[petsc-users] Obtaining compiling and building information from a.out
TAY wee-beng
zonexo at gmail.com
Tue Mar 27 21:17:45 CDT 2018
Hi Dave,
I looked at the output using log_view and re-compile. However, although
I use the same options "-xHost -g -O3 -openmp" (some filenames and dir
names are now different but they are actually the same), I still get
different results timing. I have attach both, fast and slow. So what
else can I do to pinpoint the differences?
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) ιδΌζ
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
On 27/3/2018 5:22 PM, Dave May wrote:
> On 27 March 2018 at 10:16, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> Hi,
> I have been compiling and building different version of my CFD
> with the intel 2016, 2018 compilers, and also different compiling
> options.
> I tested a version of my a.out and it is much faster than the
> other a.out, using only 3 min instead of more than 10min to solve
> a certain case using GAMG.
> However, I can't recall how it was compiled. I only know that I
> used the intel 2016 compiler.
> So is there any way I can find out how the a.out was compiled?
> Like what options were used?
> Since you posted to the list I presume "a.out" links against petsc...
> If so, run your code with
> -log_view
> Upon calling PetscFinalize(), you will get all the options given to
> PETSc configure, plus the CFLAGS, link lines, etc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180328/9b3b0985/attachment-0001.html>
0.400000000000000 0.400000000000000 0.000000000000000E+000
0.000000000000000E+000 0.000000000000000E+000 0.000000000000000E+000
1.00000000000000 0.400000000000000 0 -400000
AB,AA,BB,CC -3.11950005317340 2.72450003441190
2.95400004531257 2.97600004635751
size_x,size_y,size_z 62x140x388
total grid size = 3367840
recommended cores (50k / core) = 67.3568000000000
myid,jsta,jend,ksta,kend 0 1 70 1
97
myid,jsta,jend,ksta,kend 7 71 140 292
388
myid,jsta,jend,ksta,kend 4 1 70 195
291
myid,jsta,jend,ksta,kend 5 71 140 195
291
myid,jsta,jend,ksta,kend 6 1 70 292
388
myid,jsta,jend,ksta,kend 1 71 140 1
97
myid,jsta,jend,ksta,kend 2 1 70 98
194
myid,jsta,jend,ksta,kend 3 71 140 98
194
min_area,max_area,min_grid_area,ratio 2.491427578150726E-003
8.513928284063485E-003 6.250000000000001E-004 13.6222852545016
ratio bet max_area,min_grid_area not ideal
max element length should be 3.535533905932738E-002
body_cg_ini 0.117923968064102 -1.965876114406727E-005
6.83221612299529
Warning - length difference between element and cell
max_element_length,min_element_length,min_delta
0.157615376756988 5.913693179946990E-002 2.500000000000000E-002
maximum ngh_surfaces and ngh_vertics are 2 1
minimum ngh_surfaces and ngh_vertics are 1 1
min IIB_cell_no 66
max IIB_cell_no 316
IIB_cell_no_sum 1647
min equal_size 1800
max equal_size 2000
min I_cell_no 149
max I_cell_no 1955
I_cell_no_sum 7996
size(IIB_cell_u),size(I_cell_u),size(IIB_equal_cell_u),size(I_equal_cell_u),siz
e(IIB_global_cell_u),size(I_global_cell_u)
316 1955 316 1955 1647 7996
IIB_equal_cell_no_u1_max 316
I_equal_cell_no_u1_max 1955
IIB_I_cell_no_uvw_total1 1647 0 0 7996
0 0
size(IIB_cell_u),IIB_cell_no_max_cur 316 824
local IIB_cells size exceed, to increase size
size(I_cell_u),I_cell_no_max_cur 1955 4004
local I_cells size exceed, to increase size
IIB_cell_no_u1_max,I_cell_no_u1_max 1236 6006
size(IIB_cell_u),IIB_cell_no_max_cur 316 317
IIB_equal_cell_no_u1_max 475
size(I_cell_u),I_cell_no_max_cur 1955 1959
I_equal_cell_no_u1_max 2938
size(IIB_global_cell_u1),IIB_global_cell_no_u1_max_cur 1647 1649
IIB global cells size exceed, to increase size
size(I_global_cell_u1),I_global_cell_no_u1_max_cur 7996 8001
I global cells size exceed, to increase size
IIB_global_cell_no_u1_max,I_global_cell_no_u1_max 2473 12001
time,IIB_I_cell_no_uvw_total1 21 1649 0 0
8001 0 0
size(I_cell_u),I_cell_no_max_cur 6006 6210
IIB_cell_no_u1_max,I_cell_no_u1_max 1236 9315
time,IIB_I_cell_no_uvw_total1 22 1643 0 0
