[petsc-users] PETSc-MUMPS interface, numeric and symbolic factorisation
Smith, Barry F.
bsmith at mcs.anl.gov
Fri May 11 18:02:40 CDT 2018
Shidi,
You stated:
>> and create the matrix at the beginning of each iteration.
We never anticipated your use case where you keep the same KSP and make a new matrix for each KSPSolve so we have bugs in PETSc that do not handle that case.
Barry
> On May 11, 2018, at 5:58 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
> Thank you for your reply.
>> For now, if you give the same Mat object back, it will do what you
>> expect.
> Sorry, I am confused here.
> The same Mat object, is it that I do not destroy the Mat at the
> end of iteration?
> Moreover, which function should I actually call to put the Mat
> object back?
> Sorry for being stupid on this.
> Kind Regards,
> Shidi
> On 2018-05-11 18:10, Matthew Knepley wrote:
>> On Fri, May 11, 2018 at 1:02 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>> Thank you very much for your reply, Barry.
>>>> This is a bug in PETSc. Since you are providing a new matrix
>>>> with
>>>> the same "state" value as the previous matrix the PC code the
>>>> following code
>>> So what you mean is that every time I change the value in the
>>> matrix,
>>> the PETSc only determines if the nonzero pattern change but not the
>>> values, and if it is unchanged neither of symbolic and numeric
>>> happens.
>> No, that is not what Barry is saying.
>> PETSc looks at the matrix.
>> If the structure has changed, it does symbolic and numeric
>> factorization.
>> If only values have changes, it does numeric factorization.
>> HOWEVER, you gave it a new matrix with accidentally the same state
>> marker,
>> so it thought nothing had changed. We will fix this by also checking
>> the pointer.
>> expect.
>> Matt
>>> I found the following code:
>>> if (!pc->setupcalled) {
>>> ierr = PetscInfo(pc,"Setting up PC for first
>>> timen");CHKERRQ(ierr);
>>> pc->flag = DIFFERENT_NONZERO_PATTERN;
>>> } else if (matstate == pc->matstate) {
>>> ierr = PetscInfo(pc,"Leaving PC with identical preconditioner
>>> since operator is unchangedn");CHKERRQ(ierr);
>>> PetscFunctionReturn(0);
>>> } else {
>>> if (matnonzerostate > pc->matnonzerostate) {
>>> ierr = PetscInfo(pc,"Setting up PC with different nonzero
>>> patternn");CHKERRQ(ierr);
>>> } else {
>>> ierr = PetscInfo(pc,"Setting up PC with same nonzero
>>> pc->flag = SAME_NONZERO_PATTERN;
>>> and I commend out "else if (matstate == pc->matstate){}", so it
>>> will do "Setting up PC with same nonzero patternn"; and it seems
>>> work in my case, only "MatFactorNumeric_MUMPS()" is calling in the
>>> subsequent iterations. But I am not quite sure, need some more
>>> tests.
>>> Thank you very much for your help indeed.
>>> Kind Regards,
>>> Shidi
>>> On 2018-05-11 16:13, Smith, Barry F. wrote:
>>> How are you changing the matrix? Do you remember to assemble?
>>> I use MatCreateMPIAIJWithArrays() to create the matrix,
>>> and after that I call MatAssemblyBegin() and MatAssemblyEnd().
>> If you use MatCreateMPIAIJWithArrays() you don't need to call
>>> But I actually destroy the matrix at the end of each iteration
>> This is a bug in PETSc. Since you are providing a new matrix with
>> following code
>> kicks in:
>> ierr =
>> PetscObjectStateGet((PetscObject)pc->pmat,&matstate);CHKERRQ(ierr);
>> ierr = MatGetNonzeroState(pc->pmat,&matnonzerostate);CHKERRQ(ierr);
>> and it returns without refactoring.
>> We need an additional check that the matrix also remains the same.
>> We will also need a test example that reproduces the problem to
>> confirm that we have fixed it.
>> Barry
>>> Cheers,
>>> Shidi
>>> On 2018-05-11 12:59, Matthew Knepley wrote:
>>> On Fri, May 11, 2018 at 7:14 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>> Dear Matt,
>>> Thank you for your help last time.
>>> I want to get more detail about the Petsc-MUMPS factorisation;
>>> so I go to look the code "/src/mat/impls/aij/mpi/mumps/mumps.c".
>>> And I found the following functions are quite important to
>>> the question:
>>> PetscErrorCode MatCholeskyFactorSymbolic_MUMPS(Mat F,Mat A,IS
>>> r,const MatFactorInfo *info);
>>> PetscErrorCode MatFactorNumeric_MUMPS(Mat F,Mat A,const
>>> PetscErrorCode MatSolve_MUMPS(Mat A,Vec b,Vec x);
>>> I print some sentence to trace when these functions are called.
>>> Then I test my code; the values in the matrix is changing but the
>>> structure stays the same. Below is the output.
