733e-05 max/min 4.660241850844e+05
> 118 KSP preconditioned resid norm 8.575179217480e-09 true resid norm
> 1.550972317778e-01 ||r(i)||/||b|| 2.451589722568e-01
> 118 KSP Residual norm 8.575179217480e-09 % max 9.916072938441e+00 min
> 2.121014916472e-05 max/min 4.675154739098e+05
> 119 KSP preconditioned resid norm 8.518079720132e-09 true resid norm
> 1.544593367397e-01 ||r(i)||/||b|| 2.441506648218e-01
> 119 KSP Residual norm 8.518079720132e-09 % max 9.916686583796e+00 min
> 2.115333030509e-05 max/min 4.688002522897e+05
> 120 KSP preconditioned resid norm 8.478238591051e-09 true resid norm
> 1.539772069403e-01 ||r(i)||/||b|| 2.433885722637e-01
> 120 KSP Residual norm 8.478238591051e-09 % max 9.916686588373e+00 min
> 2.111527934504e-05 max/min 4.696450577957e+05
> 121 KSP preconditioned resid norm 8.444941671542e-09 true resid norm
> 1.535936004591e-01 ||r(i)||/||b|| 2.427822134680e-01
> 121 KSP Residual norm 8.444941671542e-09 % max 9.916688169159e+00 min
> 2.108428257901e-05 max/min 4.703355749478e+05
> 122 KSP preconditioned resid norm 8.427676435678e-09 true resid norm
> 1.533605832162e-01 ||r(i)||/||b|| 2.424138879530e-01
> 122 KSP Residual norm 8.427676435678e-09 % max 9.916689320407e+00 min
> 2.106414747089e-05 max/min 4.707852209122e+05
> 123 KSP preconditioned resid norm 8.415410922025e-09 true resid norm
> 1.532305930189e-01 ||r(i)||/||b|| 2.422084151485e-01
> 123 KSP Residual norm 8.415410922025e-09 % max 9.917057372015e+00 min
> 2.105353113559e-05 max/min 4.710400981264e+05
> 124 KSP preconditioned resid norm 8.408154019827e-09 true resid norm
> 1.531806523846e-01 ||r(i)||/||b|| 2.421294750254e-01
> 124 KSP Residual norm 8.408154019827e-09 % max 9.917120919215e+00 min
> 2.104834192197e-05 max/min 4.711592464612e+05
> 125 KSP preconditioned resid norm 8.393802244658e-09 true resid norm
> 1.530793493932e-01 ||r(i)||/||b|| 2.419693474913e-01
> 125 KSP Residual norm 8.393802244658e-09 % max 9.917132534500e+00 min
> 2.103675625602e-05 max/min 4.714192822224e+05
> 126 KSP preconditioned resid norm 8.379753801792e-09 true resid norm
> 1.529688114683e-01 ||r(i)||/||b|| 2.417946224898e-01
> 126 KSP Residual norm 8.379753801792e-09 % max 9.917431785146e+00 min
> 2.102585361587e-05 max/min 4.716779621095e+05
> 127 KSP preconditioned resid norm 8.371571974323e-09 true resid norm
> 1.528853003941e-01 ||r(i)||/||b|| 2.416626182697e-01
> 127 KSP Residual norm 8.371571974323e-09 % max 9.917505129146e+00 min
> 2.101791298538e-05 max/min 4.718596530514e+05
> 128 KSP preconditioned resid norm 8.367539460475e-09 true resid norm
> 1.528216413116e-01 ||r(i)||/||b|| 2.415619936803e-01
> 128 KSP Residual norm 8.367539460475e-09 % max 9.917526993547e+00 min
> 2.101234223878e-05 max/min 4.719857920096e+05
> 129 KSP preconditioned resid norm 8.356446303986e-09 true resid norm
> 1.526541189646e-01 ||r(i)||/||b|| 2.412971945866e-01
> 129 KSP Residual norm 8.356446303986e-09 % max 9.917537226333e+00 min
> 2.099928136381e-05 max/min 4.722798392247e+05
> 130 KSP preconditioned resid norm 8.331561543348e-09 true resid norm
> 1.523523830474e-01 ||r(i)||/||b|| 2.408202468906e-01
> 130 KSP Residual norm 8.331561543348e-09 % max 9.917571522876e+00 min
> 2.097331245945e-05 max/min 4.728662457134e+05
> 131 KSP preconditioned resid norm 8.300069240991e-09 true resid norm
> 1.520236092506e-01 ||r(i)||/||b|| 2.403005609800e-01
> 131 KSP Residual norm 8.300069240991e-09 % max 9.917634344282e+00 min
> 2.094526077576e-05 max/min 4.735025479253e+05
> 132 KSP preconditioned resid norm 8.273052072454e-09 true resid norm
> 1.517967993701e-01 ||r(i)||/||b|| 2.399420473136e-01
> 132 KSP Residual norm 8.273052072454e-09 % max 9.917715776764e+00 min
> 2.092540881867e-05 max/min 4.739556518445e+05
> 133 KSP preconditioned resid norm 8.251281894079e-09 true resid norm
> 1.516304506087e-01 ||r(i)||/||b|| 2.396791032823e-01
> 133 KSP Residual norm 8.251281894079e-09 % max 9.917715781180e+00 min
> 2.090929722571e-05 max/min 4.743208570868e+05
> 134 KSP preconditioned resid norm 8.226033728737e-09 true resid norm
> 1.514349562547e-01 ||r(i)||/||b|| 2.393700894181e-01
> 134 KSP Residual norm 8.226033728737e-09 % max 9.917731867345e+00 min
> 2.089015001649e-05 max/min 4.747563736744e+05
> 135 KSP preconditioned resid norm 8.199286605060e-09 true resid norm
> 1.512447576528e-01 ||r(i)||/||b|| 2.390694464393e-01
> 135 KSP Residual norm 8.199286605060e-09 % max 9.917748489841e+00 min
> 2.087043434554e-05 max/min 4.752056581880e+05
> 136 KSP preconditioned resid norm 8.180296594388e-09 true resid norm
> 1.510479857878e-01 ||r(i)||/||b|| 2.387584132402e-01
> 136 KSP Residual norm 8.180296594388e-09 % max 9.917785029298e+00 min
> 2.085325140445e-05 max/min 4.755989767228e+05
> 137 KSP preconditioned resid norm 8.169264503348e-09 true resid norm
> 1.509040950747e-01 ||r(i)||/||b|| 2.385309681792e-01
> 137 KSP Residual norm 8.169264503348e-09 % max 9.917785730737e+00 min
> 2.084031855443e-05 max/min 4.758941522334e+05
> 138 KSP preconditioned resid norm 8.156637560480e-09 true resid norm
> 1.507559867333e-01 ||r(i)||/||b|| 2.382968564007e-01
> 138 KSP Residual norm 8.156637560480e-09 % max 9.917796791468e+00 min
> 2.082708164521e-05 max/min 4.761971437199e+05
> 139 KSP preconditioned resid norm 8.146852248061e-09 true resid norm
> 1.506511059489e-01 ||r(i)||/||b|| 2.381310735237e-01
> 139 KSP Residual norm 8.146852248061e-09 % max 9.917821676165e+00 min
> 2.081598847234e-05 max/min 4.764521122473e+05
> 140 KSP preconditioned resid norm 8.141191465029e-09 true resid norm
> 1.505854905603e-01 ||r(i)||/||b|| 2.380273566420e-01
> 140 KSP Residual norm 8.141191465029e-09 % max 9.917845903968e+00 min
> 2.080955754602e-05 max/min 4.766005179128e+05
> 141 KSP preconditioned resid norm 8.138923553302e-09 true resid norm
> 1.505722123545e-01 ||r(i)||/||b|| 2.380063680578e-01
> 141 KSP Residual norm 8.138923553302e-09 % max 9.917872635574e+00 min
> 2.080833075673e-05 max/min 4.766299013373e+05
> 142 KSP preconditioned resid norm 8.133951815022e-09 true resid norm
> 1.505617094662e-01 ||r(i)||/||b|| 2.379897663606e-01
> 142 KSP Residual norm 8.133951815022e-09 % max 9.917872952600e+00 min
> 2.080597338078e-05 max/min 4.766839200977e+05
> 143 KSP preconditioned resid norm 8.130475958447e-09 true resid norm
> 1.505390404850e-01 ||r(i)||/||b|| 2.379539339729e-01
> 143 KSP Residual norm 8.130475958447e-09 % max 9.917874128718e+00 min
> 2.080394570826e-05 max/min 4.767304369950e+05
> 144 KSP preconditioned resid norm 8.128953889987e-09 true resid norm
> 1.505364291420e-01 ||r(i)||/||b|| 2.379498062773e-01
> 144 KSP Residual norm 8.128953889987e-09 % max 9.917915384229e+00 min
> 2.080337902646e-05 max/min 4.767454061966e+05
> 145 KSP preconditioned resid norm 8.128697515577e-09 true resid norm
> 1.505360974540e-01 ||r(i)||/||b|| 2.379492819850e-01
> 145 KSP Residual norm 8.128697515577e-09 % max 9.917928714401e+00 min
> 2.080337467554e-05 max/min 4.767461466750e+05
> 146 KSP preconditioned resid norm 8.128385333914e-09 true resid norm
> 1.505304085835e-01 ||r(i)||/||b|| 2.379402897056e-01
> 146 KSP Residual norm 8.128385333914e-09 % max 9.918146741049e+00 min
> 2.080294082776e-05 max/min 4.767665698407e+05
> 147 KSP preconditioned resid norm 8.127949324855e-09 true resid norm
> 1.505226583248e-01 ||r(i)||/||b|| 2.379280390325e-01
> 147 KSP Residual norm 8.127949324855e-09 % max 9.918156051888e+00 min
> 2.080250556219e-05 max/min 4.767769931482e+05
> 148 KSP preconditioned resid norm 8.126892921741e-09 true resid norm
> 1.505086679169e-01 ||r(i)||/||b|| 2.379059246855e-01
> 148 KSP Residual norm 8.126892921741e-09 % max 9.918171317513e+00 min
> 2.080184752072e-05 max/min 4.767928092749e+05
> 149 KSP preconditioned resid norm 8.125786411061e-09 true resid norm
> 1.504901877800e-01 ||r(i)||/||b|| 2.378767135170e-01
> 149 KSP Residual norm 8.125786411061e-09 % max 9.918205450251e+00 min
> 2.080029672887e-05 max/min 4.768299981263e+05
> 150 KSP preconditioned resid norm 8.121865705516e-09 true resid norm
> 1.504379984469e-01 ||r(i)||/||b|| 2.377942189223e-01
> 150 KSP Residual norm 8.121865705516e-09 % max 9.918295492207e+00 min
> 2.079653971654e-05 max/min 4.769204698183e+05
> 151 KSP preconditioned resid norm 8.114591200267e-09 true resid norm
> 1.503744219252e-01 ||r(i)||/||b|| 2.376937248352e-01
> 151 KSP Residual norm 8.114591200267e-09 % max 9.918302707337e+00 min
> 2.079103745413e-05 max/min 4.770470318867e+05
> 152 KSP preconditioned resid norm 8.108201162281e-09 true resid norm
> 1.503020846718e-01 ||r(i)||/||b|| 2.375793828416e-01
> 152 KSP Residual norm 8.108201162281e-09 % max 9.918303753789e+00 min
> 2.078516129771e-05 max/min 4.771819478198e+05
> 153 KSP preconditioned resid norm 8.102490482870e-09 true resid norm
> 1.502240682865e-01 ||r(i)||/||b|| 2.374560639621e-01
> 153 KSP Residual norm 8.102490482870e-09 % max 9.918303965254e+00 min
> 2.077946249056e-05 max/min 4.773128260541e+05
> 154 KSP preconditioned resid norm 8.087174026596e-09 true resid norm
> 1.500412418392e-01 ||r(i)||/||b|| 2.371670739948e-01
