[petsc-users] Question about MatCreateSubMatrix
Thu Mar 29 15:10:40 CDT 2018
On Thu, Mar 29, 2018 at 3:28 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
>   I have quick questions about MatCreateSubMatrix:
> — Once the sub matrix is created, do I need to keep the IS (isrow and
> iscol) in memory till this matrix is active, or can I destroy it
> immediately after the creation of the matrix and continue to use the matrix?
You can destroy it.
> — Is the assembly begin/end supposed to be called on the submatrix or the
> original full matrix? Is it a problem is I call this on both?
The SubMatrix is not a view. Its a fully independent matrix.
> — If I modify values in the sub matrix, would these be reflected in the
> original matrix after assembly begin/end, or do I need to do something else
> for that to happen?
No. Do you want something like this
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetLocalSubMatrix.html
    Matt
> Thanks,
> Manav
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180329/a68b7a8a/attachment.html>