>>> We can see that at 0th step, all the symbolic, numeric and solve
>>> are called; in the subsequent steps only the solve stage is called,
>>> the numeric step is not called.
>>> Matt
>>> Iteration 0 Step 0.0005 Time 0.0005
>>> [INFO]: Direct Solver setup
>>> finish MatCholeskyFactorSymbolic_MUMPS
>>> finish MatFactorNumeric_MUMPS
>>> MatSolve_MUMPS
>>> Iteration 1 Step 0.0005 Time 0.0005
>>> MatSolve_MUMPS
>>> Iteration 2 Step 0.0005 Time 0.001
>>> MatSolve_MUMPS
>>> [INFO]: End of program!!!
>>> I am wondering if there is any possibility to split the numeric
>>> and solve stage (as you mentioned using KSPSolve).
>>> Thank you very much indeed.
>>> Kind Regards,
>>> Shidi
>>> On 2018-05-04 21:10, Y. Shidi wrote:
>>> Thank you very much for your reply.
>>> That is really clear.
>>> Kind Regards,
>>> Shidi
>>> On 2018-05-04 21:05, Matthew Knepley wrote:
>>> On Fri, May 4, 2018 at 3:54 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>> Dear Matt,
>>> Thank you very much for your reply!
>>> So what you mean is that I can just do the KSPSolve() every
>>> iteration
>>> once the MUMPS is set?
>>> Yes.
>>> That means inside the KSPSolve() the numerical factorization is
>>> performed. If that is the case, it seems that the ksp object is
>>> not changed when the values in the matrix are changed.
>>> Yes.
>>> Or do I need to call both KSPSetOperators() and KSPSolve()?
>>> If you do SetOperators, it will redo the factorization. If you do
>>> not,
>>> it will look
>>> at the Mat object, determine that the structure has not changed,
>>> and
>>> just redo
>>> the numerical factorization.
>>> Thanks,
>>> Matt
>>> On 2018-05-04 14:44, Matthew Knepley wrote:
>>> On Fri, May 4, 2018 at 9:40 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>> Dear PETSc users,
>>> I am currently using MUMPS to solve linear systems directly.
>>> Generally, we use ICNTL(7) or ICNTL(29) to do the preprocessing
>>> step and then solve the system.
>>> In my code, the values in the matrix is changed in each iteration,
>>> but the structure of the matrix stays the same, which means the
>>> performance can be improved if symbolic factorisation is only
>>> performed once. Hence, it is necessary to split the symbolic
>>> and numeric factorisation. However, I cannot find a specific step
>>> (control parameter) to perform the numeric factorisation.
>>> I have used ICNTL(3) and ICNTL(4) to print the MUMPS information,
>>> it seems that the symbolic and numeric factorisation always perform
>>> together.
>>> If you use KSPSolve instead, it will automatically preserve the
>>> symbolic
>>> factorization.
>>> Thanks,
>>> Matt
>>> So I am wondering if anyone has an idea about it.
>>> Below is how I set up MUMPS solver:
>>> PC pc;
>>> PetscBool flg_mumps, flg_mumps_ch;
>>> flg_mumps = PETSC_FALSE;
>>> flg_mumps_ch = PETSC_FALSE;
>>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_lu", &flg_mumps,
>>> NULL);
>>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_ch", &flg_mumps_ch,
>>> NULL);
>>> if(flg_mumps ||flg_mumps_ch)
>>> KSPSetType(_ksp, KSPPREONLY);
>>> PetscInt ival,icntl;
>>> PetscReal val;
>>> KSPGetPC(_ksp, &pc);
>>> /// Set preconditioner type
>>> if(flg_mumps)
>>> PCSetType(pc, PCLU);
>>> else if(flg_mumps_ch)
>>> MatSetOption(A, MAT_SPD, PETSC_TRUE);
>>> PCSetType(pc, PCCHOLESKY);
>>> PCFactorSetMatSolverPackage(pc, MATSOLVERMUMPS);
>>> PCFactorSetUpMatSolverPackage(pc);
>>> PCFactorGetMatrix(pc, &_F);
>>> icntl = 7; ival = 0;
>>> MatMumpsSetIcntl( _F, icntl, ival );
>>> MatMumpsSetIcntl(_F, 3, 6);
>>> MatMumpsSetIcntl(_F, 4, 2);
>>> KSPSetUp(_ksp);
>>> Kind Regards,
>>> Shidi
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> which
>>> their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ [1] [1] [1] [1]
>>> Links:
>>> [1] http://www.caam.rice.edu/~mk51/ [2] [2] [2]
>>> which
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ [1] [1] [2]
>>> Links:
>>> [1] https://www.cse.buffalo.edu/~knepley/ [1] [1]
>>> [2] http://www.caam.rice.edu/~mk51/ [2] [2]
>>> which
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ [1] [2]
>>> Links:
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ [2]
>> Links:
