[petsc-users] Help my solver scale
Manuel Valera
mvalera-w at sdsu.edu
Wed May 2 16:59:46 CDT 2018
Thanks Matt,
I just remade the streams tests on the machine and i got the following
table, my question would be, is this the maximum speedup i may get on my
machine, and thus should compare the efficiency and scaling tests up to
this figure instead?
I have 20-cores nodes so this was made over 4 nodes,
np speedup
1 1.0
2 1.82
3 2.43
4 2.79
5 2.99
6 3.13
7 3.13
8 3.19
9 3.17
10 3.17
11 3.44
12 3.81
13 4.13
14 4.43
15 4.72
16 5.05
17 5.4
18 5.69
19 5.99
20 6.29
21 6.66
22 6.96
23 7.26
24 7.6
25 7.86
26 8.25
27 8.54
28 8.88
29 9.2
30 9.44
31 9.84
32 10.06
33 10.43
34 10.72
35 11.11
36 11.42
37 11.75
38 12.07
39 12.27
40 12.65
41 12.94
42 13.34
43 13.6
44 13.83
45 14.27
46 14.56
47 14.84
48 15.24
49 15.49
50 15.85
51 15.87
52 16.35
53 16.76
54 17.02
55 17.17
56 17.7
57 17.9
58 18.28
59 18.56
60 18.82
61 19.37
62 19.62
63 19.88
64 20.21
On Wed, May 2, 2018 at 1:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, May 2, 2018 at 4:19 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> Hello guys,
>> We are working in writing a paper about the parallelization of our model
>> using PETSc, which is very exciting since is the first time we see our
>> model scaling, but so far i feel my results for the laplacian solver could
>> be much better,
>> For example, using CG/Multigrid i get less than 20% of efficiency after
>> 16 cores, up to 64 cores where i get only 8% efficiency,
>> I am defining efficiency as speedup over number of cores, and speedup as
>> twall_n/twall_1 where n is the number of cores, i think that's pretty
>> standard,
> This is the first big problem. Not all "cores" are created equal. First,
> you need to run streams in the exact same configuration, so that you can see
> how much speedup to expect. The program is here
> cd src/benchmarks/streams
> and
> make streams
> will run it. You will probably need to submit the program yourself to the
> batch system to get the same configuration as your solver.
> This really matter because 16 cores on one nodes probably only has the
> potential for 5x speedup, so that your 20% is misguided.
> Thanks,
> Matt
>> The ksp_view for a distributed solve looks like this:
>> KSP Object: 16 MPI processes
>> type: cg
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object: 16 MPI processes
>> type: hypre
>> HYPRE BoomerAMG preconditioning
>> Cycle type V
>> Maximum number of levels 25
>> Maximum number of iterations PER hypre call 1
>> Convergence tolerance PER hypre call 0.
>> Threshold for strong coupling 0.25
>> Interpolation truncation factor 0.
>> Interpolation: max elements per row 0
>> Number of levels of aggressive coarsening 0
>> Number of paths for aggressive coarsening 1
>> Maximum row sums 0.9
>> Sweeps down 1
>> Sweeps up 1
>> Sweeps on coarse 1
>> Relax down symmetric-SOR/Jacobi
>> Relax up symmetric-SOR/Jacobi
>> Relax on coarse Gaussian-elimination
>> Relax weight (all) 1.
>> Outer relax weight (all) 1.
>> Using CF-relaxation
>> Not using more complex smoothers.
