[petsc-users] PETSc-MUMPS interface, numeric and symbolic factorisation
Smith, Barry F.
bsmith at mcs.anl.gov
Sat May 12 12:14:52 CDT 2018
> On May 12, 2018, at 12:05 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
> Dear Barry,
> Thank you very much for your help.
> Your approach works.
> Based on your idea, I have also tried to use MatDuplicate()
> for creating a new matrix that defines
> the linear system and used MatCopy() for the subsequent
> iterations; and it also works.
Thanks for the update. My approach should be more efficient since it requires one less matrix, no creation of a new matrix each solve and less copying of matrix entries between data-structures.
Barry
> Kind Regards,
> Shidi
> On 2018-05-12 01:05, Smith, Barry F. wrote:
>>> On May 11, 2018, at 7:00 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>> Alp,
>>> thank you for your suggestion. As Barry pointed out, I want to
>>> keep the symbolic factorization, because the matrix structure
>>> in my problem is unchanged for some iterations (doing some
>>> moving mesh) and this part is also sequential.
>>> Thank you very much for your help and time.
>>> Barry,
>>> I really appreciate your time and help.
>>> I will have a try on this.
>>> The basic idea here is keeping the Mat object, but I am using
>>> MatCreateMPIAIJWithArrays() instead, and this function always
>>> create a new Mat object. I think I get it, I have checked
>>> previously that if I do not destroy the Mat object created by
>>> MatCreateMPIAIJWithArrays() every time, the memory usage is
>>> keep going.
>> I understand exactly what you are doing. With my suggested approach
>> you will not use more and more memory because you only CREATE the
>> matrix once with MatCreateMPIAIJWithArrays(), everything after that
>> you simply refill the same initial matrix with
>> MatCopyValuesMPIAIJWithArrays().
>> Please let me know if you have any difficulties with my approach,
>> Barry
>>> Thank you very much for your help indeed.
>>> Kind Regards,
>>> Shidi
>>> On 2018-05-12 00:37, Smith, Barry F. wrote:
>>>>> On May 11, 2018, at 6:14 PM, Dener, Alp <adener at anl.gov> wrote:
>>>>> On May 11, 2018 at 6:03:09 PM, Smith, Barry F. (bsmith at mcs.anl.gov) wrote:
>>>>>> Shidi,
>>>>>> You stated:
>>>>>> >> and create the matrix at the beginning of each iteration.
>>>>>> We never anticipated your use case where you keep the same KSP and make a new matrix for each KSPSolve so we have bugs in PETSc that do not handle that case.
>>>>> We do this in TAO for bounded Newton algorithms where the constraints are handled with an active-set method. We have to construct a new reduced Hessian with a different size every time the active variable indexes change.
>>>>> We don’t completely destroy the KSP solver and create a brand new one whenever this happens. We simply call KSPReset() followed by KSPSetOperators(). This preserves the solver type and other KSP options set in the beginning (e.g.: maximum iterations or various tolerances), but permits the matrix (and the preconditioner) to be completely different objects from one KSPSolve() to another.
>>>>> I don’t know if this behavior is universally supported for all KSP solvers, but it’s been working bug-free for us for STCG, NASH and GLTR solvers. I’ve also made it work with GMRES in a separate test. It may be worth it for Shidi to give it a try and see if it works.
>>>> Alp,
>>>> It should work to produce correct answers, unlike now when incorrect
>>>> answers are produced but it doesn't serve Shidi's goal of reusing the
>>>> matrix symbolic factorization.
>>>> Shidi,
>>>> Here is how you can get what you want. The first time in you use
>>>> MatCreateMPIAIJWithArrays() to create the matrix. Do NOT destroy the
>>>> matrix at the end of the loop. Instead you use MatSetValues() to
>>>> transfer the values from your i,j,a arrays to the matrix with a simple
>>>> loop for the second and ever other time you build the matrix. Here is
>>>> a prototype (untested) of the routine you need.
>>>> /* The A is the matrix obtained with MatCreateMPIAIJWithArrays(); the
>>>> other arguments are the same as you pass to MatCreateMPIAIJWithArrays
>>>> PetscErrorCode MatCopyValuesMPIAIJWithArrays(Mat A,m,i,j,a)
>>>> PetscErrorCode ierr;
>>>> PetscInt i, row,rstart,nnz;
>>>> ierr = MatGetOwnershipRange(A,&rstart,NULL);CHKERRQ(ierr);
>>>> for (ii=0; ii<m; ii++) {
>>>> row = ii + rstart;
>>>> nnz = i[ii+1]- i[ii];
>>>> ierr =
>>>> MatSetValues(A,1,&row,nnz,j+i[ii],values+i[ii],INSERT_VALUES);CHKERRQ(ierr);
>>>> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERR(ierr);
>>>> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERR(ierr);
>>>> PetscFunctionReturn(0);
>>>> Plus it is more efficient than your current code because it does not
>>>> have to build the A from scratch each time.