> 154 KSP Residual norm 8.087174026596e-09 % max 9.918315546883e+00 min
> 2.076640155913e-05 max/min 4.776135874404e+05
> 155 KSP preconditioned resid norm 8.057393656065e-09 true resid norm
> 1.496423828383e-01 ||r(i)||/||b|| 2.365366058580e-01
> 155 KSP Residual norm 8.057393656065e-09 % max 9.918465324870e+00 min
> 2.073545587686e-05 max/min 4.783336032625e+05
> 156 KSP preconditioned resid norm 8.011693187532e-09 true resid norm
> 1.490284191223e-01 ||r(i)||/||b|| 2.355661261668e-01
> 156 KSP Residual norm 8.011693187532e-09 % max 9.918466288675e+00 min
> 2.068954861804e-05 max/min 4.793950062316e+05
> 157 KSP preconditioned resid norm 7.959013340300e-09 true resid norm
> 1.483574761823e-01 ||r(i)||/||b|| 2.345055805998e-01
> 157 KSP Residual norm 7.959013340300e-09 % max 9.918561932305e+00 min
> 2.064150405350e-05 max/min 4.805154656656e+05
> 158 KSP preconditioned resid norm 7.894240455844e-09 true resid norm
> 1.476088146004e-01 ||r(i)||/||b|| 2.333221867900e-01
> 158 KSP Residual norm 7.894240455844e-09 % max 9.918657124651e+00 min
> 2.058238758689e-05 max/min 4.819002208941e+05
> 159 KSP preconditioned resid norm 7.812904666749e-09 true resid norm
> 1.467208127766e-01 ||r(i)||/||b|| 2.319185407546e-01
> 159 KSP Residual norm 7.812904666749e-09 % max 9.919093811117e+00 min
> 2.051599215020e-05 max/min 4.834810687437e+05
> 160 KSP preconditioned resid norm 7.741530539562e-09 true resid norm
> 1.459917281627e-01 ||r(i)||/||b|| 2.307660918517e-01
> 160 KSP Residual norm 7.741530539562e-09 % max 9.919095332651e+00 min
> 2.045886641493e-05 max/min 4.848311304977e+05
> 161 KSP preconditioned resid norm 7.676609426916e-09 true resid norm
> 1.453051987717e-01 ||r(i)||/||b|| 2.296809091053e-01
> 161 KSP Residual norm 7.676609426916e-09 % max 9.919292102450e+00 min
> 2.040917630477e-05 max/min 4.860211874465e+05
> 162 KSP preconditioned resid norm 7.583530085636e-09 true resid norm
> 1.443036525464e-01 ||r(i)||/||b|| 2.280977857933e-01
> 162 KSP Residual norm 7.583530085636e-09 % max 9.919308484025e+00 min
> 2.033498476484e-05 max/min 4.877952257517e+05
> 163 KSP preconditioned resid norm 7.467692143507e-09 true resid norm
> 1.429522123636e-01 ||r(i)||/||b|| 2.259615923713e-01
> 163 KSP Residual norm 7.467692143507e-09 % max 9.919855464029e+00 min
> 2.024129556919e-05 max/min 4.900800657804e+05
> 164 KSP preconditioned resid norm 7.327851148024e-09 true resid norm
> 1.414046163109e-01 ||r(i)||/||b|| 2.235153394408e-01
> 164 KSP Residual norm 7.327851148024e-09 % max 9.920253012186e+00 min
> 2.012547547329e-05 max/min 4.929201809594e+05
> 165 KSP preconditioned resid norm 7.152579465113e-09 true resid norm
> 1.394666900679e-01 ||r(i)||/||b|| 2.204520996873e-01
> 165 KSP Residual norm 7.152579465113e-09 % max 9.920271087623e+00 min
> 1.998671358111e-05 max/min 4.963432856214e+05
> 166 KSP preconditioned resid norm 6.938769833629e-09 true resid norm
> 1.370973027073e-01 ||r(i)||/||b|| 2.167068583084e-01
> 166 KSP Residual norm 6.938769833629e-09 % max 9.920293566357e+00 min
> 1.981527794098e-05 max/min 5.006386282295e+05
> 167 KSP preconditioned resid norm 6.741207402281e-09 true resid norm
> 1.351840392321e-01 ||r(i)||/||b|| 2.136826024797e-01
> 167 KSP Residual norm 6.741207402281e-09 % max 9.920596954025e+00 min
> 1.967349814668e-05 max/min 5.042619711075e+05
> 168 KSP preconditioned resid norm 6.565143103123e-09 true resid norm
> 1.336623889818e-01 ||r(i)||/||b|| 2.112773615401e-01
> 168 KSP Residual norm 6.565143103123e-09 % max 9.921114523994e+00 min
> 1.956018369412e-05 max/min 5.072096806011e+05
> 169 KSP preconditioned resid norm 6.429632478813e-09 true resid norm
> 1.325320084241e-01 ||r(i)||/||b|| 2.094905924751e-01
> 169 KSP Residual norm 6.429632478813e-09 % max 9.921249706269e+00 min
> 1.947508804310e-05 max/min 5.094328551589e+05
> 170 KSP preconditioned resid norm 6.351340021846e-09 true resid norm
> 1.319352335272e-01 ||r(i)||/||b|| 2.085472827931e-01
> 170 KSP Residual norm 6.351340021846e-09 % max 9.921400860428e+00 min
> 1.943209479700e-05 max/min 5.105677470224e+05
> 171 KSP preconditioned resid norm 6.305273930969e-09 true resid norm
> 1.315826886900e-01 ||r(i)||/||b|| 2.079900224928e-01
> 171 KSP Residual norm 6.305273930969e-09 % max 9.921731787878e+00 min
> 1.940477171363e-05 max/min 5.113037109789e+05
> 172 KSP preconditioned resid norm 6.279015387005e-09 true resid norm
> 1.313487942570e-01 ||r(i)||/||b|| 2.076203104216e-01
> 172 KSP Residual norm 6.279015387005e-09 % max 9.922029289988e+00 min
> 1.939038385409e-05 max/min 5.116984462324e+05
> 173 KSP preconditioned resid norm 6.254268607814e-09 true resid norm
> 1.311057590476e-01 ||r(i)||/||b|| 2.072361497149e-01
> 173 KSP Residual norm 6.254268607814e-09 % max 9.922081473522e+00 min
> 1.937353844196e-05 max/min 5.121460647596e+05
> 174 KSP preconditioned resid norm 6.237354310290e-09 true resid norm
> 1.308928887713e-01 ||r(i)||/||b|| 2.068996700913e-01
> 174 KSP Residual norm 6.237354310290e-09 % max 9.922086586645e+00 min
> 1.935976905538e-05 max/min 5.125105861678e+05
> 175 KSP preconditioned resid norm 6.228697463260e-09 true resid norm
> 1.307776586248e-01 ||r(i)||/||b|| 2.067175281925e-01
> 175 KSP Residual norm 6.228697463260e-09 % max 9.922153120984e+00 min
> 1.935153803598e-05 max/min 5.127320165733e+05
> 176 KSP preconditioned resid norm 6.224066688220e-09 true resid norm
> 1.307217422786e-01 ||r(i)||/||b|| 2.066291423857e-01
> 176 KSP Residual norm 6.224066688220e-09 % max 9.922168914276e+00 min
> 1.934716877667e-05 max/min 5.128486254920e+05
> 177 KSP preconditioned resid norm 6.218867118158e-09 true resid norm
> 1.306556581492e-01 ||r(i)||/||b|| 2.065246845753e-01
> 177 KSP Residual norm 6.218867118158e-09 % max 9.922226850895e+00 min
> 1.934272085613e-05 max/min 5.129695519413e+05
> 178 KSP preconditioned resid norm 6.214644508175e-09 true resid norm
> 1.306129149611e-01 ||r(i)||/||b|| 2.064571213057e-01
> 178 KSP Residual norm 6.214644508175e-09 % max 9.922355708265e+00 min
> 1.933886017403e-05 max/min 5.130786209205e+05
> 179 KSP preconditioned resid norm 6.212855197040e-09 true resid norm
> 1.305891120840e-01 ||r(i)||/||b|| 2.064194965924e-01
> 179 KSP Residual norm 6.212855197040e-09 % max 9.922451375570e+00 min
> 1.933749030032e-05 max/min 5.131199148117e+05
> 180 KSP preconditioned resid norm 6.212625281595e-09 true resid norm
> 1.305842539484e-01 ||r(i)||/||b|| 2.064118174383e-01
> 180 KSP Residual norm 6.212625281595e-09 % max 9.922736461793e+00 min
> 1.933715169437e-05 max/min 5.131436427984e+05
> 181 KSP preconditioned resid norm 6.212400733084e-09 true resid norm
> 1.305772830113e-01 ||r(i)||/||b|| 2.064007986230e-01
> 181 KSP Residual norm 6.212400733084e-09 % max 9.923063598858e+00 min
> 1.933684249949e-05 max/min 5.131687657444e+05
> 182 KSP preconditioned resid norm 6.212071952354e-09 true resid norm
> 1.305684442926e-01 ||r(i)||/||b|| 2.063868274438e-01
> 182 KSP Residual norm 6.212071952354e-09 % max 9.923063744763e+00 min
> 1.933594544036e-05 max/min 5.131925809044e+05
> 183 KSP preconditioned resid norm 6.211566094656e-09 true resid norm
> 1.305591570573e-01 ||r(i)||/||b|| 2.063721473039e-01
> 183 KSP Residual norm 6.211566094656e-09 % max 9.923141089945e+00 min
> 1.933537478778e-05 max/min 5.132117271509e+05
> 184 KSP preconditioned resid norm 6.210461787001e-09 true resid norm
> 1.305375085549e-01 ||r(i)||/||b|| 2.063379279660e-01
> 184 KSP Residual norm 6.210461787001e-09 % max 9.923201283329e+00 min
> 1.933367383203e-05 max/min 5.132599923606e+05
> 185 KSP preconditioned resid norm 6.209143778669e-09 true resid norm
> 1.305127223575e-01 ||r(i)||/||b|| 2.062987489387e-01
> 185 KSP Residual norm 6.209143778669e-09 % max 9.923212917908e+00 min
> 1.933144232370e-05 max/min 5.133198419313e+05
> 186 KSP preconditioned resid norm 6.208771445688e-09 true resid norm
> 1.305097304722e-01 ||r(i)||/||b|| 2.062940197276e-01
> 186 KSP Residual norm 6.208771445688e-09 % max 9.923281135224e+00 min
> 1.933117841583e-05 max/min 5.133303786126e+05
> 187 KSP preconditioned resid norm 6.208512520426e-09 true resid norm
> 1.305036180825e-01 ||r(i)||/||b|| 2.062843580003e-01
> 187 KSP Residual norm 6.208512520426e-09 % max 9.923314434905e+00 min
> 1.933056167219e-05 max/min 5.133484791174e+05
> 188 KSP preconditioned resid norm 6.207066981762e-09 true resid norm
> 1.304777614033e-01 ||r(i)||/||b|| 2.062434868846e-01
> 188 KSP Residual norm 6.207066981762e-09 % max 9.923347740518e+00 min
> 1.932866808571e-05 max/min 5.134004938424e+05
> 189 KSP preconditioned resid norm 6.204934149804e-09 true resid norm
> 1.304392715020e-01 ||r(i)||/||b|| 2.061826466973e-01
> 189 KSP Residual norm 6.204934149804e-09 % max 9.923362596625e+00 min
> 1.932574598338e-05 max/min 5.134788900339e+05
> 190 KSP preconditioned resid norm 6.204155842095e-09 true resid norm
> 1.304126326631e-01 ||r(i)||/||b|| 2.061405392380e-01
> 190 KSP Residual norm 6.204155842095e-09 % max 9.923514343512e+00 min
> 1.932412287621e-05 max/min 5.135298718127e+05
> 191 KSP preconditioned resid norm 6.203518614933e-09 true resid norm