>> Measure type local
>> Coarsen type Falgout
>> Interpolation type classical
>> Using nodal coarsening (with HYPRE_BOOMERAMGSetNodal() 1
>> HYPRE_BoomerAMGSetInterpVecVariant() 1
>> linear system matrix = precond matrix:
>> Mat Object: 16 MPI processes
>> type: mpiaij
>> rows=213120, cols=213120
>> total: nonzeros=3934732, allocated nonzeros=8098560
>> total number of mallocs used during MatSetValues calls =0
>> has attached near null space
>> And the log_view for the same case would be:
>> *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r
>> -fCourier9' to print this document ***
>> ---------------------------------------------- PETSc Performance
>> Summary: ----------------------------------------------
>> ./gcmSeamount on a timings named ocean with 16 processors, by valera Wed
>> May 2 13:18:21 2018
>> Using Petsc Development GIT revision: v3.9-163-gbe3efd4 GIT Date:
>> 2018-04-16 10:45:40 -0500
>> Max Max/Min Avg Total
>> Time (sec): 1.355e+00 1.00004 1.355e+00
>> Objects: 4.140e+02 1.00000 4.140e+02
>> Flop: 7.582e+05 1.09916 7.397e+05 1.183e+07
>> Flop/sec: 5.594e+05 1.09918 5.458e+05 8.732e+06
>> MPI Messages: 1.588e+03 1.19167 1.468e+03 2.348e+04
>> MPI Message Lengths: 7.112e+07 1.37899 4.462e+04 1.048e+09
>> MPI Reductions: 4.760e+02 1.00000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>> e.g., VecAXPY() for real vectors of length N
>> --> 2N flop
>> and VecAXPY() for complex vectors of length N
>> --> 8N flop
>> Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages
>> --- -- Message Lengths -- -- Reductions --
>> Avg %Total Avg %Total counts
>> %Total Avg %Total counts %Total
>> 0: Main Stage: 1.3553e+00 100.0% 1.1835e+07 100.0% 2.348e+04
>> 100.0% 4.462e+04 100.0% 4.670e+02 98.1%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>> Count: number of times phase was executed
>> Time and Flop: Max - maximum over all processors
>> Ratio - ratio of maximum to minimum over all processors
>> Mess: number of messages sent
>> Avg. len: average message length (bytes)
>> Reduct: number of global reductions
>> Global: entire computation
>> Stage: stages of a computation. Set stages with PetscLogStagePush()
>> and PetscLogStagePop().
>> %T - percent time in this phase %F - percent flop in this
>> phase
>> %M - percent messages in this phase %L - percent message
>> lengths in this phase
>> %R - percent reductions in this phase
>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>> Event Count Time (sec) Flop
>> --- Global --- --- Stage --- Total
>> Max Ratio Max Ratio Max Ratio Mess Avg len
>> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> BuildTwoSidedF 2 1.0 9.1908e-03 2.2 0.00e+00 0.0 3.6e+02 1.6e+05
>> 0.0e+00 1 0 2 6 0 1 0 2 6 0 0
>> VecTDot 1 1.0 6.4135e-05 1.1 2.66e+04 1.0 0.0e+00 0.0e+00
>> 1.0e+00 0 4 0 0 0 0 4 0 0 0 6646
>> VecNorm 1 1.0 1.4589e-0347.1 2.66e+04 1.0 0.0e+00 0.0e+00
>> 1.0e+00 0 4 0 0 0 0 4 0 0 0 292
>> VecScale 14 1.0 3.6144e-04 1.3 4.80e+05 1.1 0.0e+00 0.0e+00
>> 0.0e+00 0 62 0 0 0 0 62 0 0 0 20346
>> VecCopy 7 1.0 1.0152e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecSet 83 1.0 3.0013e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
>> VecPointwiseMult 12 1.0 2.7585e-04 1.4 2.43e+05 1.2 0.0e+00 0.0e+00
>> 0.0e+00 0 31 0 0 0 0 31 0 0 0 13153
>> VecScatterBegin 111 1.0 2.5293e-02 1.8 0.00e+00 0.0 9.5e+03 3.4e+04
>> 1.9e+01 1 0 40 31 4 1 0 40 31 4 0
>> VecScatterEnd 92 1.0 4.8771e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 3 0 0 0 0 3 0 0 0 0 0
>> VecNormalize 1 1.0 2.6941e-05 2.3 1.33e+04 1.0 0.0e+00 0.0e+00
>> 0.0e+00 0 2 0 0 0 0 2 0 0 0 7911
>> MatConvert 1 1.0 1.1009e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 4.0e+00 1 0 0 0 1 1 0 0 0 1 0
>> MatAssemblyBegin 3 1.0 2.8401e-02 1.0 0.00e+00 0.0 3.6e+02 1.6e+05
>> 0.0e+00 2 0 2 6 0 2 0 2 6 0 0
>> MatAssemblyEnd 3 1.0 2.9033e-02 1.0 0.00e+00 0.0 6.0e+01 1.2e+04
>> 2.0e+01 2 0 0 0 4 2 0 0 0 4 0
>> MatGetRowIJ 2 1.0 1.9073e-06 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatView 1 1.0 3.0398e-04 5.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> KSPSetUp 1 1.0 4.7994e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> KSPSolve 1 1.0 2.4850e-03 2.0 5.33e+04 1.0 0.0e+00 0.0e+00
>> 2.0e+00 0 7 0 0 0 0 7 0 0 0 343
>> PCSetUp 2 1.0 2.2953e-02 1.0 1.33e+04 1.0 0.0e+00 0.0e+00
>> 6.0e+00 2 2 0 0 1 2 2 0 0 1 9
>> PCApply 1 1.0 1.3151e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> Memory usage is given in bytes:
>> Object Type Creations Destructions Memory Descendants'
>> Mem.