>>>> Good luck
>>>> Barry
>>>>>> Barry
>>>>>> > On May 11, 2018, at 5:58 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>>>> > Thank you for your reply.
>>>>>> >> For now, if you give the same Mat object back, it will do what you
>>>>>> >> expect.
>>>>>> > Sorry, I am confused here.
>>>>>> > The same Mat object, is it that I do not destroy the Mat at the
>>>>>> > end of iteration?
>>>>>> > Moreover, which function should I actually call to put the Mat
>>>>>> > object back?
>>>>>> > Sorry for being stupid on this.
>>>>>> > Kind Regards,
>>>>>> > Shidi
>>>>>> > On 2018-05-11 18:10, Matthew Knepley wrote:
>>>>>> >> On Fri, May 11, 2018 at 1:02 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>>>> >>> Thank you very much for your reply, Barry.
>>>>>> >>>> This is a bug in PETSc. Since you are providing a new matrix
>>>>>> >>>> with
>>>>>> >>>> the same "state" value as the previous matrix the PC code the
>>>>>> >>>> following code
>>>>>> >>> So what you mean is that every time I change the value in the
>>>>>> >>> matrix,
>>>>>> >>> the PETSc only determines if the nonzero pattern change but not the
>>>>>> >>> values, and if it is unchanged neither of symbolic and numeric
>>>>>> >>> happens.
>>>>>> >> No, that is not what Barry is saying.
>>>>>> >> PETSc looks at the matrix.
>>>>>> >> If the structure has changed, it does symbolic and numeric
>>>>>> >> factorization.
>>>>>> >> If only values have changes, it does numeric factorization.
>>>>>> >> HOWEVER, you gave it a new matrix with accidentally the same state
>>>>>> >> marker,
>>>>>> >> so it thought nothing had changed. We will fix this by also checking
>>>>>> >> the pointer.
>>>>>> >> expect.
>>>>>> >> Matt
>>>>>> >>> I found the following code:
>>>>>> >>> if (!pc->setupcalled) {
>>>>>> >>> ierr = PetscInfo(pc,"Setting up PC for first
>>>>>> >>> timen");CHKERRQ(ierr);
>>>>>> >>> pc->flag = DIFFERENT_NONZERO_PATTERN;
>>>>>> >>> } else if (matstate == pc->matstate) {
>>>>>> >>> ierr = PetscInfo(pc,"Leaving PC with identical preconditioner
>>>>>> >>> since operator is unchangedn");CHKERRQ(ierr);
>>>>>> >>> } else {
>>>>>> >>> if (matnonzerostate > pc->matnonzerostate) {
>>>>>> >>> ierr = PetscInfo(pc,"Setting up PC with different nonzero
>>>>>> >>> patternn");CHKERRQ(ierr);
>>>>>> >>> } else {
>>>>>> >>> ierr = PetscInfo(pc,"Setting up PC with same nonzero
>>>>>> >>> pc->flag = SAME_NONZERO_PATTERN;
>>>>>> >>> and I commend out "else if (matstate == pc->matstate){}", so it
>>>>>> >>> will do "Setting up PC with same nonzero patternn"; and it seems
>>>>>> >>> work in my case, only "MatFactorNumeric_MUMPS()" is calling in the
>>>>>> >>> subsequent iterations. But I am not quite sure, need some more
>>>>>> >>> tests.
>>>>>> >>> Kind Regards,
>>>>>> >>> Shidi
>>>>>> >>> On 2018-05-11 16:13, Smith, Barry F. wrote:
>>>>>> >>> How are you changing the matrix? Do you remember to assemble?
>>>>>> >>> I use MatCreateMPIAIJWithArrays() to create the matrix,
>>>>>> >>> and after that I call MatAssemblyBegin() and MatAssemblyEnd().
>>>>>> >> If you use MatCreateMPIAIJWithArrays() you don't need to call
>>>>>> >>> But I actually destroy the matrix at the end of each iteration
>>>>>> >> This is a bug in PETSc. Since you are providing a new matrix with
>>>>>> >> following code
>>>>>> >> kicks in:
>>>>>> >> ierr =
>>>>>> >> PetscObjectStateGet((PetscObject)pc->pmat,&matstate);CHKERRQ(ierr);
>>>>>> >> ierr = MatGetNonzeroState(pc->pmat,&matnonzerostate);CHKERRQ(ierr);
>>>>>> >> and it returns without refactoring.