> 1.303882235745e-01 ||r(i)||/||b|| 2.061019562988e-01
> 191 KSP Residual norm 6.203518614933e-09 % max 9.923630839564e+00 min
> 1.932179761687e-05 max/min 5.135977012253e+05
> 192 KSP preconditioned resid norm 6.201048863957e-09 true resid norm
> 1.303177921103e-01 ||r(i)||/||b|| 2.059906267464e-01
> 192 KSP Residual norm 6.201048863957e-09 % max 9.923652649804e+00 min
> 1.931812341897e-05 max/min 5.136965136096e+05
> 193 KSP preconditioned resid norm 6.192716632256e-09 true resid norm
> 1.301249902732e-01 ||r(i)||/||b|| 2.056858688878e-01
> 193 KSP Residual norm 6.192716632256e-09 % max 9.923855558469e+00 min
> 1.930707285429e-05 max/min 5.140010416578e+05
> 194 KSP preconditioned resid norm 6.181798841032e-09 true resid norm
> 1.298629857002e-01 ||r(i)||/||b|| 2.052717237022e-01
> 194 KSP Residual norm 6.181798841032e-09 % max 9.924185498149e+00 min
> 1.929298985847e-05 max/min 5.143933403247e+05
> 195 KSP preconditioned resid norm 6.171531561212e-09 true resid norm
> 1.295856208773e-01 ||r(i)||/||b|| 2.048332988886e-01
> 195 KSP Residual norm 6.171531561212e-09 % max 9.924254204639e+00 min
> 1.928113063039e-05 max/min 5.147132911902e+05
> 196 KSP preconditioned resid norm 6.153444479612e-09 true resid norm
> 1.291447908864e-01 ||r(i)||/||b|| 2.041364880798e-01
> 196 KSP Residual norm 6.153444479612e-09 % max 9.924316134490e+00 min
> 1.926027722186e-05 max/min 5.152737948769e+05
> 197 KSP preconditioned resid norm 6.119723945157e-09 true resid norm
> 1.283308296537e-01 ||r(i)||/||b|| 2.028498764687e-01
> 197 KSP Residual norm 6.119723945157e-09 % max 9.924316422607e+00 min
> 1.922390011138e-05 max/min 5.162488550767e+05
> 198 KSP preconditioned resid norm 6.067997285763e-09 true resid norm
> 1.271271480671e-01 ||r(i)||/||b|| 2.009472419903e-01
> 198 KSP Residual norm 6.067997285763e-09 % max 9.924442950178e+00 min
> 1.916694880677e-05 max/min 5.177894014447e+05
> 199 KSP preconditioned resid norm 6.004429863992e-09 true resid norm
> 1.256627003698e-01 ||r(i)||/||b|| 1.986324199378e-01
> 199 KSP Residual norm 6.004429863992e-09 % max 9.924866956836e+00 min
> 1.909406330276e-05 max/min 5.197881037403e+05
> 200 KSP preconditioned resid norm 5.934094254933e-09 true resid norm
> 1.240250400661e-01 ||r(i)||/||b|| 1.960438043167e-01
> 200 KSP Residual norm 5.934094254933e-09 % max 9.924973873650e+00 min
> 1.900999030530e-05 max/min 5.220925268374e+05
> 201 KSP preconditioned resid norm 5.851144210814e-09 true resid norm
> 1.220942283818e-01 ||r(i)||/||b|| 1.929918103984e-01
> 201 KSP Residual norm 5.851144210814e-09 % max 9.925050713110e+00 min
> 1.890466927565e-05 max/min 5.250052549660e+05
> 202 KSP preconditioned resid norm 5.765248380990e-09 true resid norm
> 1.201835481423e-01 ||r(i)||/||b|| 1.899716378366e-01
> 202 KSP Residual norm 5.765248380990e-09 % max 9.925088925004e+00 min
> 1.879800779681e-05 max/min 5.279862117458e+05
> 203 KSP preconditioned resid norm 5.682453748888e-09 true resid norm
> 1.183002353836e-01 ||r(i)||/||b|| 1.869947244831e-01
> 203 KSP Residual norm 5.682453748888e-09 % max 9.925585994328e+00 min
> 1.868987652967e-05 max/min 5.310674994866e+05
> 204 KSP preconditioned resid norm 5.601209052384e-09 true resid norm
> 1.165424983140e-01 ||r(i)||/||b|| 1.842163060127e-01
> 204 KSP Residual norm 5.601209052384e-09 % max 9.926813616373e+00 min
> 1.859493580288e-05 max/min 5.338450060600e+05
> 205 KSP preconditioned resid norm 5.518585052549e-09 true resid norm
> 1.147552536083e-01 ||r(i)||/||b|| 1.813912454350e-01
> 205 KSP Residual norm 5.518585052549e-09 % max 9.927547139863e+00 min
> 1.849785740830e-05 max/min 5.366863264612e+05
> 206 KSP preconditioned resid norm 5.403946681825e-09 true resid norm
> 1.122288671650e-01 ||r(i)||/||b|| 1.773978388675e-01
> 206 KSP Residual norm 5.403946681825e-09 % max 9.927598607359e+00 min
> 1.836227794968e-05 max/min 5.406517990068e+05
> 207 KSP preconditioned resid norm 5.279599429018e-09 true resid norm
> 1.096186442675e-01 ||r(i)||/||b|| 1.732719137586e-01
> 207 KSP Residual norm 5.279599429018e-09 % max 9.928135298387e+00 min
> 1.822407087542e-05 max/min 5.447814248670e+05
> 208 KSP preconditioned resid norm 5.196372449667e-09 true resid norm
> 1.079356390651e-01 ||r(i)||/||b|| 1.706116223982e-01
> 208 KSP Residual norm 5.196372449667e-09 % max 9.929022382947e+00 min
> 1.813084812731e-05 max/min 5.476314352879e+05
> 209 KSP preconditioned resid norm 5.126109765538e-09 true resid norm
> 1.065191875250e-01 ||r(i)||/||b|| 1.683726668744e-01
> 209 KSP Residual norm 5.126109765538e-09 % max 9.929797496117e+00 min
> 1.805154321094e-05 max/min 5.500802551939e+05
> 210 KSP preconditioned resid norm 5.077403106475e-09 true resid norm
> 1.055994890106e-01 ||r(i)||/||b|| 1.669189185387e-01
> 210 KSP Residual norm 5.077403106475e-09 % max 9.930393445658e+00 min
> 1.799779398678e-05 max/min 5.517561459451e+05
> 211 KSP preconditioned resid norm 5.044178538989e-09 true resid norm
> 1.049755475719e-01 ||r(i)||/||b|| 1.659326672683e-01
> 211 KSP Residual norm 5.044178538989e-09 % max 9.930465924340e+00 min
> 1.796091021169e-05 max/min 5.528932446795e+05
> 212 KSP preconditioned resid norm 5.020571485059e-09 true resid norm
> 1.045258936180e-01 ||r(i)||/||b|| 1.652219086046e-01
> 212 KSP Residual norm 5.020571485059e-09 % max 9.930491351737e+00 min
> 1.793154500597e-05 max/min 5.538000963347e+05
> 213 KSP preconditioned resid norm 5.006825891577e-09 true resid norm
> 1.042955061868e-01 ||r(i)||/||b|| 1.648577399783e-01
> 213 KSP Residual norm 5.006825891577e-09 % max 9.930514884346e+00 min
> 1.791642205643e-05 max/min 5.542688631173e+05
> 214 KSP preconditioned resid norm 4.994301057584e-09 true resid norm
> 1.040932063678e-01 ||r(i)||/||b|| 1.645379688570e-01
> 214 KSP Residual norm 4.994301057584e-09 % max 9.930647907797e+00 min
> 1.790225819785e-05 max/min 5.547148185467e+05
> 215 KSP preconditioned resid norm 4.977855514222e-09 true resid norm
> 1.038198654095e-01 ||r(i)||/||b|| 1.641059044826e-01
> 215 KSP Residual norm 4.977855514222e-09 % max 9.930666016381e+00 min
> 1.788110391402e-05 max/min 5.553720879947e+05
> 216 KSP preconditioned resid norm 4.964348988837e-09 true resid norm
> 1.036080455604e-01 ||r(i)||/||b|| 1.637710852474e-01
> 216 KSP Residual norm 4.964348988837e-09 % max 9.930679455140e+00 min
> 1.786718726800e-05 max/min 5.558054161622e+05
> 217 KSP preconditioned resid norm 4.956200770500e-09 true resid norm
> 1.035069953035e-01 ||r(i)||/||b|| 1.636113572057e-01
> 217 KSP Residual norm 4.956200770500e-09 % max 9.930689869541e+00 min
> 1.785815278053e-05 max/min 5.560871827891e+05
> 218 KSP preconditioned resid norm 4.950534860249e-09 true resid norm
> 1.034473981952e-01 ||r(i)||/||b|| 1.635171532945e-01
> 218 KSP Residual norm 4.950534860249e-09 % max 9.930984291908e+00 min
> 1.785402053178e-05 max/min 5.562323777005e+05
> 219 KSP preconditioned resid norm 4.942975355172e-09 true resid norm
> 1.033459997641e-01 ||r(i)||/||b|| 1.633568749011e-01
> 219 KSP Residual norm 4.942975355172e-09 % max 9.931699409621e+00 min
> 1.784719695142e-05 max/min 5.564851128529e+05
> 220 KSP preconditioned resid norm 4.931006016804e-09 true resid norm
> 1.031436045505e-01 ||r(i)||/||b|| 1.630369529915e-01
> 220 KSP Residual norm 4.931006016804e-09 % max 9.931710539777e+00 min
> 1.783542753853e-05 max/min 5.568529556311e+05
> 221 KSP preconditioned resid norm 4.918043165591e-09 true resid norm
> 1.029101140458e-01 ||r(i)||/||b|| 1.626678794013e-01
> 221 KSP Residual norm 4.918043165591e-09 % max 9.931745055666e+00 min
> 1.782321540888e-05 max/min 5.572364372995e+05
> 222 KSP preconditioned resid norm 4.897513457279e-09 true resid norm
> 1.025741649722e-01 ||r(i)||/||b|| 1.621368516797e-01
> 222 KSP Residual norm 4.897513457279e-09 % max 9.931805660966e+00 min
> 1.780346830739e-05 max/min 5.578579122612e+05
> 223 KSP preconditioned resid norm 4.860092454927e-09 true resid norm
> 1.019662024304e-01 ||r(i)||/||b|| 1.611758579198e-01
> 223 KSP Residual norm 4.860092454927e-09 % max 9.932464226880e+00 min
> 1.776986772785e-05 max/min 5.589498120639e+05
> 224 KSP preconditioned resid norm 4.769160522417e-09 true resid norm
> 1.004448198639e-01 ||r(i)||/||b|| 1.587710401024e-01
> 224 KSP Residual norm 4.769160522417e-09 % max 9.933920635368e+00 min
> 1.767636423838e-05 max/min 5.619889079792e+05
> 225 KSP preconditioned resid norm 4.634557449537e-09 true resid norm
> 9.826212202717e-02 ||r(i)||/||b|| 1.553208949755e-01
> 225 KSP Residual norm 4.634557449537e-09 % max 9.935080165032e+00 min
> 1.754021072797e-05 max/min 5.664173777106e+05
> 226 KSP preconditioned resid norm 4.491782226584e-09 true resid norm
> 9.619719506576e-02 ||r(i)||/||b|| 1.520569078248e-01
> 226 KSP Residual norm 4.491782226584e-09 % max 9.937326276961e+00 min
> 1.739963797630e-05 max/min 5.711225883262e+05
> 227 KSP preconditioned resid norm 4.362133112512e-09 true resid norm
> 9.441389210582e-02 ||r(i)||/||b|| 1.492380778826e-01
> 227 KSP Residual norm 4.362133112512e-09 % max 9.946120307410e+00 min
> 1.727701416548e-05 max/min 5.756851393504e+05
