[petsc-users] using PETSC_NULL_INTEGER in preallocation routines
Klaij, Christiaan
C.Klaij at marin.nl
Mon May 14 04:45:15 CDT 2018
With petsc-3.7.5, I had F90 code like this:
CALL MatSeqAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,ierr); CHKERRQ(ierr)
CALL MatMPIAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr); CHKERRQ(ierr)
which worked fine. Now, with petsc-3.8.4, the same code gives this compilation error:
error #6634: The shape matching rules of actual arguments and dummy arguments have been violated. [PETSC_NULL_INTEGER]
CALL MatSeqAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,ierr); if (ierr .ne. 0) then ; call PetscErrorF(ierr); return; endif
CALL MatMPIAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr); if (ierr .ne. 0) then ; call PetscErrorF(ierr); return; endif
What's the intended usage now, simply 0 instead of PETSC_NULL_INTEGER?
Chris
dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/120-papers-presented-at-NAV2018.htm