7988 0 0
size(IIB_cell_u),IIB_cell_no_max_cur 1236 1319
IIB_cell_no_u1_max,I_cell_no_u1_max 1978 9315
time,IIB_I_cell_no_uvw_total1 23 1649 0 0
8003 0 0
time,IIB_I_cell_no_uvw_total1 24 1645 0 0
7984 0 0
time,IIB_I_cell_no_uvw_total1 25 1646 0 0
7997 0 0
time,IIB_I_cell_no_uvw_total1 26 1649 0 0
8001 0 0
time,IIB_I_cell_no_uvw_total1 27 1646 0 0
7987 0 0
time,IIB_I_cell_no_uvw_total1 28 1645 0 0
7984 0 0
time,IIB_I_cell_no_uvw_total1 29 1644 0 0
7991 0 0
time,IIB_I_cell_no_uvw_total1 30 1648 0 0
7992 0 0
time,IIB_I_cell_no_uvw_total1 31 1648 0 0
8001 0 0
time,IIB_I_cell_no_uvw_total1 32 1648 0 0
7998 0 0
time,IIB_I_cell_no_uvw_total1 33 1647 0 0
7997 0 0
time,IIB_I_cell_no_uvw_total1 34 1648 0 0
8003 0 0
time,IIB_I_cell_no_uvw_total1 35 1647 0 0
7990 0 0
time,IIB_I_cell_no_uvw_total1 36 1642 0 0
7990 0 0
time,IIB_I_cell_no_uvw_total1 37 1646 0 0
7982 0 0
time,IIB_I_cell_no_uvw_total1 38 1646 0 0
7991 0 0
time,IIB_I_cell_no_uvw_total1 39 1648 0 0
8000 0 0
time,IIB_I_cell_no_uvw_total1 40 1646 0 0
7998 0 0
time,IIB_I_cell_no_uvw_total1 41 1645 0 0
7987 0 0
time,IIB_I_cell_no_uvw_total1 42 1650 0 0
8008 0 0
time,IIB_I_cell_no_uvw_total1 43 1644 0 0
7990 0 0
time,IIB_I_cell_no_uvw_total1 44 1647 0 0
7998 0 0
time,IIB_I_cell_no_uvw_total1 45 1647 0 0
7996 0 0
Recommended no for final_IIB_equal_no1,final_IIB_no1,final_IIB_global_no1,final
_I_equal_no1,final_I_no1,final_I_global_no1
593 2472 3091 3672 11643 15001
97
97
194
194
291
291
388
388
6.83221612299529
2472 11643 593 3672 3091 15001
IIB_I_cell_no_uvw_total1 1647 1699 1668 7996
8318 7986
1 0.01500000 0.55521996 0.50167194 1.49132917 -0.68647491E+03 -0.20372981E+00 0.33615663E+07
2 0.01500000 0.64585142 0.60619409 1.40141482 -0.11012069E+04 -0.16753715E+01 0.33575645E+07
3 0.01500000 0.73593671 0.72189474 1.44197488 -0.13166126E+04 -0.36947098E+01 0.33552444E+07
4 0.01500000 0.76027431 0.77393780 1.46636155 -0.14542153E+04 -0.47010091E+01 0.33537201E+07
5 0.01500000 0.75915757 0.76204613 1.47797514 -0.15453247E+04 -0.60296962E+01 0.33526627E+07
6 0.01500000 0.74742340 0.75211120 1.46445276 -0.16119725E+04 -0.70224586E+01 0.33518669E+07
7 0.01500000 0.72469489 0.73253807 1.45611639 -0.16628567E+04 -0.75633417E+01 0.33512386E+07
8 0.01500000 0.70620928 0.70750345 1.44491710 -0.17038804E+04 -0.81789866E+01 0.33507166E+07
9 0.01500000 0.68737201 0.68840472 1.43060449 -0.17383828E+04 -0.86491557E+01 0.33502642E+07
10 0.01500000 0.67066958 0.67201885 1.41666375 -0.17682751E+04 -0.90679314E+01 0.33498601E+07
11 0.01500000 0.65356651 0.65614140 1.40694393 -0.17948878E+04 -0.94375640E+01 0.33494895E+07
12 0.01500000 0.63784263 0.64006177 1.39565411 -0.18190659E+04 -0.98032901E+01 0.33491430E+07
13 0.01500000 0.62354446 0.62707936 1.38463801 -0.18413690E+04 -0.10146395E+02 0.33488144E+07
14 0.01500000 0.60511977 0.60854016 1.37434517 -0.18621890E+04 -0.10476429E+02 0.33484996E+07
15 0.01500000 0.59483432 0.59700016 1.36652361 -0.18818065E+04 -0.10798095E+02 0.33481953E+07
16 0.01500000 0.58195301 0.58443368 1.35889657 -0.19004238E+04 -0.11113175E+02 0.33478997E+07
17 0.01500000 0.56770020 0.57081075 1.35100984 -0.19181939E+04 -0.11422851E+02 0.33476109E+07
18 0.01500000 0.55880217 0.56091360 1.34350797 -0.19352312E+04 -0.11726948E+02 0.33473280E+07
19 0.01500000 0.54887411 0.55141669 1.33653850 -0.19516281E+04 -0.12027016E+02 0.33470500E+07
20 0.01500000 0.53716931 0.53993030 1.33090692 -0.19674569E+04 -0.12323269E+02 0.33467762E+07
cd_cl_cs_mom_implicit1
0.128886132854489 5.139386380557665E-004 0.344932288820398
-2.214355720498197E-004 -3.982915522187946E-002 8.883606198822986E-005
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./a.out on a petsc-3.8.3_intel2016_rel named vis01 with 8 processors, by tsltaywb Tue Mar 27 22:28:37 2018
Using Petsc Release Version 3.8.3, Dec, 09, 2017
Max Max/Min Avg Total
Time (sec): 1.347e+02 1.00000 1.347e+02
Objects: 9.030e+02 1.00111 9.021e+02
Flop: 1.177e+11 1.00745 1.173e+11 9.387e+11