> 228 KSP preconditioned resid norm 4.225957340088e-09 true resid norm
> 9.265275503217e-02 ||r(i)||/||b|| 1.464542850964e-01
> 228 KSP Residual norm 4.225957340088e-09 % max 9.985645498795e+00 min
> 1.715055176814e-05 max/min 5.822346495782e+05
> 229 KSP preconditioned resid norm 4.092962778807e-09 true resid norm
> 9.106715798430e-02 ||r(i)||/||b|| 1.439479647823e-01
> 229 KSP Residual norm 4.092962778807e-09 % max 1.012393782405e+01 min
> 1.703438299138e-05 max/min 5.943237174583e+05
> 230 KSP preconditioned resid norm 3.953159424001e-09 true resid norm
> 8.949933715671e-02 ||r(i)||/||b|| 1.414697429703e-01
> 230 KSP Residual norm 3.953159424001e-09 % max 1.034103229999e+01 min
> 1.691398442562e-05 max/min 6.113894892986e+05
> 231 KSP preconditioned resid norm 3.819537372036e-09 true resid norm
> 8.813823667573e-02 ||r(i)||/||b|| 1.393182797157e-01
> 231 KSP Residual norm 3.819537372036e-09 % max 1.059220161526e+01 min
> 1.680354842788e-05 max/min 6.303550503468e+05
> 232 KSP preconditioned resid norm 3.693790673013e-09 true resid norm
> 8.693612541781e-02 ||r(i)||/||b|| 1.374181274232e-01
> 232 KSP Residual norm 3.693790673013e-09 % max 1.086546283828e+01 min
> 1.670426209107e-05 max/min 6.504605099612e+05
> 233 KSP preconditioned resid norm 3.570890771949e-09 true resid norm
> 8.586106485480e-02 ||r(i)||/||b|| 1.357188015247e-01
> 233 KSP Residual norm 3.570890771949e-09 % max 1.117129763635e+01 min
> 1.660960311863e-05 max/min 6.725806484697e+05
> 234 KSP preconditioned resid norm 3.457471830300e-09 true resid norm
> 8.494167552889e-02 ||r(i)||/||b|| 1.342655419168e-01
> 234 KSP Residual norm 3.457471830300e-09 % max 1.149605765262e+01 min
> 1.652670056090e-05 max/min 6.956051276091e+05
> 235 KSP preconditioned resid norm 3.349671536188e-09 true resid norm
> 8.413008092747e-02 ||r(i)||/||b|| 1.329826711905e-01
> 235 KSP Residual norm 3.349671536188e-09 % max 1.186263512521e+01 min
> 1.644950134682e-05 max/min 7.211546949117e+05
> 236 KSP preconditioned resid norm 3.250181079812e-09 true resid norm
> 8.343835240331e-02 ||r(i)||/||b|| 1.318892702824e-01
> 236 KSP Residual norm 3.250181079812e-09 % max 1.224121618785e+01 min
> 1.638169066079e-05 max/min 7.472498682418e+05
> 237 KSP preconditioned resid norm 3.157573520911e-09 true resid norm
> 8.283558144539e-02 ||r(i)||/||b|| 1.309364827513e-01
> 237 KSP Residual norm 3.157573520911e-09 % max 1.266651789872e+01 min
> 1.631989107866e-05 max/min 7.761398552030e+05
> 238 KSP preconditioned resid norm 3.071923111478e-09 true resid norm
> 8.231741040511e-02 ||r(i)||/||b|| 1.301174205525e-01
> 238 KSP Residual norm 3.071923111478e-09 % max 1.310242143029e+01 min
> 1.626505408103e-05 max/min 8.055565856109e+05
> 239 KSP preconditioned resid norm 2.992453638560e-09 true resid norm
> 8.186535317118e-02 ||r(i)||/||b|| 1.294028630739e-01
> 239 KSP Residual norm 2.992453638560e-09 % max 1.358095904032e+01 min
> 1.621534964344e-05 max/min 8.375372310160e+05
> 240 KSP preconditioned resid norm 2.918686673178e-09 true resid norm
> 8.147203530886e-02 ||r(i)||/||b|| 1.287811536998e-01
> 240 KSP Residual norm 2.918686673178e-09 % max 1.407595144572e+01 min
> 1.617073516012e-05 max/min 8.704583499968e+05
> 241 KSP preconditioned resid norm 2.850021677599e-09 true resid norm
> 8.112645247485e-02 ||r(i)||/||b|| 1.282348980933e-01
> 241 KSP Residual norm 2.850021677599e-09 % max 1.460780048328e+01 min
> 1.613020605157e-05 max/min 9.056177234546e+05
> 242 KSP preconditioned resid norm 2.785952071661e-09 true resid norm
> 8.082199238068e-02 ||r(i)||/||b|| 1.277536443473e-01
> 242 KSP Residual norm 2.785952071661e-09 % max 1.516164202801e+01 min
> 1.609343254723e-05 max/min 9.421011946032e+05
> 243 KSP preconditioned resid norm 2.726003754945e-09 true resid norm
> 8.055198108373e-02 ||r(i)||/||b|| 1.273268430995e-01
> 243 KSP Residual norm 2.726003754945e-09 % max 1.574736003328e+01 min
> 1.605983429005e-05 max/min 9.805431207371e+05
> 244 KSP preconditioned resid norm 2.669760211669e-09 true resid norm
> 8.031144058846e-02 ||r(i)||/||b|| 1.269466257357e-01
> 244 KSP Residual norm 2.669760211669e-09 % max 1.635815972012e+01 min
> 1.602907156577e-05 max/min 1.020530705911e+06
> 245 KSP preconditioned resid norm 2.616859721135e-09 true resid norm
> 8.009610298041e-02 ||r(i)||/||b|| 1.266062460521e-01
> 245 KSP Residual norm 2.616859721135e-09 % max 1.699685923744e+01 min
> 1.600077930749e-05 max/min 1.062251963533e+06
> 246 KSP preconditioned resid norm 2.566982964804e-09 true resid norm
> 7.990246732814e-02 ||r(i)||/||b|| 1.263001701991e-01
> 246 KSP Residual norm 2.566982964804e-09 % max 1.766055495648e+01 min
> 1.597468378646e-05 max/min 1.105533930596e+06
> 247 KSP preconditioned resid norm 2.519853945818e-09 true resid norm
> 7.972764043767e-02 ||r(i)||/||b|| 1.260238249653e-01
> 247 KSP Residual norm 2.519853945818e-09 % max 1.834829832678e+01 min
> 1.595053475726e-05 max/min 1.150324964398e+06
> 248 KSP preconditioned resid norm 2.475228628479e-09 true resid norm
> 7.956917868632e-02 ||r(i)||/||b|| 1.257733477668e-01
> 248 KSP Residual norm 2.475228628479e-09 % max 1.905813218687e+01 min
> 1.592812497001e-05 max/min 1.196508203116e+06
> 249 KSP preconditioned resid norm 2.432893339181e-09 true resid norm
> 7.942504309496e-02 ||r(i)||/||b|| 1.255455156318e-01
> 249 KSP Residual norm 2.432893339181e-09 % max 1.978773059579e+01 min
> 1.590727268262e-05 max/min 1.243942377213e+06
> 250 KSP preconditioned resid norm 2.392658478629e-09 true resid norm
> 7.929349666938e-02 ||r(i)||/||b|| 1.253375829297e-01
> 250 KSP Residual norm 2.392658478629e-09 % max 2.053507536526e+01 min
> 1.588782169373e-05 max/min 1.292504143180e+06
> 251 KSP preconditioned resid norm 2.354356018003e-09 true resid norm
> 7.917306646215e-02 ||r(i)||/||b|| 1.251472214030e-01
> 251 KSP Residual norm 2.354356018003e-09 % max 2.129774752042e+01 min
> 1.586963551752e-05 max/min 1.342043898671e+06
> 252 KSP preconditioned resid norm 2.317836022639e-09 true resid norm
> 7.906248909205e-02 ||r(i)||/||b|| 1.249724340512e-01
> 252 KSP Residual norm 2.317836022639e-09 % max 2.207376104408e+01 min
> 1.585259496597e-05 max/min 1.392438341575e+06
> 253 KSP preconditioned resid norm 2.282964417342e-09 true resid norm
> 7.896067936127e-02 ||r(i)||/||b|| 1.248115055248e-01
> 253 KSP Residual norm 2.282964417342e-09 % max 2.286109489220e+01 min
> 1.583659527831e-05 max/min 1.443561225784e+06
> 254 KSP preconditioned resid norm 2.249620807694e-09 true resid norm
> 7.886669910772e-02 ||r(i)||/||b|| 1.246629528903e-01
> 254 KSP Residual norm 2.249620807694e-09 % max 2.365806660683e+01 min
> 1.582154408902e-05 max/min 1.495307061922e+06
> 255 KSP preconditioned resid norm 2.217696771416e-09 true resid norm
> 7.877973447027e-02 ||r(i)||/||b|| 1.245254896945e-01
> 255 KSP Residual norm 2.217696771416e-09 % max 2.446314901661e+01 min
> 1.580735961621e-05 max/min 1.547579710373e+06
> 256 KSP preconditioned resid norm 2.187094355924e-09 true resid norm
> 7.869907621975e-02 ||r(i)||/||b|| 1.243979948735e-01
> 256 KSP Residual norm 2.187094355924e-09 % max 2.527506655730e+01 min
> 1.579396921088e-05 max/min 1.600298583581e+06
> 257 KSP preconditioned resid norm 2.157724818661e-09 true resid norm
> 7.862410399905e-02 ||r(i)||/||b|| 1.242794878418e-01
> 257 KSP Residual norm 2.157724818661e-09 % max 2.609272696980e+01 min
> 1.578130810546e-05 max/min 1.653394433176e+06
> 258 KSP preconditioned resid norm 2.129507540860e-09 true resid norm
> 7.855427316399e-02 ||r(i)||/||b|| 1.241691076915e-01
> 258 KSP Residual norm 2.129507540860e-09 % max 2.691522199241e+01 min
> 1.576931837984e-05 max/min 1.706809472933e+06
> 259 KSP preconditioned resid norm 2.102369096407e-09 true resid norm
> 7.848910387083e-02 ||r(i)||/||b|| 1.240660959436e-01
> 259 KSP Residual norm 2.102369096407e-09 % max 2.774179262325e+01 min
> 1.575794808171e-05 max/min 1.760495242109e+06
> 260 KSP preconditioned resid norm 2.076242447040e-09 true resid norm
> 7.842817196590e-02 ||r(i)||/||b|| 1.239697821473e-01
> 260 KSP Residual norm 2.076242447040e-09 % max 2.857180990120e+01 min
> 1.574715047563e-05 max/min 1.814411435607e+06
> 261 KSP preconditioned resid norm 2.051066245234e-09 true resid norm
> 7.837110133459e-02 ||r(i)||/||b|| 1.238795717860e-01
> 261 KSP Residual norm 2.051066245234e-09 % max 2.940475189721e+01 min
> 1.573688340909e-05 max/min 1.868524480535e+06
> 262 KSP preconditioned resid norm 2.026784227773e-09 true resid norm
> 7.831755746963e-02 ||r(i)||/||b|| 1.237949361110e-01
> 262 KSP Residual norm 2.026784227773e-09 % max 3.024018579353e+01 min
> 1.572710876006e-05 max/min 1.922806426464e+06
> 263 KSP preconditioned resid norm 2.003344686512e-09 true resid norm
> 7.826724200522e-02 ||r(i)||/||b|| 1.237154035016e-01
> 263 KSP Residual norm 2.003344686512e-09 % max 3.107775189605e+01 min
> 1.571779197010e-05 max/min 1.977233949601e+06
> 264 KSP preconditioned resid norm 1.980700004942e-09 true resid norm
> 7.821988809140e-02 ||r(i)||/||b|| 1.236405521538e-01
> 264 KSP Residual norm 1.980700004942e-09 % max 3.191715058147e+01 min
