[petsc-users] Placing FindPETSc.cmake
Stefano Zampini
stefano.zampini at gmail.com
Fri May 11 13:34:40 CDT 2018
CMAKE is case sensitive on this. You should use find_package(PETSc ….)
> On May 11, 2018, at 9:28 PM, Evan Um <evanum at gmail.com> wrote:
> Hi,
> I would like to ask a question about FindPETSc.cmake. I place the cmake file in the same directory where main.cpp is placed. I also placed the file in /usr/share/cmake_xx/Modules.
Actually, it can be put in any directory pointed by the variable CMAKE_MODULE_PATH. If I were you, I would not modify /usr/share/
> Where should i put the file? What else should I do to use the file in cmake? Do I need any other lines in my cmakelists.txt except find_package(petsc)? Thanks for your comments.
> Evan
> cmake_minimum_required(VERSION 3.10)
> project(hellopetsc)
> SET(CMAKE_CXX_STANDARD 11)
> SET(CMAKE_C_COMPILER mpicc)
> SET(CMAKE_CXX_COMPILER mpicxx)
> find_package(PETSC COMPONENTS CXX)
> add_executable(hellopetsc main.cpp)
> CMake Warning at CMakeLists.txt:9 (find_package):
> By not providing "FindPETSC.cmake" in CMAKE_MODULE_PATH this project has
> asked CMake to find a package configuration file provided by "PETSC", but
> CMake did not find one.
> Could not find a package configuration file provided by "PETSC" with any of
> the following names:
> PETSCConfig.cmake
> petsc-config.cmake
> Add the installation prefix of "PETSC" to CMAKE_PREFIX_PATH or set
> "PETSC_DIR" to a directory containing one of the above files. If "PETSC"
> provides a separate development package or SDK, be sure it has been
> installed.