Flop/sec: 8.740e+08 1.00745 8.710e+08 6.968e+09
MPI Messages: 5.214e+04 1.69428 4.224e+04 3.379e+05
MPI Message Lengths: 9.316e+08 1.42825 1.874e+04 6.333e+09
MPI Reductions: 2.178e+03 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flop
and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 1.3471e+02 100.0% 9.3868e+11 100.0% 3.379e+05 100.0% 1.874e+04 100.0% 2.177e+03 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flop: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flop in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event Count Time (sec) Flop --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSided 4 1.0 2.7359e-0310.9 0.00e+00 0.0 6.4e+01 4.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecDot 76 1.0 2.7495e-01 2.1 1.92e+08 1.0 0.0e+00 0.0e+00 7.6e+01 0 0 0 0 3 0 0 0 0 3 5585
VecDotNorm2 38 1.0 2.1468e-01 3.0 1.92e+08 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 2 0 0 0 0 2 7154
VecMDot 400 1.0 1.5063e+00 1.4 2.39e+09 1.0 0.0e+00 0.0e+00 4.0e+02 1 2 0 0 18 1 2 0 0 18 12703
VecNorm 485 1.0 2.7930e-01 1.6 4.51e+08 1.0 0.0e+00 0.0e+00 4.8e+02 0 0 0 0 22 0 0 0 0 22 12906
VecScale 428 1.0 6.0537e-02 1.0 1.53e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 20259
VecCopy 1426 1.0 4.1480e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 5357 1.0 5.1100e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 28 1.0 1.4019e-02 1.0 1.87e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 10664
VecAYPX 10880 1.0 1.8162e+00 1.1 1.57e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 6920
VecAXPBYCZ 5516 1.0 1.5153e+00 1.0 3.53e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 3 0 0 0 1 3 0 0 0 18616
VecWAXPY 76 1.0 2.2895e-01 1.0 1.92e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 6708
VecMAXPY 428 1.0 1.3232e+00 1.0 2.68e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 16202
VecAssemblyBegin 91 1.0 7.6561e-02 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.7e+02 0 0 0 0 12 0 0 0 0 12 0
VecAssemblyEnd 91 1.0 3.3951e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 44 1.0 1.1086e-02 1.1 5.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 3668
VecScatterBegin 11498 1.0 4.6959e-01 1.3 0.00e+00 0.0 3.3e+05 1.9e+04 0.0e+00 0 0 98 98 0 0 0 98 98 0 0
VecScatterEnd 11498 1.0 4.4420e+00 7.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
VecSetRandom 4 1.0 1.0390e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 428 1.0 2.0914e-01 1.2 4.60e+08 1.0 0.0e+00 0.0e+00 4.3e+02 0 0 0 0 20 0 0 0 0 20 17592
MatMult 8636 1.0 3.5918e+01 1.0 5.13e+10 1.0 2.6e+05 2.2e+04 0.0e+00 26 43 77 90 0 26 43 77 90 0 11366
MatMultAdd 1360 1.0 2.4898e+00 1.0 2.46e+09 1.0 3.5e+04 3.1e+03 0.0e+00 2 2 10 2 0 2 2 10 2 0 7877
MatMultTranspose 1360 1.0 3.1336e+00 1.3 2.46e+09 1.0 3.5e+04 3.1e+03 0.0e+00 2 2 10 2 0 2 2 10 2 0 6258
MatSolve 435 4.6 5.8790e+00 1.0 9.06e+09 1.0 0.0e+00 0.0e+00 0.0e+00 4 8 0 0 0 4 8 0 0 0 12332
MatSOR 8204 1.0 5.4194e+01 1.0 4.00e+10 1.0 0.0e+00 0.0e+00 0.0e+00 40 34 0 0 0 40 34 0 0 0 5883
MatLUFactorSym 1 1.0 2.3842e-05 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 2 1.0 6.1511e-01 1.0 4.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 5510
MatILUFactorSym 1 1.0 2.5613e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatConvert 4 1.0 4.8567e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 13 1.0 9.8135e-02 1.0 7.62e+07 1.0 1.2e+02 1.9e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 6192
MatResidual 1360 1.0 4.8659e+00 1.0 6.88e+09 1.0 4.1e+04 1.9e+04 0.0e+00 4 6 12 13 0 4 6 12 13 0 11222
MatAssemblyBegin 81 1.0 2.0317e-01 1.8 0.00e+00 0.0 6.0e+02 8.2e+04 5.6e+01 0 0 0 1 3 0 0 0 1 3 0
MatAssemblyEnd 81 1.0 4.8165e-01 1.1 0.00e+00 0.0 1.1e+03 4.7e+03 1.7e+02 0 0 0 0 8 0 0 0 0 8 0
MatGetRow 1386912 1.0 5.0331e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 4 0 0 0 0 4 0 0 0 0 0
MatGetRowIJ 2 2.0 1.0014e-05 5.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatCreateSubMat 2 1.0 4.9806e-04 1.0 0.00e+00 0.0 4.9e+01 8.4e+01 3.6e+01 0 0 0 0 2 0 0 0 0 2 0