> 1.570890163917e-05 max/min 2.031787537703e+06
> 265 KSP preconditioned resid norm 1.958806251109e-09 true resid norm
> 7.817525644637e-02 ||r(i)||/||b|| 1.235700038397e-01
> 265 KSP Residual norm 1.958806251109e-09 % max 3.275813144817e+01 min
> 1.570040916795e-05 max/min 2.086450811425e+06
> 266 KSP preconditioned resid norm 1.937622818970e-09 true resid norm
> 7.813313196624e-02 ||r(i)||/||b|| 1.235034185490e-01
> 266 KSP Residual norm 1.937622818970e-09 % max 3.360048447534e+01 min
> 1.569228845921e-05 max/min 2.141209968366e+06
> 267 KSP preconditioned resid norm 1.917112111503e-09 true resid norm
> 7.809332083185e-02 ||r(i)||/||b|| 1.234404899160e-01
> 267 KSP Residual norm 1.917112111503e-09 % max 3.444403281522e+01 min
> 1.568451564582e-05 max/min 2.196053330113e+06
> 268 KSP preconditioned resid norm 1.897239259969e-09 true resid norm
> 7.805564799222e-02 ||r(i)||/||b|| 1.233809412410e-01
> 268 KSP Residual norm 1.897239259969e-09 % max 3.528862694058e+01 min
> 1.567706885891e-05 max/min 2.250970972838e+06
> 269 KSP preconditioned resid norm 1.877971874523e-09 true resid norm
> 7.801995501184e-02 ||r(i)||/||b|| 1.233245220884e-01
> 269 KSP Residual norm 1.877971874523e-09 % max 3.613413989135e+01 min
> 1.566992802358e-05 max/min 2.305954426656e+06
> 270 KSP preconditioned resid norm 1.859279822146e-09 true resid norm
> 7.798609818486e-02 ||r(i)||/||b|| 1.232710053053e-01
> 270 KSP Residual norm 1.859279822146e-09 % max 3.698046341191e+01 min
> 1.566307468025e-05 max/min 2.360996430576e+06
> 271 KSP preconditioned resid norm 1.841135028406e-09 true resid norm
> 7.795394691239e-02 ||r(i)||/||b|| 1.232201844568e-01
> 271 KSP Residual norm 1.841135028406e-09 % max 3.782750480653e+01 min
> 1.565649181982e-05 max/min 2.416090733599e+06
> 272 KSP preconditioned resid norm 1.823511300102e-09 true resid norm
> 7.792338226282e-02 ||r(i)||/||b|| 1.231718715502e-01
> 272 KSP Residual norm 1.823511300102e-09 % max 3.867518437327e+01 min
> 1.565016375351e-05 max/min 2.471231929736e+06
> 273 KSP preconditioned resid norm 1.806384166231e-09 true resid norm
> 7.789429574400e-02 ||r(i)||/||b|| 1.231258950942e-01
> 273 KSP Residual norm 1.806384166231e-09 % max 3.952343330397e+01 min
> 1.564407597706e-05 max/min 2.526415325643e+06
> 274 KSP preconditioned resid norm 1.789730735084e-09 true resid norm
> 7.786658820055e-02 ||r(i)||/||b|| 1.230820983558e-01
> 274 KSP Residual norm 1.789730735084e-09 % max 4.037219195996e+01 min
> 1.563821506843e-05 max/min 2.581636828966e+06
> 275 KSP preconditioned resid norm 1.773529565569e-09 true resid norm
> 7.784016885169e-02 ||r(i)||/||b|| 1.230403378399e-01
> 275 KSP Residual norm 1.773529565569e-09 % max 4.122140845150e+01 min
> 1.563256858590e-05 max/min 2.636892857690e+06
> 276 KSP preconditioned resid norm 1.757760551130e-09 true resid norm
> 7.781495445520e-02 ||r(i)||/||b|| 1.230004819672e-01
> 276 KSP Residual norm 1.757760551130e-09 % max 4.207103746307e+01 min
> 1.562712498178e-05 max/min 2.692180264260e+06
> 277 KSP preconditioned resid norm 1.742404814808e-09 true resid norm
> 7.779086855347e-02 ||r(i)||/||b|| 1.229624098827e-01
> 277 KSP Residual norm 1.742404814808e-09 % max 4.292103927837e+01 min
> 1.562187351950e-05 max/min 2.747496273402e+06
> 278 KSP preconditioned resid norm 1.727444614226e-09 true resid norm
> 7.776784081058e-02 ||r(i)||/||b|| 1.229260104079e-01
> 278 KSP Residual norm 1.727444614226e-09 % max 4.377137896812e+01 min
> 1.561680420878e-05 max/min 2.802838428588e+06
> 279 KSP preconditioned resid norm 1.712863255388e-09 true resid norm
> 7.774580642352e-02 ||r(i)||/||b|| 1.228911811100e-01
> 279 KSP Residual norm 1.712863255388e-09 % max 4.462202571076e+01 min
> 1.561190773954e-05 max/min 2.858204548427e+06
> 280 KSP preconditioned resid norm 1.698645014357e-09 true resid norm
> 7.772470561649e-02 ||r(i)||/||b|| 1.228578275027e-01
> 280 KSP Residual norm 1.698645014357e-09 % max 4.547295222235e+01 min
> 1.560717542407e-05 max/min 2.913592689695e+06
> 281 KSP preconditioned resid norm 1.684775065960e-09 true resid norm
> 7.770448314865e-02 ||r(i)||/||b|| 1.228258622679e-01
> 281 KSP Residual norm 1.684775065960e-09 % max 4.632413427620e+01 min
> 1.560259914800e-05 max/min 2.969001115571e+06
> 282 KSP preconditioned resid norm 1.671239418801e-09 true resid norm
> 7.768508792437e-02 ||r(i)||/||b|| 1.227952046398e-01
> 282 KSP Residual norm 1.671239418801e-09 % max 4.717555029673e+01 min
> 1.559817132342e-05 max/min 3.024428269094e+06
> 283 KSP preconditioned resid norm 1.658024855925e-09 true resid norm
> 7.766647260718e-02 ||r(i)||/||b|| 1.227657797946e-01
> 283 KSP Residual norm 1.658024855925e-09 % max 4.802718101487e+01 min
> 1.559388484496e-05 max/min 3.079872750914e+06
> 284 KSP preconditioned resid norm 1.645118880556e-09 true resid norm
> 7.764859329326e-02 ||r(i)||/||b|| 1.227375183346e-01
> 284 KSP Residual norm 1.645118880556e-09 % max 4.887900917455e+01 min
> 1.558973305319e-05 max/min 3.135333299665e+06
> 285 KSP preconditioned resid norm 1.632509666424e-09 true resid norm
> 7.763140921182e-02 ||r(i)||/||b|| 1.227103558140e-01
> 285 KSP Residual norm 1.632509666424e-09 % max 4.973101928201e+01 min
> 1.558570970162e-05 max/min 3.190808775095e+06
> 286 KSP preconditioned resid norm 1.620186012203e-09 true resid norm
> 7.761488245375e-02 ||r(i)||/||b|| 1.226842323109e-01
> 286 KSP Residual norm 1.620186012203e-09 % max 5.058319739082e+01 min
> 1.558180892380e-05 max/min 3.246298144084e+06
> 287 KSP preconditioned resid norm 1.608137299684e-09 true resid norm
> 7.759897773695e-02 ||r(i)||/||b|| 1.226590920554e-01
> 287 KSP Residual norm 1.608137299684e-09 % max 5.143553091712e+01 min
> 1.557802520420e-05 max/min 3.301800468474e+06
> 288 KSP preconditioned resid norm 1.596353455318e-09 true resid norm
> 7.758366217724e-02 ||r(i)||/||b|| 1.226348830683e-01
> 288 KSP Residual norm 1.596353455318e-09 % max 5.228800848011e+01 min
> 1.557435335439e-05 max/min 3.357314893935e+06
> 289 KSP preconditioned resid norm 1.584824914814e-09 true resid norm
> 7.756890510550e-02 ||r(i)||/||b|| 1.226115568716e-01
> 289 KSP Residual norm 1.584824914814e-09 % max 5.314061976413e+01 min
> 1.557078848607e-05 max/min 3.412840641416e+06
> 290 KSP preconditioned resid norm 1.573542590509e-09 true resid norm
> 7.755467787456e-02 ||r(i)||/||b|| 1.225890681832e-01
> 290 KSP Residual norm 1.573542590509e-09 % max 5.399335539895e+01 min
> 1.556732599304e-05 max/min 3.468376998278e+06
> 291 KSP preconditioned resid norm 1.562497841257e-09 true resid norm
> 7.754095371195e-02 ||r(i)||/||b|| 1.225673746845e-01
> 291 KSP Residual norm 1.562497841257e-09 % max 5.484620685555e+01 min
> 1.556396153017e-05 max/min 3.523923311507e+06
> 292 KSP preconditioned resid norm 1.551682444612e-09 true resid norm
> 7.752770755925e-02 ||r(i)||/||b|| 1.225464367661e-01
> 292 KSP Residual norm 1.551682444612e-09 % max 5.569916635525e+01 min
> 1.556069099359e-05 max/min 3.579478981892e+06
> 293 KSP preconditioned resid norm 1.541088571101e-09 true resid norm
> 7.751491595478e-02 ||r(i)||/||b|| 1.225262173427e-01
> 293 KSP Residual norm 1.541088571101e-09 % max 5.655222679014e+01 min
> 1.555751050459e-05 max/min 3.635043458494e+06
> 294 KSP preconditioned resid norm 1.530708760400e-09 true resid norm
> 7.750255689784e-02 ||r(i)||/||b|| 1.225066816381e-01
> 294 KSP Residual norm 1.530708760400e-09 % max 5.740538165332e+01 min
> 1.555441639733e-05 max/min 3.690616233161e+06
> 295 KSP preconditioned resid norm 1.520535899256e-09 true resid norm
> 7.749060974081e-02 ||r(i)||/||b|| 1.224877970152e-01
> 295 KSP Residual norm 1.520535899256e-09 % max 5.825862497755e+01 min
> 1.555140519978e-05 max/min 3.746196837465e+06
> 296 KSP preconditioned resid norm 1.510563200994e-09 true resid norm
> 7.747905509827e-02 ||r(i)||/||b|| 1.224695328317e-01
> 296 KSP Residual norm 1.510563200994e-09 % max 5.911195128112e+01 min
> 1.554847362481e-05 max/min 3.801784838019e+06
> 297 KSP preconditioned resid norm 1.500784186497e-09 true resid norm
> 7.746787474440e-02 ||r(i)||/||b|| 1.224518602786e-01
> 297 KSP Residual norm 1.500784186497e-09 % max 5.996535552011e+01 min
> 1.554561855686e-05 max/min 3.857379833473e+06
> 298 KSP preconditioned resid norm 1.491192666507e-09 true resid norm
> 7.745705153527e-02 ||r(i)||/||b|| 1.224347522568e-01
> 298 KSP Residual norm 1.491192666507e-09 % max 6.081883304605e+01 min
> 1.554283704130e-05 max/min 3.912981451485e+06
> 299 KSP preconditioned resid norm 1.481782725168e-09 true resid norm
> 7.744656933035e-02 ||r(i)||/||b|| 1.224181832532e-01
> 299 KSP Residual norm 1.481782725168e-09 % max 6.167237956835e+01 min
> 1.554012627155e-05 max/min 3.968589346744e+06
> 300 KSP preconditioned resid norm 1.472548704690e-09 true resid norm
> 7.743641291307e-02 ||r(i)||/||b|| 1.224021292155e-01
> 300 KSP Residual norm 1.472548704690e-09 % max 6.252599112088e+01 min
> 1.553748358279e-05 max/min 4.024203197881e+06
> 301 KSP preconditioned resid norm 1.463485191052e-09 true resid norm
> 7.742656794078e-02 ||r(i)||/||b|| 1.223865674723e-01