>> Reports information only for process 0.
>> Vector 172 170 70736264 0.
>> Matrix 5 5 7125104 0.
>> Matrix Null Space 1 1 608 0.
>> Distributed Mesh 18 16 84096 0.
>> Index Set 73 73 10022204 0.
>> IS L to G Mapping 18 16 1180828 0.
>> Star Forest Graph 36 32 27968 0.
>> Discrete System 18 16 15040 0.
>> Vec Scatter 67 64 38240520 0.
>> Krylov Solver 2 2 2504 0.
>> Preconditioner 2 2 2528 0.
>> Viewer 2 1 848 0.
>> Average time to get PetscTime(): 0.
>> Average time for MPI_Barrier(): 2.38419e-06
>> Average time for zero size MPI_Send(): 2.11596e-06
>> #PETSc Option Table entries:
>> -da_processors_z 1
>> -ksp_type cg
>> -ksp_view
>> -log_view
>> -pc_hypre_boomeramg_nodal_coarsen 1
>> -pc_hypre_boomeramg_vec_interp_variant 1
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> Configure options: --known-level1-dcache-size=32768
>> --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8
>> --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2
>> --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8
>> --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8
>> --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=8
>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
>> --known-mpi-c-double-complex=1 --known-has-attribute-aligned=1
>> PETSC_ARCH=timings --with-mpi-dir=/usr/lib64/openmpi
>> --with-blaslapack-dir=/usr/lib64 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
>> FOPTFLAGS=-O3 --with-shared-libraries=1 --download-hypre
>> --with-debugging=no --with-batch -known-mpi-shared-libraries=0
>> --known-64-bit-blas-indices=0
>> Libraries compiled on 2018-04-27 21:13:11 on ocean
>> Machine characteristics: Linux-3.10.0-327.36.3.el7.x86_
>> 64-x86_64-with-centos-7.2.1511-Core
>> Using PETSc directory: /home/valera/petsc
>> Using PETSc arch: timings
>> Using C compiler: /usr/lib64/openmpi/bin/mpicc -fPIC -Wall
>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>> -fvisibility=hidden -O3
>> Using Fortran compiler: /usr/lib64/openmpi/bin/mpif90 -fPIC -Wall
>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>> Using include paths: -I/home/valera/petsc/include
>> -I/home/valera/petsc/timings/include -I/usr/lib64/openmpi/include
>> Using C linker: /usr/lib64/openmpi/bin/mpicc
>> Using Fortran linker: /usr/lib64/openmpi/bin/mpif90
>> Using libraries: -Wl,-rpath,/home/valera/petsc/timings/lib
>> -L/home/valera/petsc/timings/lib -lpetsc -Wl,-rpath,/home/valera/petsc/timings/lib
>> -L/home/valera/petsc/timings/lib -Wl,-rpath,/usr/lib64 -L/usr/lib64
>> -Wl,-rpath,/usr/lib64/openmpi/lib -L/usr/lib64/openmpi/lib
>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -lHYPRE -llapack -lblas -lm
>> -lstdc++ -ldl -lmpi_usempi -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm
>> -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
>> What do you see wrong here? what options could i try to improve my solver
>> scaling?
>> Thanks so much,
>> Manuel
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180502/72b909d4/attachment-0001.html>