MatGetOrdering 2 2.0 1.7617e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 4.1207e-02 1.0 0.00e+00 0.0 9.0e+02 7.1e+03 1.4e+01 0 0 0 0 1 0 0 0 0 1 0
MatZeroEntries 4 1.0 9.6283e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAXPY 4 1.0 3.4464e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00 3 0 0 0 0 3 0 0 0 0 0
MatMatMult 4 1.0 3.3812e-01 1.0 2.02e+07 1.0 7.6e+02 9.5e+03 6.5e+01 0 0 0 0 3 0 0 0 0 3 475
MatMatMultSym 4 1.0 2.7510e-01 1.0 0.00e+00 0.0 6.4e+02 7.6e+03 5.6e+01 0 0 0 0 3 0 0 0 0 3 0
MatMatMultNum 4 1.0 6.2469e-02 1.0 2.02e+07 1.0 1.2e+02 1.9e+04 8.0e+00 0 0 0 0 0 0 0 0 0 0 2571
MatPtAP 4 1.0 2.3125e+00 1.0 5.63e+08 1.0 1.5e+03 6.8e+04 6.9e+01 2 0 0 2 3 2 0 0 2 3 1913
MatPtAPSymbolic 4 1.0 1.6609e+00 1.0 0.00e+00 0.0 7.7e+02 6.8e+04 2.9e+01 1 0 0 1 1 1 0 0 1 1 0
MatPtAPNumeric 4 1.0 6.5213e-01 1.0 5.63e+08 1.0 7.2e+02 6.8e+04 4.0e+01 0 0 0 1 2 0 0 0 1 2 6783
MatTrnMatMult 1 1.0 7.2597e-01 1.0 4.10e+07 1.0 1.4e+02 6.9e+04 1.9e+01 1 0 0 0 1 1 0 0 0 1 450
MatTrnMatMultSym 1 1.0 4.6429e-01 1.0 0.00e+00 0.0 1.2e+02 3.5e+04 1.7e+01 0 0 0 0 1 0 0 0 0 1 0
MatTrnMatMultNum 1 1.0 2.6166e-01 1.0 4.10e+07 1.0 2.0e+01 2.8e+05 2.0e+00 0 0 0 0 0 0 0 0 0 0 1249
MatGetLocalMat 14 1.0 7.4680e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetBrAoCol 12 1.0 1.6888e-02 1.2 0.00e+00 0.0 8.5e+02 5.6e+04 0.0e+00 0 0 0 1 0 0 0 0 1 0 0
SFSetGraph 4 1.0 4.2915e-06 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFBcastBegin 22 1.0 3.9790e-03 1.9 0.00e+00 0.0 9.0e+02 7.1e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFBcastEnd 22 1.0 2.1598e-03 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 400 1.0 2.6764e+00 1.2 4.78e+09 1.0 0.0e+00 0.0e+00 4.0e+02 2 4 0 0 18 2 4 0 0 18 14298
KSPSetUp 17 1.0 3.4259e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+01 0 0 0 0 1 0 0 0 0 1 0
KSPSolve 39 1.0 1.2240e+02 1.0 1.18e+11 1.0 3.3e+05 1.8e+04 1.5e+03 91100 99 96 69 91100 99 96 69 7666
PCGAMGGraph_AGG 4 1.0 7.0450e+00 1.0 2.02e+07 1.0 3.5e+02 8.4e+03 4.8e+01 5 0 0 0 2 5 0 0 0 2 23
PCGAMGCoarse_AGG 4 1.0 8.7772e-01 1.0 4.10e+07 1.0 1.2e+03 2.0e+04 4.9e+01 1 0 0 0 2 1 0 0 0 2 372
PCGAMGProl_AGG 4 1.0 1.4617e-01 1.0 0.00e+00 0.0 5.8e+02 8.1e+03 9.6e+01 0 0 0 0 4 0 0 0 0 4 0
PCGAMGPOpt_AGG 4 1.0 4.0676e+00 1.0 3.57e+08 1.0 2.0e+03 1.5e+04 1.9e+02 3 0 1 0 9 3 0 1 0 9 699
GAMG: createProl 4 1.0 1.2139e+01 1.0 4.18e+08 1.0 4.1e+03 1.5e+04 3.8e+02 9 0 1 1 18 9 0 1 1 18 275
Graph 8 1.0 7.0439e+00 1.0 2.02e+07 1.0 3.5e+02 8.4e+03 4.8e+01 5 0 0 0 2 5 0 0 0 2 23
MIS/Agg 4 1.0 4.1251e-02 1.0 0.00e+00 0.0 9.0e+02 7.1e+03 1.4e+01 0 0 0 0 1 0 0 0 0 1 0
SA: col data 4 1.0 2.4046e-02 1.1 0.00e+00 0.0 2.6e+02 1.6e+04 4.0e+01 0 0 0 0 2 0 0 0 0 2 0
SA: frmProl0 4 1.0 1.1588e-01 1.0 0.00e+00 0.0 3.2e+02 1.8e+03 4.0e+01 0 0 0 0 2 0 0 0 0 2 0
SA: smooth 4 1.0 3.8085e+00 1.0 2.75e+07 1.0 7.6e+02 9.5e+03 8.1e+01 3 0 0 0 4 3 0 0 0 4 57
GAMG: partLevel 4 1.0 2.3136e+00 1.0 5.63e+08 1.0 1.6e+03 6.5e+04 1.2e+02 2 0 0 2 6 2 0 0 2 6 1912
repartition 1 1.0 1.0395e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
Invert-Sort 1 1.0 1.0014e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
Move A 1 1.0 3.2687e-04 1.0 0.00e+00 0.0 3.5e+01 1.1e+02 1.9e+01 0 0 0 0 1 0 0 0 0 1 0
Move P 1 1.0 3.0112e-04 1.0 0.00e+00 0.0 1.4e+01 2.6e+01 1.9e+01 0 0 0 0 1 0 0 0 0 1 0
PCSetUp 4 1.0 1.5343e+01 1.0 1.41e+09 1.0 5.7e+03 2.9e+04 5.3e+02 11 1 2 3 24 11 1 2 3 24 726
PCSetUpOnBlocks 359 1.0 8.8877e-01 1.0 4.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 3813
PCApply 435 1.0 9.6567e+01 1.0 9.92e+10 1.0 3.2e+05 1.6e+04 8.4e+01 72 84 95 79 4 72 84 95 79 4 8190
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Vector 359 359 423296120 0.
Vector Scatter 67 67 27572128 0.
Matrix 118 118 2032943620 0.
Matrix Coarsen 4 4 2512 0.
Distributed Mesh 35 35 181440 0.
Index Set 137 137 33646184 0.
IS L to G Mapping 35 35 14511960 0.
Star Forest Graph 74 74 63344 0.
Discrete System 35 35 31500 0.
