[petsc-users] PETSc-MUMPS interface, numeric and symbolic factorisation
Y. Shidi ys453 at cam.ac.uk
Fri May 4 15:10:55 CDT 2018
Thank you very much for your reply.
That is really clear.
Kind Regards,
Shidi
On 2018-05-04 21:05, Matthew Knepley wrote:
> On Fri, May 4, 2018 at 3:54 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>> Dear Matt,
>> Thank you very much for your reply!
>> So what you mean is that I can just do the KSPSolve() every
>> iteration
>> once the MUMPS is set?
> Yes.
>> That means inside the KSPSolve() the numerical factorization is
>> performed. If that is the case, it seems that the ksp object is
>> not changed when the values in the matrix are changed.
> Yes.
>> Or do I need to call both KSPSetOperators() and KSPSolve()?
> If you do SetOperators, it will redo the factorization. If you do not,
> it will look
> at the Mat object, determine that the structure has not changed, and
> just redo
> the numerical factorization.
>   Thanks,
>      Matt
>> On 2018-05-04 14:44, Matthew Knepley wrote:
>> On Fri, May 4, 2018 at 9:40 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>> Dear PETSc users,
>> I am currently using MUMPS to solve linear systems directly.
>> Generally, we use ICNTL(7) or ICNTL(29) to do the preprocessing
>> step and then solve the system.
>> In my code, the values in the matrix is changed in each iteration,
>> but the structure of the matrix stays the same, which means the
>> performance can be improved if symbolic factorisation is only
>> performed once. Hence, it is necessary to split the symbolic
>> and numeric factorisation. However, I cannot find a specific step
>> (control parameter) to perform the numeric factorisation.
>> I have used ICNTL(3) and ICNTL(4) to print the MUMPS information,
>> it seems that the symbolic and numeric factorisation always perform
>> together.
>> If you use KSPSolve instead, it will automatically preserve the
>> symbolic
>> factorization.
>> Thanks,
>> Matt
>> So I am wondering if anyone has an idea about it.
>> Below is how I set up MUMPS solver:
>> PC pc;
>> PetscBool flg_mumps, flg_mumps_ch;
>> flg_mumps = PETSC_FALSE;
>> flg_mumps_ch = PETSC_FALSE;
>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_lu", &flg_mumps,
>> NULL);
>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_ch", &flg_mumps_ch,
>> NULL);
>> if(flg_mumps ||flg_mumps_ch)
>> KSPSetType(_ksp, KSPPREONLY);
>> PetscInt ival,icntl;
>> PetscReal val;
>> KSPGetPC(_ksp, &pc);
>> /// Set preconditioner type
>> if(flg_mumps)
>> PCSetType(pc, PCLU);
>> else if(flg_mumps_ch)
>> MatSetOption(A, MAT_SPD, PETSC_TRUE);
>> PCSetType(pc, PCCHOLESKY);
>> PCFactorSetMatSolverPackage(pc, MATSOLVERMUMPS);
>> PCFactorSetUpMatSolverPackage(pc);
>> PCFactorGetMatrix(pc, &_F);
>> icntl = 7; ival = 0;
>> MatMumpsSetIcntl( _F, icntl, ival );
>> MatMumpsSetIcntl(_F, 3, 6);
>> MatMumpsSetIcntl(_F, 4, 2);
>> KSPSetUp(_ksp);
>> Kind Regards,
>> Shidi
>> experiments is infinitely more interesting than any results to
>> which
>> their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ [1] [1]
>> Links:
>> [1] http://www.caam.rice.edu/~mk51/ [2]
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ [2]
> Links:
> [1] https://www.cse.buffalo.edu/~knepley/
> [2] http://www.caam.rice.edu/~mk51/