> 301 KSP Residual norm 1.463485191052e-09 % max 6.337966403224e+01 min
> 1.553490644415e-05 max/min 4.079822705085e+06
> 302 KSP preconditioned resid norm 1.454587000664e-09 true resid norm
> 7.741702087545e-02 ||r(i)||/||b|| 1.223714766244e-01
> 302 KSP Residual norm 1.454587000664e-09 % max 6.423339489912e+01 min
> 1.553239244746e-05 max/min 4.135447589055e+06
> 303 KSP preconditioned resid norm 1.445849167908e-09 true resid norm
> 7.740775893208e-02 ||r(i)||/||b|| 1.223568364630e-01
> 303 KSP Residual norm 1.445849167908e-09 % max 6.508718056257e+01 min
> 1.552993929984e-05 max/min 4.191077589287e+06
> 304 KSP preconditioned resid norm 1.437266933493e-09 true resid norm
> 7.739877002315e-02 ||r(i)||/||b|| 1.223426278813e-01
> 304 KSP Residual norm 1.437266933493e-09 % max 6.594101808663e+01 min
> 1.552754481805e-05 max/min 4.246712462229e+06
> 305 KSP preconditioned resid norm 1.428835733563e-09 true resid norm
> 7.739004272067e-02 ||r(i)||/||b|| 1.223288328156e-01
> 305 KSP Residual norm 1.428835733563e-09 % max 6.679490473918e+01 min
> 1.552520692457e-05 max/min 4.302351979186e+06
> 306 KSP preconditioned resid norm 1.420551189495e-09 true resid norm
> 7.738156621021e-02 ||r(i)||/||b|| 1.223154341716e-01
> 306 KSP Residual norm 1.420551189495e-09 % max 6.764883797474e+01 min
> 1.552292363761e-05 max/min 4.357995926157e+06
> 307 KSP preconditioned resid norm 1.412409098347e-09 true resid norm
> 7.737333024472e-02 ||r(i)||/||b|| 1.223024157521e-01
> 307 KSP Residual norm 1.412409098347e-09 % max 6.850281541896e+01 min
> 1.552069306562e-05 max/min 4.413644102704e+06
> 308 KSP preconditioned resid norm 1.404405423899e-09 true resid norm
> 7.736532511275e-02 ||r(i)||/||b|| 1.222897622063e-01
> 308 KSP Residual norm 1.404405423899e-09 % max 6.935683485452e+01 min
> 1.551851340462e-05 max/min 4.469296320217e+06
> 309 KSP preconditioned resid norm 1.396536288240e-09 true resid norm
> 7.735754161515e-02 ||r(i)||/||b|| 1.222774589933e-01
> 309 KSP Residual norm 1.396536288240e-09 % max 7.021089420858e+01 min
> 1.551638293250e-05 max/min 4.524952401215e+06
> 310 KSP preconditioned resid norm 1.388797963878e-09 true resid norm
> 7.734997100748e-02 ||r(i)||/||b|| 1.222654922910e-01
> 310 KSP Residual norm 1.388797963878e-09 % max 7.106499154121e+01 min
> 1.551430000199e-05 max/min 4.580612179221e+06
> 311 KSP preconditioned resid norm 1.381186866318e-09 true resid norm
> 7.734260499993e-02 ||r(i)||/||b|| 1.222538489959e-01
> 311 KSP Residual norm 1.381186866318e-09 % max 7.191912503503e+01 min
> 1.551226304067e-05 max/min 4.636275496779e+06
> 312 KSP preconditioned resid norm 1.373699547088e-09 true resid norm
> 7.733543571137e-02 ||r(i)||/||b|| 1.222425166504e-01
> 312 KSP Residual norm 1.373699547088e-09 % max 7.277329298577e+01 min
> 1.551027054238e-05 max/min 4.691942206096e+06
> 313 KSP preconditioned resid norm 1.366332687169e-09 true resid norm
> 7.732845565140e-02 ||r(i)||/||b|| 1.222314834147e-01
> 313 KSP Residual norm 1.366332687169e-09 % max 7.362749379365e+01 min
> 1.550832106753e-05 max/min 4.747612167238e+06
> 314 KSP preconditioned resid norm 1.359083090818e-09 true resid norm
> 7.732165769144e-02 ||r(i)||/||b|| 1.222207380206e-01
> 314 KSP Residual norm 1.359083090818e-09 % max 7.448172595555e+01 min
> 1.550641323816e-05 max/min 4.803285247957e+06
> 315 KSP preconditioned resid norm 1.351947679741e-09 true resid norm
> 7.731503505485e-02 ||r(i)||/||b|| 1.222102697565e-01
> 315 KSP Residual norm 1.351947679741e-09 % max 7.533598805789e+01 min
> 1.550454573403e-05 max/min 4.858961323358e+06
> 316 KSP preconditioned resid norm 1.344923487600e-09 true resid norm
> 7.730858128088e-02 ||r(i)||/||b|| 1.222000684101e-01
> 316 KSP Residual norm 1.344923487600e-09 % max 7.619027877011e+01 min
> 1.550271729250e-05 max/min 4.914640274512e+06
> 317 KSP preconditioned resid norm 1.338007654833e-09 true resid norm
> 7.730229022367e-02 ||r(i)||/||b|| 1.221901242666e-01
> 317 KSP Residual norm 1.338007654833e-09 % max 7.704459683868e+01 min
> 1.550092669784e-05 max/min 4.970321990454e+06
> 318 KSP preconditioned resid norm 1.331197423761e-09 true resid norm
> 7.729615601478e-02 ||r(i)||/||b|| 1.221804280500e-01
> 318 KSP Residual norm 1.331197423761e-09 % max 7.789894108168e+01 min
> 1.549917278716e-05 max/min 5.026006365076e+06
> 319 KSP preconditioned resid norm 1.324490133971e-09 true resid norm
> 7.729017306553e-02 ||r(i)||/||b|| 1.221709709264e-01
> 319 KSP Residual norm 1.324490133971e-09 % max 7.875331038375e+01 min
> 1.549745444738e-05 max/min 5.081693296865e+06
> 320 KSP preconditioned resid norm 1.317883217946e-09 true resid norm
> 7.728433604124e-02 ||r(i)||/||b|| 1.221617444634e-01
> 320 KSP Residual norm 1.317883217946e-09 % max 7.960770369153e+01 min
> 1.549577060563e-05 max/min 5.137382690902e+06
> 321 KSP preconditioned resid norm 1.311374196936e-09 true resid norm
> 7.727863984637e-02 ||r(i)||/||b|| 1.221527406065e-01
> 321 KSP Residual norm 1.311374196936e-09 % max 8.046212000946e+01 min
> 1.549412023217e-05 max/min 5.193074456876e+06
> 322 KSP preconditioned resid norm 1.304960677053e-09 true resid norm
> 7.727307961732e-02 ||r(i)||/||b|| 1.221439516680e-01
> 322 KSP Residual norm 1.304960677053e-09 % max 8.131655839582e+01 min
> 1.549250234145e-05 max/min 5.248768507734e+06
> 323 KSP preconditioned resid norm 1.298640345569e-09 true resid norm
> 7.726765070255e-02 ||r(i)||/||b|| 1.221353702952e-01
> 323 KSP Residual norm 1.298640345569e-09 % max 8.217101795924e+01 min
> 1.549091598505e-05 max/min 5.304464761060e+06
> 324 KSP preconditioned resid norm 1.292410967416e-09 true resid norm
> 7.726234866242e-02 ||r(i)||/||b|| 1.221269894705e-01
> 324 KSP Residual norm 1.292410967416e-09 % max 8.302549785536e+01 min
> 1.548936024742e-05 max/min 5.360163139676e+06
> 325 KSP preconditioned resid norm 1.286270381860e-09 true resid norm
> 7.725716924438e-02 ||r(i)||/||b|| 1.221188024720e-01
> 325 KSP Residual norm 1.286270381860e-09 % max 8.387999728379e+01 min
> 1.548783425086e-05 max/min 5.415863569118e+06
> 326 KSP preconditioned resid norm 1.280216499357e-09 true resid norm
> 7.725210838122e-02 ||r(i)||/||b|| 1.221108028707e-01
> 326 KSP Residual norm 1.280216499357e-09 % max 8.473451548533e+01 min
> 1.548633715258e-05 max/min 5.471565977834e+06
> 327 KSP preconditioned resid norm 1.274247298561e-09 true resid norm
> 7.724716218140e-02 ||r(i)||/||b|| 1.221029845154e-01
> 327 KSP Residual norm 1.274247298561e-09 % max 8.558905173932e+01 min
> 1.548486813770e-05 max/min 5.527270298862e+06
> 328 KSP preconditioned resid norm 1.268360823492e-09 true resid norm
> 7.724232691489e-02 ||r(i)||/||b|| 1.220953415101e-01
> 328 KSP Residual norm 1.268360823492e-09 % max 8.644360536128e+01 min
> 1.548342642511e-05 max/min 5.582976467087e+06
> 329 KSP preconditioned resid norm 1.262555180844e-09 true resid norm
> 7.723759900898e-02 ||r(i)||/||b|| 1.220878682074e-01
> 329 KSP Residual norm 1.262555180844e-09 % max 8.729817570067e+01 min
> 1.548201126003e-05 max/min 5.638684421192e+06
> 330 KSP preconditioned resid norm 1.256828537422e-09 true resid norm
> 7.723297504110e-02 ||r(i)||/||b|| 1.220805591975e-01
> 330 KSP Residual norm 1.256828537422e-09 % max 8.815276213883e+01 min
> 1.548062191472e-05 max/min 5.694394102799e+06
> 331 KSP preconditioned resid norm 1.251179117715e-09 true resid norm
> 7.722845172784e-02 ||r(i)||/||b|| 1.220734092902e-01
> 331 KSP Residual norm 1.251179117715e-09 % max 8.900736408702e+01 min
> 1.547925768954e-05 max/min 5.750105455454e+06
> 332 KSP preconditioned resid norm 1.245605201579e-09 true resid norm
> 7.722402591733e-02 ||r(i)||/||b|| 1.220664135034e-01
> 332 KSP Residual norm 1.245605201579e-09 % max 8.986198098471e+01 min
> 1.547791791175e-05 max/min 5.805818424484e+06
> 333 KSP preconditioned resid norm 1.240105122040e-09 true resid norm
> 7.721969459269e-02 ||r(i)||/||b|| 1.220595670686e-01
> 333 KSP Residual norm 1.240105122040e-09 % max 9.071661229787e+01 min
> 1.547660192837e-05 max/min 5.861532959091e+06
> 334 KSP preconditioned resid norm 1.234677263197e-09 true resid norm
> 7.721545484810e-02 ||r(i)||/||b|| 1.220528653924e-01
> 334 KSP Residual norm 1.234677263197e-09 % max 9.157125751743e+01 min
> 1.547530911137e-05 max/min 5.917249009919e+06
> 335 KSP preconditioned resid norm 1.229320058231e-09 true resid norm
> 7.721130389656e-02 ||r(i)||/||b|| 1.220463040695e-01
> 335 KSP Residual norm 1.229320058231e-09 % max 9.242591615789e+01 min
> 1.547403885462e-05 max/min 5.972966529699e+06
> 336 KSP preconditioned resid norm 1.224031987499e-09 true resid norm
> 7.720723906513e-02 ||r(i)||/||b|| 1.220398788749e-01
> 336 KSP Residual norm 1.224031987499e-09 % max 9.328058775593e+01 min
> 1.547279057027e-05 max/min 6.028685474176e+06
> 337 KSP preconditioned resid norm 1.218811576730e-09 true resid norm
> 7.720325777856e-02 ||r(i)||/||b|| 1.220335857379e-01
> 337 KSP Residual norm 1.218811576730e-09 % max 9.413527186918e+01 min
> 1.547156369733e-05 max/min 6.084405798326e+06
> 338 KSP preconditioned resid norm 1.213657395293e-09 true resid norm