Krylov Solver 17 17 270136 0.
Preconditioner 13 13 13484 0.
PetscRandom 8 8 5104 0.
Viewer 1 0 0 0.
Average time to get PetscTime(): 1.09673e-06
Average time for MPI_Barrier(): 1.81198e-06
Average time for zero size MPI_Send(): 7.7486e-06
#PETSc Option Table entries:
-log_view
-poisson_pc_gamg_agg_nsmooths 1
-poisson_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-mpi-dir=/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64 --with-blaslapack-dir=/app/intel/compilers_and_libraries_2016.1.150/linux/mkl/lib/intel64 --download-hypre=/home/users/nus/tsltaywb/source/git.hypre.tar.gz --with-debugging=0 --prefix=/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_rel --with-shared-libraries=0 --known-mpi-shared-libraries=0 --with-fortran-interfaces=1 --CFLAGS="-xHost -g -O3 -openmp" --CXXFLAGS="-xHost -g -O3 -openmp" --FFLAGS="-xHost -g -O3 -openmp"
Libraries compiled on Sat Feb 24 21:14:23 2018 on nus03
Machine characteristics: Linux-2.6.32-696.18.7.el6.x86_64-x86_64-with-redhat-6.9-Santiago
Using PETSc directory: /home/users/nus/tsltaywb/source/petsc-3.8.3
Using PETSc arch: petsc-3.8.3_intel2016_rel
Using C compiler: /app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/bin/mpicc -xHost -g -O3 -openmp ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/bin/mpif90 -xHost -g -O3 -openmp ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_rel/include -I/home/users/nus/tsltaywb/source/petsc-3.8.3/include -I/home/users/nus/tsltaywb/source/petsc-3.8.3/include -I/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_rel/include -I/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_rel/include -I/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/include
Using C linker: /app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/bin/mpicc
Using Fortran linker: /app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/bin/mpif90
Using libraries: -Wl,-rpath,/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_rel/lib -L/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_rel/lib -lpetsc -Wl,-rpath,/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_rel/lib -L/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_rel/lib -Wl,-rpath,/app/intel/compilers_and_libraries_2016.1.150/linux/mkl/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/mkl/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib/debug_mt -L/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib -L/app/intel/compilers_and_libraries_2016.1.150/linux/ipp/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/tbb/lib/intel64/gcc4.4 -L/app/intel/compilers_and_libraries_2016.1.150/linux/daal/lib/intel64_lin -L/app/intel/compilers_and_libraries_2016.1.150/linux/tbb/lib/intel64_lin/gcc4.4 -L/app/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64_lin -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -Wl,-rpath,/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib -Wl,-rpath,/opt/intel/mpi-rt/5.1/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/5.1/intel64/lib -Wl,-rpath,/opt/intel/mpi-rt/5.0/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/5.0/intel64/lib -lHYPRE -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lX11 -lifport -lifcoremt -lmpicxx -ldl -lmpifort -lmpi -lmpigi -lrt -lpthread -limf -lsvml -lirng -lm -lipgo -ldecimal -liomp5 -lcilkrts -lstdc++ -lgcc_s -lirc -lirc_s -ldl
Resource Usage on 2018-03-27 22:28:37.108982:
JobId: 6700582.wlm01
Project: 11000314
Exit Status: 0
NCPUs Requested: 8 NCPUs Used: 8
CPU Time Used: 00:17:57
Memory Requested: 32gb Memory Used: 19402196kb
Vmem Used: 21906792kb
Walltime requested: 00:10:00 Walltime Used: 00:02:27
Execution Nodes Used: (vis01:ncpus=8:mem=33554432kb)
97
97
194
194
291
291
388
388
6.83221612299529
min IIB_cell_no 66
max IIB_cell_no 316
min equal_size 1800
max equal_size 2000
min I_cell_no 149
max I_cell_no 1955
I_cell_no_sum 7996
0 0
8001 0 0
7988 0 0
8003 0 0
7984 0 0
7997 0 0
8001 0 0
7987 0 0
7984 0 0
7991 0 0
7992 0 0
8001 0 0
7998 0 0
7997 0 0
8003 0 0
7990 0 0
7990 0 0
7982 0 0
7991 0 0
8000 0 0
7998 0 0
7987 0 0
8008 0 0
7990 0 0
7998 0 0
7996 0 0
97
97
194
194
291
291
388
388
6.83221612299529
8318 7986
1 0.01500000 0.55521952 0.50166514 1.49131893 -0.68670439E+03 -0.20604374E+00 0.33615662E+07
