[petsc-users] Problem with solving Poisson eqn for some cases
TAY wee-beng
zonexo at gmail.com
Mon Mar 26 00:15:37 CDT 2018
On 24/3/2018 6:00 AM, Matthew Knepley wrote:
> On Fri, Mar 23, 2018 at 5:23 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> On 21/3/2018 7:47 PM, Matthew Knepley wrote:
>> On Wed, Mar 21, 2018 at 4:59 AM, TAY wee-beng <zonexo at gmail.com
>> On 19/3/2018 6:32 PM, Matthew Knepley wrote:
>>> On Mon, Mar 19, 2018 at 5:19 AM, TAY wee-beng
>>> <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>>> On 17/3/2018 1:15 AM, Matthew Knepley wrote:
>>>> On Fri, Mar 16, 2018 at 12:54 PM, TAY wee-beng
>>>> On 15/3/2018 6:21 PM, Matthew Knepley wrote:
>>>>> On Thu, Mar 15, 2018 at 3:51 PM, TAY wee-beng
>>>>> Hi,
>>>>> I'm running a CFD code which solves the
>>>>> momentum and Poisson eqns.
>>>>> Due to poor scaling with HYPRE at higher cpu
>>>>> no., I decided to try using PETSc with
>>>>> boomeramg and gamg.
>>>>> I tested for some small cases and it work
>>>>> well. However, for the large problem which has
>>>>> poor scaling, it gives an error when I change
>>>>> my Poisson solver from pure HYPRE to PETSc
>>>>> with boomeramg and gamg.
>>>>> The error is :
>>>>> Caught signal number 11 SEGV: Segmentation
>>>>> Violation, probably memory access out of range
>>>>> I tried using:
>>>>> -poisson_ksp_type richardson -poisson_pc_type
>>>>> hypre -poisson_pc_type_hypre boomeramg
>>>>> -poisson_ksp_type gmres -poisson_pc_type hypre
>>>>> -poisson_pc_type gamg
>>>>> -poisson_pc_gamg_agg_nsmooths 1
>>>>> but they all gave similar error.
>>>>> So why is this so? How should I troubleshoot?
>>>>> I am now running a debug ver of PETSc to check
>>>>> the error msg.
>>>>> 1) For anything like this, we would like to see a
>>>>> stack trace from the debugger or valgrind output.
>>>>> 2) We do have several Poisson examples. Does it
>>>>> fail for you on those?
>>>> Hi,
>>>> Can you recommend me some suitable egs? Esp in Fortran?
>>>> Here is 2D Poisson
>>>> https://bitbucket.org/petsc/petsc/src/4b6141395f14f0c7d1415a2ff0158eec75a27d63/src/snes/examples/tutorials/ex5f.F90?at=master&fileviewer=file-view-default
>>>> <https://bitbucket.org/petsc/petsc/src/4b6141395f14f0c7d1415a2ff0158eec75a27d63/src/snes/examples/tutorials/ex5f.F90?at=master&fileviewer=file-view-default>
>> Hi,
>> I tried to use the different options like ML, MG BoomerAMG
>> and while they worked for the small problem, it failed for
>> the large problem. I checked and compared the 2D Poisson
>> example with my 3D Poisson subroutine. I found that my
>> subroutine is very similar to my momentum subroutine, which
>> is based on KSPSolve:
>> 0. DMDACreate, DMDACreate3d etc
>> 1. Assemble matrix
>> 2. KSPSetOperators, KSPSetType etc
>> 3. KSPSolve
>> However, the 2D Poisson example uses SNESSetDM, SNESSolve
>> etc. So does it matter if I use SNESSolve or KSPSolve?
>> Not if you are using Algebraic Multigrid. "It failed for the
>> large problem" is not descriptive enough. Please send the output of
>> -ksp_view -ksp_monitor_true_residual
>> I also didn't set any nullspace. Is this required for a
>> Poisson eqn solve?
>> If you only have the constant null space, no. Most AMG packages
>> do that one by default.
>> Matt
> Hi,
> I tried to use
> 1. -ksp_view -ksp_monitor_true_residual
> 2. -poisson_ksp_view -poisson_ksp_monitor_true_residual
> However, this did not give any output. May I know why?