>>>>>> >> We need an additional check that the matrix also remains the same.
>>>>>> >> We will also need a test example that reproduces the problem to
>>>>>> >> confirm that we have fixed it.
>>>>>> >> Barry
>>>>>> >>> Cheers,
>>>>>> >>> Shidi
>>>>>> >>> On 2018-05-11 12:59, Matthew Knepley wrote:
>>>>>> >>> On Fri, May 11, 2018 at 7:14 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>>>> >>> Dear Matt,
>>>>>> >>> Thank you for your help last time.
>>>>>> >>> I want to get more detail about the Petsc-MUMPS factorisation;
>>>>>> >>> so I go to look the code "/src/mat/impls/aij/mpi/mumps/mumps.c".
>>>>>> >>> And I found the following functions are quite important to
>>>>>> >>> the question:
>>>>>> >>> PetscErrorCode MatCholeskyFactorSymbolic_MUMPS(Mat F,Mat A,IS
>>>>>> >>> r,const MatFactorInfo *info);
>>>>>> >>> PetscErrorCode MatFactorNumeric_MUMPS(Mat F,Mat A,const
>>>>>> >>> PetscErrorCode MatSolve_MUMPS(Mat A,Vec b,Vec x);
>>>>>> >>> I print some sentence to trace when these functions are called.
>>>>>> >>> Then I test my code; the values in the matrix is changing but the
>>>>>> >>> structure stays the same. Below is the output.
>>>>>> >>> We can see that at 0th step, all the symbolic, numeric and solve
>>>>>> >>> are called; in the subsequent steps only the solve stage is called,
>>>>>> >>> the numeric step is not called.
>>>>>> >>> Matt
>>>>>> >>> Iteration 0 Step 0.0005 Time 0.0005
>>>>>> >>> [INFO]: Direct Solver setup
>>>>>> >>> finish MatCholeskyFactorSymbolic_MUMPS
>>>>>> >>> finish MatFactorNumeric_MUMPS
>>>>>> >>> MatSolve_MUMPS
>>>>>> >>> Iteration 1 Step 0.0005 Time 0.0005
>>>>>> >>> MatSolve_MUMPS
>>>>>> >>> Iteration 2 Step 0.0005 Time 0.001
>>>>>> >>> MatSolve_MUMPS
>>>>>> >>> [INFO]: End of program!!!
>>>>>> >>> I am wondering if there is any possibility to split the numeric
>>>>>> >>> and solve stage (as you mentioned using KSPSolve).
>>>>>> >>> Thank you very much indeed.
>>>>>> >>> Kind Regards,
>>>>>> >>> Shidi
>>>>>> >>> On 2018-05-04 21:10, Y. Shidi wrote:
>>>>>> >>> Thank you very much for your reply.
>>>>>> >>> That is really clear.
>>>>>> >>> Kind Regards,
>>>>>> >>> Shidi
>>>>>> >>> On 2018-05-04 21:05, Matthew Knepley wrote:
>>>>>> >>> On Fri, May 4, 2018 at 3:54 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>>>> >>> Dear Matt,
>>>>>> >>> Thank you very much for your reply!
>>>>>> >>> So what you mean is that I can just do the KSPSolve() every
>>>>>> >>> iteration
>>>>>> >>> once the MUMPS is set?
>>>>>> >>> Yes.
>>>>>> >>> That means inside the KSPSolve() the numerical factorization is
>>>>>> >>> performed. If that is the case, it seems that the ksp object is
>>>>>> >>> not changed when the values in the matrix are changed.
>>>>>> >>> Yes.
>>>>>> >>> Or do I need to call both KSPSetOperators() and KSPSolve()?
>>>>>> >>> If you do SetOperators, it will redo the factorization. If you do
>>>>>> >>> not,
>>>>>> >>> it will look
>>>>>> >>> at the Mat object, determine that the structure has not changed,
>>>>>> >>> and
>>>>>> >>> just redo
>>>>>> >>> the numerical factorization.
>>>>>> >>> Thanks,
>>>>>> >>> Matt
>>>>>> >>> On 2018-05-04 14:44, Matthew Knepley wrote:
>>>>>> >>> On Fri, May 4, 2018 at 9:40 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>>>> >>> Dear PETSc users,
>>>>>> >>> I am currently using MUMPS to solve linear systems directly.