2 0.01500000 0.64585026 0.60619564 1.40140471 -0.11009478E+04 -0.10911172E+01 0.33575644E+07
3 0.01500000 0.73593463 0.72189795 1.44197265 -0.13161091E+04 -0.28042672E+01 0.33552438E+07
4 0.01500000 0.76027325 0.77393896 1.46636140 -0.14536130E+04 -0.36603995E+01 0.33537189E+07
5 0.01500000 0.75915510 0.76204667 1.47797502 -0.15446388E+04 -0.49307434E+01 0.33526611E+07
6 0.01500000 0.74742136 0.75211276 1.46445227 -0.16112041E+04 -0.59483248E+01 0.33518653E+07
7 0.01500000 0.72469437 0.73253845 1.45611669 -0.16620039E+04 -0.65738576E+01 0.33512372E+07
8 0.01500000 0.70620865 0.70750419 1.44491755 -0.17029461E+04 -0.73025142E+01 0.33507155E+07
9 0.01500000 0.68737227 0.68840507 1.43060525 -0.17373751E+04 -0.78836160E+01 0.33502633E+07
10 0.01500000 0.67066988 0.67201926 1.41666490 -0.17672055E+04 -0.83903321E+01 0.33498595E+07
11 0.01500000 0.65356708 0.65614218 1.40694522 -0.17937703E+04 -0.88125441E+01 0.33494891E+07
12 0.01500000 0.63784284 0.64006217 1.39565551 -0.18179146E+04 -0.91924434E+01 0.33491426E+07
13 0.01500000 0.62354467 0.62707978 1.38463971 -0.18401961E+04 -0.95159393E+01 0.33488141E+07
14 0.01500000 0.60512073 0.60854059 1.37434643 -0.18610036E+04 -0.98021312E+01 0.33484991E+07
15 0.01500000 0.59483523 0.59700107 1.36652434 -0.18806142E+04 -0.10067043E+02 0.33481948E+07
16 0.01500000 0.58195385 0.58443459 1.35889875 -0.18992269E+04 -0.10322942E+02 0.33478989E+07
17 0.01500000 0.56770101 0.57081164 1.35101132 -0.19169918E+04 -0.10578851E+02 0.33476101E+07
18 0.01500000 0.55880304 0.56091451 1.34350841 -0.19340220E+04 -0.10838995E+02 0.33473270E+07
19 0.01500000 0.54887498 0.55141759 1.33653898 -0.19504092E+04 -0.11106005E+02 0.33470490E+07
20 0.01500000 0.53716976 0.53993119 1.33090820 -0.19662259E+04 -0.11378638E+02 0.33467752E+07
0.128886335282393 5.139605941217318E-004 0.344932516978139
-2.214409645676409E-004 -3.982912633936039E-002 8.883873705382712E-005
./a.out on a petsc-3.8.3_intel2016_O3_rel named vis01 with 8 processors, by tsltaywb Wed Mar 28 00:37:22 2018
Time (sec): 6.984e+02 1.00000 6.984e+02
Objects: 8.800e+02 1.00114 8.791e+02
Flop: 6.874e+11 1.00870 6.847e+11 5.478e+12
Flop/sec: 9.842e+08 1.00870 9.804e+08 7.843e+09
MPI Messages: 3.604e+05 1.70000 2.916e+05 2.333e+06
MPI Message Lengths: 5.939e+09 1.42866 1.730e+04 4.036e+10
MPI Reductions: 3.933e+03 1.00000
0: Main Stage: 6.9842e+02 100.0% 5.4778e+12 100.0% 2.333e+06 100.0% 1.730e+04 100.0% 3.932e+03 100.0%
Phase summary info:
BuildTwoSided 4 1.0 3.0739e-0313.3 0.00e+00 0.0 6.4e+01 4.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecDot 76 1.0 2.7252e-01 2.1 1.92e+08 1.0 0.0e+00 0.0e+00 7.6e+01 0 0 0 0 2 0 0 0 0 2 5635
VecDotNorm2 38 1.0 2.1477e-01 2.9 1.92e+08 1.0 0.0e+00 0.0e+00 3.8e+01 0 0 0 0 1 0 0 0 0 1 7151
VecMDot 80 1.0 7.3801e-02 1.4 1.02e+08 1.0 0.0e+00 0.0e+00 8.0e+01 0 0 0 0 2 0 0 0 0 2 11020
VecNorm 2606 1.0 2.5490e+00 6.4 2.24e+09 1.0 0.0e+00 0.0e+00 2.6e+03 0 0 0 0 66 0 0 0 0 66 7019
VecScale 88 1.0 4.2443e-03 1.1 1.02e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 19161
VecCopy 7329 1.0 3.1297e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 34131 1.0 6.2618e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 8 1.0 1.4107e-03 1.0 1.85e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 10481
VecAYPX 79973 1.0 1.4727e+01 1.1 1.23e+10 1.0 0.0e+00 0.0e+00 0.0e+00 2 2 0 0 0 2 2 0 0 0 6654
VecAXPBYCZ 38852 1.0 9.4528e+00 1.1 2.29e+10 1.0 0.0e+00 0.0e+00 0.0e+00 1 3 0 0 0 1 3 0 0 0 19331
VecWAXPY 76 1.0 2.3002e-01 1.0 1.92e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 6676
VecMAXPY 88 1.0 5.7092e-02 1.0 1.20e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 16835
VecAssemblyBegin 91 1.0 7.6395e-02 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.7e+02 0 0 0 0 7 0 0 0 0 7 0
VecAssemblyEnd 91 1.0 3.1996e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 44 1.0 1.0860e-02 1.0 5.09e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 3744
VecScatterBegin 80251 1.0 2.4074e+00 1.4 0.00e+00 0.0 2.3e+06 1.7e+04 0.0e+00 0 0100100 0 0 0100100 0 0
VecScatterEnd 80251 1.0 3.0498e+01 8.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