> You need to call
> KSPSetFromOptions()
Hi Matt,
But I thought I already called:
call KSPSetOperators(ksp,A_mat,A_mat,ierr)
call KSPGetPC(ksp,pc,ierr)
call KSPSetOptionsPrefix(ksp,"poisson_",ierr)
call KSPSetType(ksp,ksptype,ierr)
ksptype=KSPRICHARDSON
call PCSetType(pc,'hypre',ierr)
call KSPSetFromOptions(ksp,ierr)
Is my sequence of calling wrong?
Thanks.
> after you create it. When you launch valgrind you need
> valgrind --trace-children=yes <exec>
> Matt
> I also tried valgrind:
> ==32157== Memcheck, a memory error detector
> ==32157== Copyright (C) 2002-2012, and GNU GPL'd, by Julian Seward
> et al.
> ==32157== Using Valgrind-3.8.1 and LibVEX; rerun with -h for
> copyright info
> ==32157== Command:
> /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpirun
> ./a.out -poisson_ksp_type richardson -poisson_pc_type hypre
> ==32157==
> ==32159==
> ==32159== HEAP SUMMARY:
> ==32159== in use at exit: 49,981 bytes in 1,137 blocks
> ==32159== total heap usage: 1,542 allocs, 405 frees, 72,030
> bytes allocated
> ==32159==
> ==32159== LEAK SUMMARY:
> ==32159== definitely lost: 0 bytes in 0 blocks
> ==32159== indirectly lost: 0 bytes in 0 blocks
> ==32159== possibly lost: 0 bytes in 0 blocks
> ==32159== still reachable: 49,981 bytes in 1,137 blocks
> ==32159== suppressed: 0 bytes in 0 blocks
> ==32159== Reachable blocks (those to which a pointer was found)
> are not shown.
> ==32159== To see them, rerun with: --leak-check=full
> --show-reachable=yes
> ==32159==
> ==32159== For counts of detected and suppressed errors, rerun with: -v
> ==32159== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 8
> from 6)
> [362]PETSC ERROR:
> [362]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> [362]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> [362]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> <http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> [362]PETSC ERROR: or try http://valgrind.org on GNU/linux and
> Apple Mac OS X to find memory corruption errors
> [362]PETSC ERROR: configure using --with-debugging=yes, recompile,
> link, and run
> [362]PETSC ERROR: to get more information on the crash.
> [362]PETSC ERROR: --------------------- Error Message
> [362]PETSC ERROR: Signal received
> [362]PETSC ERROR: See
> <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> shooting.
> [362]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
> [362]PETSC ERROR: ./a.out on a petsc-3.8.3_intel_rel named std1055
> by tsltaywb Thu Mar 22 17:43:54 2018
> [362]PETSC ERROR: Configure options
> --with-mpi-dir=/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64
> --with-blaslapack-dir=/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mkl/lib/intel64
> --download-hypre=/home/users/nus/tsltaywb/source/git.hypre.tar.gz
> --with-debugging=0
> --prefix=/home/users/nus/tsltaywb/lib/petsc-3.8.3_intel_rel
> --with-shared-libraries=0 --known-mpi-shared-libraries=0
> --with-fortran-interfaces=1 --CFLAGS="-xHost -g -O2"
> --CXXFLAGS="-xHost -g -O2" --FFLAGS="-xHost -g -O2"
> [362]PETSC ERROR: #1 User provided function() line 0 in unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 362
> ==32409==
> ==32409== HEAP SUMMARY:
> ==32409== in use at exit: 52,168 bytes in 1,223 blocks
> ==32409== total heap usage: 3,055 allocs, 1,832 frees, 122,188
> bytes allocated
> ==32409==
> ==32409== 10 bytes in 1 blocks are definitely lost in loss record
> 89 of 319
> ==32409== at 0x4C28A2E: malloc (vg_replace_malloc.c:270)
> ==32409== by 0x466742: xmalloc (in /bin/bash)
> ==32409== by 0x42EC78: ??? (in /bin/bash)
> ==32409== by 0x430462: execute_command_internal (in /bin/bash)
> ==32409== by 0x43320D: ??? (in /bin/bash)
> ==32409== by 0x433629: ??? (in /bin/bash)
> ==32409== by 0x4303BC: execute_command_internal (in /bin/bash)
> ==32409== by 0x43110D: execute_command (in /bin/bash)
> ==32409== by 0x41D6D5: reader_loop (in /bin/bash)
> ==32409== by 0x41CEBB: main (in /bin/bash)
> ==32409==
> ==32409== LEAK SUMMARY:
> ==32409== definitely lost: 10 bytes in 1 blocks
> ==32409== indirectly lost: 0 bytes in 0 blocks
> ==32409== possibly lost: 0 bytes in 0 blocks
> ==32409== still reachable: 52,158 bytes in 1,222 blocks
> ==32409== suppressed: 0 bytes in 0 blocks
> ==32409== Reachable blocks (those to which a pointer was found)
> are not shown.