> 7.719935756389e-02 ||r(i)||/||b|| 1.220274207496e-01
> 338 KSP Residual norm 1.213657395293e-09 % max 9.498996807506e+01 min
> 1.547035768835e-05 max/min 6.140127461085e+06
> 339 KSP preconditioned resid norm 1.208568054553e-09 true resid norm
> 7.719553604324e-02 ||r(i)||/||b|| 1.220213801513e-01
> 339 KSP Residual norm 1.208568054553e-09 % max 9.584467596970e+01 min
> 1.546917201274e-05 max/min 6.195850423720e+06
> 340 KSP preconditioned resid norm 1.203542206295e-09 true resid norm
> 7.719179092494e-02 ||r(i)||/||b|| 1.220154603206e-01
> 340 KSP Residual norm 1.203542206295e-09 % max 9.669939516689e+01 min
> 1.546800616544e-05 max/min 6.251574645926e+06
> 341 KSP preconditioned resid norm 1.198578541230e-09 true resid norm
> 7.718812001002e-02 ||r(i)||/||b|| 1.220096577817e-01
> 341 KSP Residual norm 1.198578541230e-09 % max 9.755412529717e+01 min
> 1.546685964925e-05 max/min 6.307300092550e+06
> 342 KSP preconditioned resid norm 1.193675787557e-09 true resid norm
> 7.718452117706e-02 ||r(i)||/||b|| 1.220039691812e-01
> 342 KSP Residual norm 1.193675787557e-09 % max 9.840886600689e+01 min
> 1.546573198975e-05 max/min 6.363026727225e+06
> 343 KSP preconditioned resid norm 1.188832709597e-09 true resid norm
> 7.718099238265e-02 ||r(i)||/||b|| 1.219983912892e-01
> 343 KSP Residual norm 1.188832709597e-09 % max 9.926361695742e+01 min
> 1.546462272342e-05 max/min 6.418754516855e+06
> 344 KSP preconditioned resid norm 1.184048106481e-09 true resid norm
> 7.717753165982e-02 ||r(i)||/||b|| 1.219929209965e-01
> 344 KSP Residual norm 1.184048106481e-09 % max 1.001183778244e+02 min
> 1.546353140667e-05 max/min 6.474483427579e+06
> 345 KSP preconditioned resid norm 1.179320810902e-09 true resid norm
> 7.717413711596e-02 ||r(i)||/||b|| 1.219875553115e-01
> 345 KSP Residual norm 1.179320810902e-09 % max 1.009731482967e+02 min
> 1.546245760538e-05 max/min 6.530213428787e+06
> 346 KSP preconditioned resid norm 1.174649687921e-09 true resid norm
> 7.717080691875e-02 ||r(i)||/||b|| 1.219822913380e-01
> 346 KSP Residual norm 1.174649687921e-09 % max 1.018279280764e+02 min
> 1.546140090201e-05 max/min 6.585944489880e+06
> 347 KSP preconditioned resid norm 1.170033633815e-09 true resid norm
> 7.716753931049e-02 ||r(i)||/||b|| 1.219771262975e-01
> 347 KSP Residual norm 1.170033633815e-09 % max 1.026827168774e+02 min
> 1.546036089024e-05 max/min 6.641676582224e+06
> 348 KSP preconditioned resid norm 1.165471574989e-09 true resid norm
> 7.716433258709e-02 ||r(i)||/||b|| 1.219720574964e-01
> 348 KSP Residual norm 1.165471574989e-09 % max 1.035375144253e+02 min
> 1.545933718045e-05 max/min 6.697409676543e+06
> 349 KSP preconditioned resid norm 1.160962466922e-09 true resid norm
> 7.716118511043e-02 ||r(i)||/||b|| 1.219670823454e-01
> 349 KSP Residual norm 1.160962466922e-09 % max 1.043923204565e+02 min
> 1.545832939107e-05 max/min 6.753143746360e+06
> 350 KSP preconditioned resid norm 1.156505293164e-09 true resid norm
> 7.715809530016e-02 ||r(i)||/||b|| 1.219621983465e-01
> 350 KSP Residual norm 1.156505293164e-09 % max 1.052471347179e+02 min
> 1.545733715254e-05 max/min 6.808878766069e+06
> 351 KSP preconditioned resid norm 1.152099064375e-09 true resid norm
> 7.715506162638e-02 ||r(i)||/||b|| 1.219574030814e-01
> 351 KSP Residual norm 1.152099064375e-09 % max 1.061019569664e+02 min
> 1.545636010731e-05 max/min 6.864614710693e+06
> 352 KSP preconditioned resid norm 1.147742817401e-09 true resid norm
> 7.715208261314e-02 ||r(i)||/||b|| 1.219526942171e-01
> 352 KSP Residual norm 1.147742817401e-09 % max 1.069567869683e+02 min
> 1.545539791075e-05 max/min 6.920351555224e+06
> 353 KSP preconditioned resid norm 1.143435614387e-09 true resid norm
> 7.714915683577e-02 ||r(i)||/||b|| 1.219480695016e-01
> 353 KSP Residual norm 1.143435614387e-09 % max 1.078116244987e+02 min
> 1.545445022700e-05 max/min 6.976089276237e+06
> 354 KSP preconditioned resid norm 1.139176541935e-09 true resid norm
> 7.714628291836e-02 ||r(i)||/||b|| 1.219435267600e-01
> 354 KSP Residual norm 1.139176541935e-09 % max 1.086664693415e+02 min
> 1.545351672773e-05 max/min 7.031827852270e+06
> 355 KSP preconditioned resid norm 1.134964710284e-09 true resid norm
> 7.714345952721e-02 ||r(i)||/||b|| 1.219390638843e-01
> 355 KSP Residual norm 1.134964710284e-09 % max 1.095213212888e+02 min
> 1.545259710251e-05 max/min 7.087567258902e+06
> 356 KSP preconditioned resid norm 1.130799252532e-09 true resid norm
> 7.714068537802e-02 ||r(i)||/||b|| 1.219346788443e-01
> 356 KSP Residual norm 1.130799252532e-09 % max 1.103761801401e+02 min
> 1.545169103719e-05 max/min 7.143307478410e+06
> 357 KSP preconditioned resid norm 1.126679323889e-09 true resid norm
> 7.713795922628e-02 ||r(i)||/||b|| 1.219303696729e-01
> 357 KSP Residual norm 1.126679323889e-09 % max 1.112310457026e+02 min
> 1.545079823844e-05 max/min 7.199048488371e+06
> 358 KSP preconditioned resid norm 1.122604100951e-09 true resid norm
> 7.713527986831e-02 ||r(i)||/||b|| 1.219261344674e-01
> 358 KSP Residual norm 1.122604100951e-09 % max 1.120859177906e+02 min
> 1.544991841664e-05 max/min 7.254790269309e+06
> 359 KSP preconditioned resid norm 1.118572781015e-09 true resid norm
> 7.713264614048e-02 ||r(i)||/||b|| 1.219219713885e-01
> 359 KSP Residual norm 1.118572781015e-09 % max 1.129407962252e+02 min
> 1.544905128897e-05 max/min 7.310532803124e+06
> 360 KSP preconditioned resid norm 1.114584581410e-09 true resid norm
> 7.713005691674e-02 ||r(i)||/||b|| 1.219178786563e-01
> 360 KSP Residual norm 1.114584581410e-09 % max 1.137956808336e+02 min
> 1.544819658611e-05 max/min 7.366276069785e+06
> 361 KSP preconditioned resid norm 1.110638738862e-09 true resid norm
> 7.712751110547e-02 ||r(i)||/||b|| 1.219138545454e-01
> 361 KSP Residual norm 1.110638738862e-09 % max 1.146505714496e+02 min
> 1.544735404005e-05 max/min 7.422020052905e+06
> 362 KSP preconditioned resid norm 1.106734508879e-09 true resid norm
> 7.712500764805e-02 ||r(i)||/||b|| 1.219098973822e-01
> 362 KSP Residual norm 1.106734508879e-09 % max 1.155054679126e+02 min
> 1.544652339415e-05 max/min 7.477764734840e+06
> 363 KSP preconditioned resid norm 1.102871165161e-09 true resid norm
> 7.712254552760e-02 ||r(i)||/||b|| 1.219060055596e-01
> 363 KSP Residual norm 1.102871165161e-09 % max 1.163603700679e+02 min
> 1.544570439898e-05 max/min 7.533510098483e+06
> 364 KSP preconditioned resid norm 1.099047999031e-09 true resid norm
> 7.712012375229e-02 ||r(i)||/||b|| 1.219021775097e-01
> 364 KSP Residual norm 1.099047999031e-09 % max 1.172152777659e+02 min
> 1.544489680841e-05 max/min 7.589256129056e+06
> 365 KSP preconditioned resid norm 1.095264318893e-09 true resid norm
> 7.711774136137e-02 ||r(i)||/||b|| 1.218984117138e-01
> 365 KSP Residual norm 1.095264318893e-09 % max 1.180701908624e+02 min
> 1.544410038906e-05 max/min 7.645002809354e+06
> 366 KSP preconditioned resid norm 1.091519449702e-09 true resid norm
> 7.711539742160e-02 ||r(i)||/||b|| 1.218947066969e-01
> 366 KSP Residual norm 1.091519449702e-09 % max 1.189251092179e+02 min
> 1.544331490869e-05 max/min 7.700750125285e+06
> 367 KSP preconditioned resid norm 1.087812732460e-09 true resid norm
> 7.711309103674e-02 ||r(i)||/||b|| 1.218910610423e-01
> 367 KSP Residual norm 1.087812732460e-09 % max 1.197800326979e+02 min
> 1.544254014346e-05 max/min 7.756498062180e+06
> 368 KSP preconditioned resid norm 1.084143523729e-09 true resid norm
> 7.711082133212e-02 ||r(i)||/||b|| 1.218874733673e-01
> 368 KSP Residual norm 1.084143523729e-09 % max 1.206349611723e+02 min
> 1.544177587792e-05 max/min 7.812246604670e+06
> 369 KSP preconditioned resid norm 1.080511195162e-09 true resid norm
> 7.710858745788e-02 ||r(i)||/||b|| 1.218839423287e-01
> 369 KSP Residual norm 1.080511195162e-09 % max 1.214898945154e+02 min
> 1.544102189887e-05 max/min 7.867995739603e+06
> 370 KSP preconditioned resid norm 1.076915133049e-09 true resid norm
> 7.710638859341e-02 ||r(i)||/||b|| 1.218804666293e-01
> 370 KSP Residual norm 1.076915133049e-09 % max 1.223448326055e+02 min
> 1.544027799826e-05 max/min 7.923745454537e+06
> 371 KSP preconditioned resid norm 1.073354737886e-09 true resid norm
> 7.710422394121e-02 ||r(i)||/||b|| 1.218770450086e-01
> 371 KSP Residual norm 1.073354737886e-09 % max 1.231997753251e+02 min
> 1.543954397783e-05 max/min 7.979495735240e+06
> 372 KSP preconditioned resid norm 1.069829423948e-09 true resid norm
> 7.710209272561e-02 ||r(i)||/||b|| 1.218736762404e-01
> 372 KSP Residual norm 1.069829423948e-09 % max 1.240547225605e+02 min
> 1.543881964126e-05 max/min 8.035246569561e+06
> 373 KSP preconditioned resid norm 1.066338618893e-09 true resid norm
> 7.709999419813e-02 ||r(i)||/||b|| 1.218703591416e-01
> 373 KSP Residual norm 1.066338618893e-09 % max 1.249096742015e+02 min
> 1.543810479771e-05 max/min 8.090997945550e+06
> 374 KSP preconditioned resid norm 1.062881763364e-09 true resid norm
> 7.709792762746e-02 ||r(i)||/||b|| 1.218670925562e-01
> 374 KSP Residual norm 1.062881763364e-09 % max 1.257646301416e+02 min
> 1.543739926076e-05 max/min 8.146749851917e+06