VecSetRandom 4 1.0 1.0388e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 88 1.0 2.0471e-02 1.7 3.05e+07 1.0 0.0e+00 0.0e+00 8.8e+01 0 0 0 0 2 0 0 0 0 2 11918
MatMult 60741 1.0 2.3056e+02 1.1 3.21e+11 1.0 1.8e+06 2.1e+04 0.0e+00 32 46 78 95 0 32 46 78 95 0 11048
MatMultAdd 9684 1.0 1.7790e+01 1.0 1.75e+10 1.0 2.5e+05 3.1e+03 0.0e+00 3 3 11 2 0 3 3 11 2 0 7849
MatMultTranspose 9684 1.0 2.1507e+01 1.3 1.75e+10 1.0 2.5e+05 3.1e+03 0.0e+00 3 3 11 2 0 3 3 11 2 0 6493
MatSolve 251626.5 5.8798e+00 1.0 9.06e+09 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 12331
MatSOR 58208 1.0 3.8408e+02 1.0 2.84e+11 1.0 0.0e+00 0.0e+00 0.0e+00 54 41 0 0 0 54 41 0 0 0 5897
MatLUFactorSym 1 1.0 2.7895e-05 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatLUFactorNum 2 1.0 6.1062e-01 1.0 4.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 5550
MatILUFactorSym 1 1.0 2.5299e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatConvert 4 1.0 4.8461e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 13 1.0 9.7709e-02 1.0 7.62e+07 1.0 1.2e+02 1.9e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 6219
MatResidual 9704 1.0 3.4509e+01 1.0 4.92e+10 1.0 3.0e+05 1.9e+04 0.0e+00 5 7 13 14 0 5 7 13 14 0 11318
MatAssemblyBegin 81 1.0 2.8049e-01 9.1 0.00e+00 0.0 6.0e+02 8.2e+04 5.6e+01 0 0 0 0 1 0 0 0 0 1 0
MatAssemblyEnd 81 1.0 5.1077e-01 1.2 0.00e+00 0.0 1.1e+03 4.7e+03 1.7e+02 0 0 0 0 4 0 0 0 0 4 0
MatGetRow 1386912 1.0 5.0990e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
MatGetRowIJ 2 2.0 7.1526e-06 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatCreateSubMat 2 1.0 5.5003e-04 1.0 0.00e+00 0.0 4.9e+01 8.4e+01 3.6e+01 0 0 0 0 1 0 0 0 0 1 0
MatGetOrdering 2 2.0 1.8149e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 4 1.0 4.0846e-02 1.0 0.00e+00 0.0 9.0e+02 7.1e+03 1.4e+01 0 0 0 0 0 0 0 0 0 0 0
MatZeroEntries 4 1.0 9.5308e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAXPY 4 1.0 3.4579e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 4 1.0 3.3728e-01 1.0 2.02e+07 1.0 7.6e+02 9.5e+03 6.5e+01 0 0 0 0 2 0 0 0 0 2 476
MatMatMultSym 4 1.0 2.7397e-01 1.0 0.00e+00 0.0 6.4e+02 7.6e+03 5.6e+01 0 0 0 0 1 0 0 0 0 1 0
MatMatMultNum 4 1.0 6.0991e-02 1.0 2.02e+07 1.0 1.2e+02 1.9e+04 8.0e+00 0 0 0 0 0 0 0 0 0 0 2633
MatPtAP 4 1.0 2.2907e+00 1.0 5.63e+08 1.0 1.5e+03 6.8e+04 6.9e+01 0 0 0 0 2 0 0 0 0 2 1931
MatPtAPSymbolic 4 1.0 1.6347e+00 1.0 0.00e+00 0.0 7.7e+02 6.8e+04 2.9e+01 0 0 0 0 1 0 0 0 0 1 0
MatPtAPNumeric 4 1.0 6.5637e-01 1.0 5.63e+08 1.0 7.2e+02 6.8e+04 4.0e+01 0 0 0 0 1 0 0 0 0 1 6739
MatTrnMatMult 1 1.0 7.3789e-01 1.0 4.10e+07 1.0 1.4e+02 6.9e+04 1.9e+01 0 0 0 0 0 0 0 0 0 0 443
MatTrnMatMultSym 1 1.0 4.7426e-01 1.0 0.00e+00 0.0 1.2e+02 3.5e+04 1.7e+01 0 0 0 0 0 0 0 0 0 0 0
MatTrnMatMultNum 1 1.0 2.6366e-01 1.0 4.10e+07 1.0 2.0e+01 2.8e+05 2.0e+00 0 0 0 0 0 0 0 0 0 0 1240
MatGetLocalMat 14 1.0 7.4357e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetBrAoCol 12 1.0 1.6210e-02 1.1 0.00e+00 0.0 8.5e+02 5.6e+04 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFSetGraph 4 1.0 6.6757e-06 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFBcastBegin 22 1.0 4.3759e-03 2.0 0.00e+00 0.0 9.0e+02 7.1e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFBcastEnd 22 1.0 2.5189e-03 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 80 1.0 1.2113e-01 1.2 2.03e+08 1.0 0.0e+00 0.0e+00 8.0e+01 0 0 0 0 2 0 0 0 0 2 13428
KSPSetUp 17 1.0 3.4320e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.4e+01 0 0 0 0 1 0 0 0 0 1 0
KSPSolve 39 1.0 6.8603e+02 1.0 6.87e+11 1.0 2.3e+06 1.7e+04 3.3e+03 98100100 99 83 98100100 99 83 7984
PCGAMGGraph_AGG 4 1.0 7.0555e+00 1.0 2.02e+07 1.0 3.5e+02 8.4e+03 4.8e+01 1 0 0 0 1 1 0 0 0 1 23
PCGAMGCoarse_AGG 4 1.0 8.9008e-01 1.0 4.10e+07 1.0 1.2e+03 2.0e+04 4.9e+01 0 0 0 0 1 0 0 0 0 1 367
PCGAMGProl_AGG 4 1.0 1.3883e-01 1.0 0.00e+00 0.0 5.8e+02 8.1e+03 9.6e+01 0 0 0 0 2 0 0 0 0 2 0
PCGAMGPOpt_AGG 4 1.0 4.0805e+00 1.0 3.57e+08 1.0 2.0e+03 1.5e+04 1.9e+02 1 0 0 0 5 1 0 0 0 5 697
GAMG: createProl 4 1.0 1.2167e+01 1.0 4.18e+08 1.0 4.1e+03 1.5e+04 3.8e+02 2 0 0 0 10 2 0 0 0 10 274
Graph 8 1.0 7.0544e+00 1.0 2.02e+07 1.0 3.5e+02 8.4e+03 4.8e+01 1 0 0 0 1 1 0 0 0 1 23
MIS/Agg 4 1.0 4.0890e-02 1.0 0.00e+00 0.0 9.0e+02 7.1e+03 1.4e+01 0 0 0 0 0 0 0 0 0 0 0