> ==32409== To see them, rerun with: --leak-check=full
> are not shown.
> ==32409==
> ==32409== For counts of detected and suppressed errors, rerun with: -v
> ==32409== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 8
> from 6)
> ==32157==
> ==32157== HEAP SUMMARY:
> ==32157== in use at exit: 55,861 bytes in 1,202 blocks
> ==32157== total heap usage: 3,249 allocs, 2,047 frees, 125,857
> bytes allocated
> ==32157==
> ==32157== LEAK SUMMARY:
> ==32157== definitely lost: 0 bytes in 0 blocks
> ==32157== indirectly lost: 0 bytes in 0 blocks
> ==32157== possibly lost: 0 bytes in 0 blocks
> ==32157== still reachable: 55,861 bytes in 1,202 blocks
> ==32157== suppressed: 0 bytes in 0 blocks
> ==32157== Reachable blocks (those to which a pointer was found)
> are not shown.
> ==32157== To see them, rerun with: --leak-check=full
> ==32157==
> ==32157== For counts of detected and suppressed errors, rerun with: -v
> ==32157== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 8
> from 6)
> Is this the output I'm supposed to get?
> Thanks!
>> Thanks
>>>>> 3) You can also try ML, which is the same type of
>>>>> MG as GAMG. (--download-ml).
>>> I have recompiled PETSc with ML. Is there an example
>>> command line options which I can use for ML?
>>> -pc_type ml
>>> Another question is generally speaking, is geometric
>>> multigrid (GMG) faster than algebraic?
>>> No, only for the setup time.
>>> I tested on a small problem and the time taken varies
>>> from 1.15min (HYPRE, geometric) to 3.25 (GAMG).
>>> BoomerAMG is 1.45min.
>>> I am not sure what you are running when you say Hypre geometric.
>>> Besides HYPRE, is there any other GMG I can use?
>>> As I said above, it does not converge any faster and the
>>> solve is not faster, its all setup time, so small problems
>>> will look faster.
>>> You should be doing 10-20 iterates. If you are doing more,
>>> MG is not working.
>>> If you truly have a structured grid, then use DMDA in PETSc
>>> and you can use GMG with
>>> -pc_type mg -pc_mg_nlevels <n>
>>> Matt
>>>> My cluster can't connect to the internet. Where can
>>>> I 1st download it?
>>>> Similarly, how can I find out the location of the
>>>> ext software by myself?
>>>> The locations are all in the configure Python modules:
>>>> https://bitbucket.org/petsc/petsc/src/4b6141395f14f0c7d1415a2ff0158eec75a27d63/config/BuildSystem/config/packages/ml.py?at=master&fileviewer=file-view-default
>>>> <https://bitbucket.org/petsc/petsc/src/4b6141395f14f0c7d1415a2ff0158eec75a27d63/config/BuildSystem/config/packages/ml.py?at=master&fileviewer=file-view-default>
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>> Matt
>>>>> Thank you very much.
>>>>> Yours sincerely,
>>>>> TAY Wee-Beng (Zheng Weiming) 郑伟明
>>>>> Personal research webpage:
>>>>> http://tayweebeng.wixsite.com/website
>>>>> <http://tayweebeng.wixsite.com/website>
>>>>> Youtube research showcase:
>>>>> https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
>>>>> <https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA>
>>>>> linkedin: www.linkedin.com/in/tay-weebeng
>>>>> <http://www.linkedin.com/in/tay-weebeng>
>>>>> What most experimenters take for granted before
>>>>> they begin their experiments is infinitely more
>>>>> interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>> What most experimenters take for granted before they
>>>> begin their experiments is infinitely more interesting
>>>> than any results to which their experiments lead.
>>>> -- Norbert Wiener
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> -- Norbert Wiener
>> experiments is infinitely more interesting than any results to
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180326/3aa625dc/attachment-0001.html>
