[petsc-users] understanding gmres output
Ganesh Diwan gcdiwan at gmail.com
Tue May 1 06:15:02 CDT 2018
> You may/likely won't get the same convergence with Matlab not due to GMRES
> but due to differences in the ILU in Matlab and PETSc. Better to run with
> Jacobi or no preconditioner if you wish to get consistent results.
Not sure how to specify 'no' preconditioner but I tried
ksp.setOperators(A,Id) where Id is the nxn identity matrix and this gave me
consistent results with Matlab.
I am working on the Helmholtz problems with finite elements and I use a
preconditioning matrix which is supposed to help with the GMRES
convergence. From the options set in the code in my previous post, I
believe PETSc will compute the norm of preconditioned residual (default for
left preconditioning) and use it as the stopping criterion. From the Matlab
documentation, I understand that it will use the norm of the preconditioned
residual (same as PETSc). Despite using the same parameters (number of
restarts, maximum iterations, tolerance and the same preconditioning
matrix), I see PETSc and Matlab diverge in terms of the GMRES iterations as
I refine my finite element mesh (I get consistent results only up to a
certain mesh refinement level). Could you comment?
 Thank you, Ganesh
On Thu, Apr 26, 2018 at 7:24 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> *  You may/likely won't get the same convergence with Matlab not due to
> GMRES but due to differences in the ILU in Matlab and PETSc. Better to run
> with Jacobi or no preconditioner if you wish to get consistent results.
> *   Check carefully if Matlab using left or right preconditioning for
> GMRES (PETSc uses left by default).
> > I see that the residual < norm(b)*rtol for the 4th iteration itself, I
> am not sure then why GMRES continues for one more iteration.
> * Since PETSc is using left preconditioning it is norm(B*b)*rtol that
> determines the convergence, not norm(b)*rtol. Where B is application of
> preconditioner.
> * The residual history for GMRES includes everything through any restarts
> so if it takes 90 total iterations (and the restart is 30) the residual
> history should have 90 values.
> > In the above specific example, it took GMRES a total of 5 iterations to
> converge. Does it mean the convergence was achieved without having to
> restart?
>   In most cases if you need to restart then you need a better
> preconditioner.
>    Barry
> > On Apr 26, 2018, at 9:46 AM, Ganesh Diwan <gcdiwan at gmail.com> wrote:
> > Dear Petsc developers,
> > I am trying to learn to use PETSc GMRES with petsc4py and also trying to
> follow the codes in petsc/src/ksp/ksp/examples/tutorials. Here is the
> Python code I use to read a linear system and solve it with GMRES in PETSc
> (petsc4py)
> > # gmrestest.py
> > # usual imports
> > import numpy as np
> > import scipy.io as sio
> > import scipy
> > from sys import getrefcount
> > from petsc4py import PETSc
> > # read the matrix data
> > mat_contents = sio.loadmat('data.mat')
> > mat_A = mat_contents['A']
> > vec_b = mat_contents['b']
> > n = mat_contents['n']
> > vec_x = mat_contents['x']
> > mat_nnzA = mat_contents['nnzA']
> > # form the petsc matrices
> > x = PETSc.Vec().createWithArray(vec_x)
> > b = PETSc.Vec().createWithArray(vec_b)
> > p1=mat_A.indptr
> > p2=mat_A.indices
> > p3=mat_A.data
> > A = PETSc.Mat().createAIJ(size=mat_A.shape,csr=(p1,p2,p3))
> > A = scipy.transpose(A) # transpose the csr format as my matrix is column
> major originally
> > A.assemblyBegin()
> > A.assemblyEnd()
> > # solve
> > ksp = PETSc.KSP()
> > ksp.create(PETSc.COMM_WORLD)
> > ksp.setType('gmres')
> > ksp.setOperators(A)
> > ksp.setFromOptions()
> > rtol = 1e-4
> > ksp.setTolerances(rtol, 1e-5, 10000., 10000)
> > ksp.view()
> > ksp.setConvergenceHistory()
> > ksp.solve(b, x)
> > # print
> > print 'iterations = ', ksp.getIterationNumber()
> > print 'residual = ', '{:.2e}'.format(ksp.getResidualNorm())#  %.2E
> > print 'norm(b)*rtol =  ', '{:.2e}'.format(PETSc.Vec.norm(b)*rtol)# %.2E
> > print 'converge reason# = ', ksp.getConvergedReason()
> > print 'residuals at each iter = ', ksp.getConvergenceHistory()
> > Here is the output from the above code for a linear system of dimension
> 100 by 100.
> > KSP Object: 1 MPI processes
> >   type: gmres
> >     restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> >     happy breakdown tolerance 1e-30
> >   maximum iterations=10000, initial guess is zero
> >   tolerances:  relative=0.0001, absolute=1e-05, divergence=10000.
> >   using DEFAULT norm type for convergence test
> > PC Object: 1 MPI processes
> >   type: ilu
> >   PC has not been set up so information may be incomplete
> >     out-of-place factorization
> >     0 levels of fill
> >     tolerance for zero pivot 2.22045e-14
> >     matrix ordering: natural
> >   linear system matrix = precond matrix:
> >   Mat Object: 1 MPI processes
> >     type: seqaij
> >     rows=100, cols=100
> >     total: nonzeros=2704, allocated nonzeros=2704
> >     total number of mallocs used during MatSetValues calls =0
> >       using I-node routines: found 25 nodes, limit used is 5
> > iterations =  5
> > residual =  1.38e-03
> > norm(b)*rtol =   1.99e-01
> > converge reason# =  2
> > residuals at each iter =  [  2.05677686e+01   4.97916031e+00
>  4.82888782e-01   1.16849581e-01
> >    8.87159777e-03   1.37992327e-03]
> > Sorry if this sounds stupid, but I am trying to understand the output
> from PETSc by contrasting it with Matlab GMRES.
> am not sure then why GMRES continues for one more iteration. Secondly, how
> does one get total number of iterations? For eg. let's say if it takes 3
> outer iterations each with the default restart of 30, then one would expect
> the length of residual vector to be 150. In the above specific example, it
> took GMRES a total of 5 iterations to converge. Does it mean the
> convergence was achieved without having to restart?
> > Thank you, Ganesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180501/b23217b7/attachment.html>