SA: col data 4 1.0 2.4671e-02 1.1 0.00e+00 0.0 2.6e+02 1.6e+04 4.0e+01 0 0 0 0 1 0 0 0 0 1 0
SA: frmProl0 4 1.0 1.0792e-01 1.0 0.00e+00 0.0 3.2e+02 1.8e+03 4.0e+01 0 0 0 0 1 0 0 0 0 1 0
SA: smooth 4 1.0 3.8192e+00 1.0 2.75e+07 1.0 7.6e+02 9.5e+03 8.1e+01 1 0 0 0 2 1 0 0 0 2 57
GAMG: partLevel 4 1.0 2.2918e+00 1.0 5.63e+08 1.0 1.6e+03 6.5e+04 1.2e+02 0 0 0 0 3 0 0 0 0 3 1930
repartition 1 1.0 1.0419e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
Invert-Sort 1 1.0 1.0705e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
Move A 1 1.0 3.4499e-04 1.0 0.00e+00 0.0 3.5e+01 1.1e+02 1.9e+01 0 0 0 0 0 0 0 0 0 0 0
Move P 1 1.0 3.2592e-04 1.0 0.00e+00 0.0 1.4e+01 2.6e+01 1.9e+01 0 0 0 0 0 0 0 0 0 0 0
PCSetUp 4 1.0 1.5343e+01 1.0 1.41e+09 1.0 5.7e+03 2.9e+04 5.3e+02 2 0 0 0 13 2 0 0 0 13 726
PCSetUpOnBlocks 2440 1.0 8.8707e-01 1.0 4.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 3821
PCApply 60724 1.0 3.9030e+02 1.0 2.93e+11 1.0 0.0e+00 0.0e+00 0.0e+00 55 43 0 0 0 55 43 0 0 0 5988
Vector 336 336 345797896 0.
Krylov Solver 17 17 252912 0.
Viewer 1 0 0 0.
Average time to get PetscTime(): 1.40667e-06
Average time for zero size MPI_Send(): 7.51019e-06
-log_view
Configure options: --with-mpi-dir=/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64 --with-blaslapack-dir=/app/intel/compilers_and_libraries_2016.1.150/linux/mkl/lib/intel64 --download-hypre=/home/users/nus/tsltaywb/source/git.hypre_org.tar.gz --download-ml=/home/users/nus/tsltaywb/source/ml-v6.2-p4.tar.gz --with-debugging=0 --prefix=/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_O3_rel --with-shared-libraries=0 --known-mpi-shared-libraries=0 --with-fortran-interfaces=1 --CFLAGS="-xHost -g -O3 -openmp" --CXXFLAGS="-xHost -g -O3 -openmp" --FFLAGS="-xHost -g -O3 -openmp"
Libraries compiled on Tue Mar 20 04:26:04 2018 on nus01
Using PETSc arch: petsc-3.8.3_intel2016_O3_rel
Using include paths: -I/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_O3_rel/include -I/home/users/nus/tsltaywb/source/petsc-3.8.3/include -I/home/users/nus/tsltaywb/source/petsc-3.8.3/include -I/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_O3_rel/include -I/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_O3_rel/include -I/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/include
Using libraries: -Wl,-rpath,/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_O3_rel/lib -L/home/users/nus/tsltaywb/source/petsc-3.8.3/petsc-3.8.3_intel2016_O3_rel/lib -lpetsc -Wl,-rpath,/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_O3_rel/lib -L/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel2016_O3_rel/lib -Wl,-rpath,/app/intel/compilers_and_libraries_2016.1.150/linux/mkl/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/mkl/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib/debug_mt -L/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib -L/app/intel/compilers_and_libraries_2016.1.150/linux/ipp/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64 -L/app/intel/compilers_and_libraries_2016.1.150/linux/tbb/lib/intel64/gcc4.4 -L/app/intel/compilers_and_libraries_2016.1.150/linux/daal/lib/intel64_lin -L/app/intel/compilers_and_libraries_2016.1.150/linux/tbb/lib/intel64_lin/gcc4.4 -L/app/intel/compilers_and_libraries_2016.1.150/linux/compiler/lib/intel64_lin -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -Wl,-rpath,/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib/debug_mt -Wl,-rpath,/app/intel/compilers_and_libraries_2016.1.150/linux/mpi/intel64/lib -Wl,-rpath,/opt/intel/mpi-rt/5.1/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/5.1/intel64/lib -Wl,-rpath,/opt/intel/mpi-rt/5.0/intel64/lib/debug_mt -Wl,-rpath,/opt/intel/mpi-rt/5.0/intel64/lib -lHYPRE -lml -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lX11 -lifport -lifcoremt -lmpicxx -ldl -lmpifort -lmpi -lmpigi -lrt -lpthread -limf -lsvml -lirng -lm -lipgo -ldecimal -liomp5 -lcilkrts -lstdc++ -lgcc_s -lirc -lirc_s -ldl
Resource Usage on 2018-03-28 00:37:23.076186:
JobId: 6701296.wlm01
Project: 11000314
Exit Status: 0
CPU Time Used: 01:33:02
Memory Requested: 32gb Memory Used: 18812572kb
Vmem Used: 21312508kb
Walltime requested: 00:25:00 Walltime Used: 00:11:51