> 375 KSP preconditioned resid norm 1.059458310615e-09 true resid norm
> 7.709589230803e-02 ||r(i)||/||b|| 1.218638753691e-01
> 375 KSP Residual norm 1.059458310615e-09 % max 1.266195902777e+02 min
> 1.543670285377e-05 max/min 8.202502275075e+06
> 376 KSP preconditioned resid norm 1.056067726151e-09 true resid norm
> 7.709388754828e-02 ||r(i)||/||b|| 1.218607064870e-01
> 376 KSP Residual norm 1.056067726151e-09 % max 1.274745545100e+02 min
> 1.543601539683e-05 max/min 8.258255205948e+06
> 377 KSP preconditioned resid norm 1.052709487372e-09 true resid norm
> 7.709191268570e-02 ||r(i)||/||b|| 1.218575848627e-01
> 377 KSP Residual norm 1.052709487372e-09 % max 1.283295227415e+02 min
> 1.543533671742e-05 max/min 8.314008634271e+06
> 378 KSP preconditioned resid norm 1.049383083240e-09 true resid norm
> 7.708996706456e-02 ||r(i)||/||b|| 1.218545094598e-01
> 378 KSP Residual norm 1.049383083240e-09 % max 1.291844948787e+02 min
> 1.543466665321e-05 max/min 8.369762546949e+06
> 379 KSP preconditioned resid norm 1.046088013948e-09 true resid norm
> 7.708805005888e-02 ||r(i)||/||b|| 1.218514792888e-01
> 379 KSP Residual norm 1.046088013948e-09 % max 1.300394708306e+02 min
> 1.543400503818e-05 max/min 8.425516935422e+06
> 380 KSP preconditioned resid norm 1.042823790607e-09 true resid norm
> 7.708616105731e-02 ||r(i)||/||b|| 1.218484933832e-01
> 380 KSP Residual norm 1.042823790607e-09 % max 1.308944505091e+02 min
> 1.543335171343e-05 max/min 8.481271789797e+06
> 381 KSP preconditioned resid norm 1.039589934939e-09 true resid norm
> 7.708429945932e-02 ||r(i)||/||b|| 1.218455507940e-01
> 381 KSP Residual norm 1.039589934939e-09 % max 1.317494338290e+02 min
> 1.543270652608e-05 max/min 8.537027099320e+06
> 382 KSP preconditioned resid norm 1.036385978986e-09 true resid norm
> 7.708246468814e-02 ||r(i)||/||b|| 1.218426506093e-01
> 382 KSP Residual norm 1.036385978986e-09 % max 1.326044207073e+02 min
> 1.543206932545e-05 max/min 8.592782854377e+06
> 383 KSP preconditioned resid norm 1.033211464824e-09 true resid norm
> 7.708065617992e-02 ||r(i)||/||b|| 1.218397919379e-01
> 383 KSP Residual norm 1.033211464824e-09 % max 1.334594110638e+02 min
> 1.543143995964e-05 max/min 8.648539048386e+06
> 384 KSP preconditioned resid norm 1.030065944287e-09 true resid norm
> 7.707887338809e-02 ||r(i)||/||b|| 1.218369739159e-01
> 384 KSP Residual norm 1.030065944287e-09 % max 1.343144048204e+02 min
> 1.543081828661e-05 max/min 8.704295671538e+06
> 385 KSP preconditioned resid norm 1.026948978700e-09 true resid norm
> 7.707711577599e-02 ||r(i)||/||b|| 1.218341956950e-01
> 385 KSP Residual norm 1.026948978700e-09 % max 1.351694019016e+02 min
> 1.543020417169e-05 max/min 8.760052712044e+06
> 386 KSP preconditioned resid norm 1.023860138629e-09 true resid norm
> 7.707538282676e-02 ||r(i)||/||b|| 1.218314564581e-01
> 386 KSP Residual norm 1.023860138629e-09 % max 1.360244022339e+02 min
> 1.542959747165e-05 max/min 8.815810165097e+06
> 387 KSP preconditioned resid norm 1.020799003623e-09 true resid norm
> 7.707367403825e-02 ||r(i)||/||b|| 1.218287554116e-01
> 387 KSP Residual norm 1.020799003623e-09 % max 1.368794057461e+02 min
> 1.542899805510e-05 max/min 8.871568021284e+06
> 388 KSP preconditioned resid norm 1.017765161980e-09 true resid norm
> 7.707198891737e-02 ||r(i)||/||b|| 1.218260917761e-01
> 388 KSP Residual norm 1.017765161980e-09 % max 1.377344123689e+02 min
> 1.542840579215e-05 max/min 8.927326272360e+06
> 389 KSP preconditioned resid norm 1.014758210512e-09 true resid norm
> 7.707032698231e-02 ||r(i)||/||b|| 1.218234647898e-01
> 389 KSP Residual norm 1.014758210512e-09 % max 1.385894220351e+02 min
> 1.542782055322e-05 max/min 8.983084911899e+06
> 390 KSP preconditioned resid norm 1.011777754323e-09 true resid norm
> 7.706868777483e-02 ||r(i)||/||b|| 1.218208737286e-01
> 390 KSP Residual norm 1.011777754323e-09 % max 1.394444346793e+02 min
> 1.542724221860e-05 max/min 9.038843929678e+06
> 391 KSP preconditioned resid norm 1.008823406584e-09 true resid norm
> 7.706707083757e-02 ||r(i)||/||b|| 1.218183178695e-01
> 391 KSP Residual norm 1.008823406584e-09 % max 1.402994502381e+02 min
> 1.542667066261e-05 max/min 9.094603320870e+06
> 392 KSP preconditioned resid norm 1.005894788330e-09 true resid norm
> 7.706547572694e-02 ||r(i)||/||b|| 1.218157965112e-01
> 392 KSP Residual norm 1.005894788330e-09 % max 1.411544686498e+02 min
> 1.542610576846e-05 max/min 9.150363077267e+06
> 393 KSP preconditioned resid norm 1.002991528252e-09 true resid norm
> 7.706390201354e-02 ||r(i)||/||b|| 1.218133089752e-01
> 393 KSP Residual norm 1.002991528252e-09 % max 1.420094898544e+02 min
> 1.542554741975e-05 max/min 9.206123192267e+06
> 394 KSP preconditioned resid norm 1.000113262500e-09 true resid norm
> 7.706234928097e-02 ||r(i)||/||b|| 1.218108546031e-01
> 394 KSP Residual norm 1.000113262500e-09 % max 1.428645137936e+02 min
> 1.542499550445e-05 max/min 9.261883658399e+06
> 395 KSP preconditioned resid norm 9.972596344905e-10 true resid norm
> 7.706081711850e-02 ||r(i)||/||b|| 1.218084327457e-01
> 395 KSP Residual norm 9.972596344905e-10 % max 1.437195404107e+02 min
> 1.542444990971e-05 max/min 9.317644470431e+06
> 396 KSP preconditioned resid norm 9.944302947220e-10 true resid norm
> 7.705930512894e-02 ||r(i)||/||b|| 1.218060427752e-01
> 396 KSP Residual norm 9.944302947220e-10 % max 1.445745696505e+02 min
> 1.542391053187e-05 max/min 9.373405619265e+06
> 397 KSP preconditioned resid norm 9.916249005950e-10 true resid norm
> 7.705781292267e-02 ||r(i)||/||b|| 1.218036840757e-01
> 397 KSP Residual norm 9.916249005950e-10 % max 1.454296014594e+02 min
> 1.542337726140e-05 max/min 9.429167100999e+06
> 398 KSP preconditioned resid norm 9.888431162377e-10 true resid norm
> 7.705634012295e-02 ||r(i)||/||b|| 1.218013560518e-01
> 398 KSP Residual norm 9.888431162377e-10 % max 1.462846357853e+02 min
> 1.542284999699e-05 max/min 9.484928908327e+06
> 399 KSP preconditioned resid norm 9.860846123368e-10 true resid norm
> 7.705488636085e-02 ||r(i)||/||b|| 1.217990581203e-01
> 399 KSP Residual norm 9.860846123368e-10 % max 1.471396725772e+02 min
> 1.542232863599e-05 max/min 9.540691036362e+06
> 400 KSP preconditioned resid norm 9.833490659742e-10 true resid norm
> 7.705345127778e-02 ||r(i)||/||b|| 1.217967897143e-01
> 400 KSP Residual norm 9.833490659742e-10 % max 1.479947117857e+02 min
> 1.542181308274e-05 max/min 9.596453477403e+06
> 401 KSP preconditioned resid norm 9.806361604678e-10 true resid norm
> 7.705203451983e-02 ||r(i)||/||b|| 1.217945502744e-01
> 401 KSP Residual norm 9.806361604678e-10 % max 1.488497533627e+02 min
> 1.542130323624e-05 max/min 9.652216228579e+06
> 402 KSP preconditioned resid norm 9.779455852179e-10 true resid norm
> 7.705063574650e-02 ||r(i)||/||b|| 1.217923392624e-01
> 402 KSP Residual norm 9.779455852179e-10 % max 1.497047972613e+02 min
> 1.542079900965e-05 max/min 9.707979279646e+06
> 403 KSP preconditioned resid norm 9.752770355574e-10 true resid norm
> 7.704925462217e-02 ||r(i)||/||b|| 1.217901561479e-01
> 403 KSP Residual norm 9.752770355574e-10 % max 1.505598434358e+02 min
> 1.542030029976e-05 max/min 9.763742632051e+06
> 404 KSP preconditioned resid norm 9.726302126073e-10 true resid norm
> 7.704789082703e-02 ||r(i)||/||b|| 1.217880004253e-01
> 404 KSP Residual norm 9.726302126073e-10 % max 1.514148918418e+02 min
> 1.541980702756e-05 max/min 9.819506273407e+06
> 405 KSP preconditioned resid norm 9.700048231357e-10 true resid norm
> 7.704654403631e-02 ||r(i)||/||b|| 1.217858715812e-01
> 405 KSP Residual norm 9.700048231357e-10 % max 1.522699424359e+02 min
> 1.541931909671e-05 max/min 9.875270203627e+06
> 406 KSP preconditioned resid norm 9.674005794219e-10 true resid norm
> 7.704521394321e-02 ||r(i)||/||b|| 1.217837691306e-01
> 406 KSP Residual norm 9.674005794219e-10 % max 1.531249951760e+02 min
> 1.541883642568e-05 max/min 9.931034414568e+06
> 407 KSP preconditioned resid norm 9.648171991231e-10 true resid norm
> 7.704390024238e-02 ||r(i)||/||b|| 1.217816925910e-01
> 407 KSP Residual norm 9.648171991231e-10 % max 1.539800500208e+02 min
> 1.541835892931e-05 max/min 9.986798901676e+06
> 408 KSP preconditioned resid norm 9.622544051468e-10 true resid norm
> 7.704260264030e-02 ||r(i)||/||b|| 1.217796414984e-01
> 408 KSP Residual norm 9.622544051468e-10 % max 1.548351069303e+02 min
> 1.541788651841e-05 max/min 1.004256366431e+07
> 409 KSP preconditioned resid norm 9.597119255252e-10 true resid norm
> 7.704132084797e-02 ||r(i)||/||b|| 1.217776153959e-01
> 409 KSP Residual norm 9.597119255252e-10 % max 1.556901658654e+02 min
> 1.541741912358e-05 max/min 1.009832869026e+07
> 410 KSP preconditioned resid norm 9.571894932944e-10 true resid norm
> 7.704005458204e-02 ||r(i)||/||b|| 1.217756138356e-01
> 410 KSP Residual norm 9.571894932944e-10 % max 1.565452267880e+02 min
> 1.541695665871e-05 max/min 1.015409397934e+07
> 411 KSP preconditioned resid norm 9.546868463763e-10 true resid norm
> 7.703880356970e-02 ||r(i)||/||b|| 1.217736363864e-01
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180518/52b52fc8/attachment-0001.html>