>>>>>> >>> Generally, we use ICNTL(7) or ICNTL(29) to do the preprocessing
>>>>>> >>> step and then solve the system.
>>>>>> >>> In my code, the values in the matrix is changed in each iteration,
>>>>>> >>> but the structure of the matrix stays the same, which means the
>>>>>> >>> performance can be improved if symbolic factorisation is only
>>>>>> >>> performed once. Hence, it is necessary to split the symbolic
>>>>>> >>> and numeric factorisation. However, I cannot find a specific step
>>>>>> >>> (control parameter) to perform the numeric factorisation.
>>>>>> >>> I have used ICNTL(3) and ICNTL(4) to print the MUMPS information,
>>>>>> >>> it seems that the symbolic and numeric factorisation always perform
>>>>>> >>> together.
>>>>>> >>> If you use KSPSolve instead, it will automatically preserve the
>>>>>> >>> symbolic
>>>>>> >>> factorization.
>>>>>> >>> Thanks,
>>>>>> >>> Matt
>>>>>> >>> So I am wondering if anyone has an idea about it.
>>>>>> >>> Below is how I set up MUMPS solver:
>>>>>> >>> PC pc;
>>>>>> >>> PetscBool flg_mumps, flg_mumps_ch;
>>>>>> >>> flg_mumps = PETSC_FALSE;
>>>>>> >>> flg_mumps_ch = PETSC_FALSE;
>>>>>> >>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_lu", &flg_mumps,
>>>>>> >>> NULL);
>>>>>> >>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_ch", &flg_mumps_ch,
>>>>>> >>> NULL);
>>>>>> >>> if(flg_mumps ||flg_mumps_ch)
>>>>>> >>> KSPSetType(_ksp, KSPPREONLY);
>>>>>> >>> PetscInt ival,icntl;
>>>>>> >>> PetscReal val;
>>>>>> >>> KSPGetPC(_ksp, &pc);
>>>>>> >>> /// Set preconditioner type
>>>>>> >>> if(flg_mumps)
>>>>>> >>> PCSetType(pc, PCLU);
>>>>>> >>> else if(flg_mumps_ch)
>>>>>> >>> MatSetOption(A, MAT_SPD, PETSC_TRUE);
>>>>>> >>> PCSetType(pc, PCCHOLESKY);
>>>>>> >>> PCFactorSetMatSolverPackage(pc, MATSOLVERMUMPS);
>>>>>> >>> PCFactorSetUpMatSolverPackage(pc);
>>>>>> >>> PCFactorGetMatrix(pc, &_F);
>>>>>> >>> icntl = 7; ival = 0;
>>>>>> >>> MatMumpsSetIcntl( _F, icntl, ival );
>>>>>> >>> MatMumpsSetIcntl(_F, 3, 6);
>>>>>> >>> MatMumpsSetIcntl(_F, 4, 2);
>>>>>> >>> KSPSetUp(_ksp);
>>>>>> >>> Kind Regards,
>>>>>> >>> Shidi
>>>>>> >>> What most experimenters take for granted before they begin their
>>>>>> >>> experiments is infinitely more interesting than any results to
>>>>>> >>> which
>>>>>> >>> their experiments lead.
>>>>>> >>> -- Norbert Wiener
>>>>>> >>> https://www.cse.buffalo.edu/~knepley/ [1] [1] [1] [1]
>>>>>> >>> Links:
>>>>>> >>> [1] http://www.caam.rice.edu/~mk51/ [2] [2] [2]
>>>>>> >>> which
>>>>>> >>> -- Norbert Wiener
>>>>>> >>> https://www.cse.buffalo.edu/~knepley/ [1] [1] [2]
>>>>>> >>> Links:
>>>>>> >>> [1] https://www.cse.buffalo.edu/~knepley/ [1] [1]
>>>>>> >>> [2] http://www.caam.rice.edu/~mk51/ [2] [2]
>>>>>> >>> which
>>>>>> >>> -- Norbert Wiener
>>>>>> >>> https://www.cse.buffalo.edu/~knepley/ [1] [2]
>>>>>> >>> Links:
>>>>>> >> experiments is infinitely more interesting than any results to which
>>>>>> >> -- Norbert Wiener
>>>>>> >> https://www.cse.buffalo.edu/~knepley/ [2]
>>>>>> >> Links:
>>>>> Alp Dener
>>>>> Postdoctoral Appointee
>>>>> Argonne National Laboratory
>>>>> Mathematics and Computer Science Division
