[petsc-users] What does DMPlexDistribute actually do?
Matthew Knepley
knepley at gmail.com
Sun Mar 25 19:34:53 CDT 2018
On Sun, Mar 25, 2018 at 8:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Mar 25, 2018 at 7:44 PM, Ellen M. Price <
> ellen.price at cfa.harvard.edu> wrote:
>> Here is the full minimal (non)-working example and the problematic
>> output. I'm using PETSc 3.8.0.
> Its not Distribute that is broken, its the cylinder mesh thing. It was
> written only in serial, so it makes the same
> mesh on every process. Here is an example with a box that works.
> master *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
> /PETSc3/petsc/petsc-dev/arch-master-debug/bin/mpiexec -n 2 ./tester
> -refine 5 -petscpartitioner_type simple
> DM Object: 2 MPI processes
> type: plex
> DM_0x84000004_0 in 2 dimensions:
> 0-cells: 36 0
> 1-cells: 60 0
> 2-cells: 25 0
> Labels:
> depth: 3 strata with value/size (0 (36), 1 (60), 2 (25))
> Face Sets: 4 strata with value/size (4 (5), 2 (5), 1 (5), 3 (5))
> marker: 1 strata with value/size (1 (40))
> DM Object: Parallel Mesh 2 MPI processes
> type: plex
> Parallel Mesh in 2 dimensions:
> 0-cells: 22 21
> 1-cells: 34 32
> 2-cells: 13 12
> Labels:
> Face Sets: 3 strata with value/size (1 (5), 2 (2), 4 (3))
> marker: 1 strata with value/size (1 (21))
> depth: 3 strata with value/size (0 (22), 1 (34), 2 (13))
> I will fix the cylinder mesh for you. Should be in the dev branch this
> week.
Okay, it works now
5master *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./tester
-refine 1
DM Object: 1 MPI processes
type: plex
DM_0x84000000_1 in 3 dimensions:
0-cells: 75
1-cells: 182
2-cells: 148
3-cells: 40
Labels:
depth: 4 strata with value/size (0 (75), 1 (182), 2 (148), 3 (40))
DM Object: DM_0x84000000_1 1 MPI processes
type: plex
0-cells: 75
1-cells: 182
2-cells: 148
3-cells: 40
Labels:
-refine 2
type: plex
0-cells: 445
1-cells: 1196
2-cells: 1072
3-cells: 320
Labels:
depth: 4 strata with value/size (0 (445), 1 (1196), 2 (1072), 3 (320))
type: plex
0-cells: 445
1-cells: 1196
2-cells: 1072
3-cells: 320
Labels:
/PETSc3/petsc/petsc-dev/arch-master-debug/bin/mpiexec -n 2 ./tester -refine
1 -petscpartitioner_type simple
type: plex
DM_0x84000004_1 in 3 dimensions:
0-cells: 75 0
1-cells: 182 0
2-cells: 148 0
3-cells: 40 0
Labels:
type: plex
Parallel Mesh in 3 dimensions:
0-cells: 53 57
1-cells: 116 122
2-cells: 84 86
3-cells: 20 20
Labels:
depth: 4 strata with value/size (0 (53), 1 (116), 2 (84), 3 (20))
3 -petscpartitioner_type simple
type: plex
0-cells: 3033 0
1-cells: 8600 0
2-cells: 8128 0
3-cells: 2560 0
Labels:
depth: 4 strata with value/size (0 (3033), 1 (8600), 2 (8128), 3 (2560))
type: plex
0-cells: 1697 1737
1-cells: 4640 4712
2-cells: 4224 4256
3-cells: 1280 1280
Labels:
depth: 4 strata with value/size (0 (1697), 1 (4640), 2 (4224), 3 (1280))
3 -petscpartitioner_type parmetis
type: plex
0-cells: 3033 0
1-cells: 8600 0
2-cells: 8128 0
3-cells: 2560 0
Labels:
type: plex
0-cells: 1648 1648
1-cells: 4544 4544
2-cells: 4177 4177
3-cells: 1280 1280
Labels:
depth: 4 strata with value/size (0 (1648), 1 (4544), 2 (4177), 3 (1280))
and its in this branch
https://bitbucket.org/petsc/petsc/branch/knepley/fix-cylinder-mesh
and in testing.
Matt
> Thanks for reporting that,
> Matt
>> #include <petscdm.h>
>> #include <petscdmplex.h>
>> int main(int argc, char *argv[])
>> PetscInt refine = 0;
>> PetscErrorCode ierr;
>> DM dmplex, dmplex_dist;
>> /* initialize */
>> PetscInitialize(&argc, &argv, NULL, NULL);
>> /* get the refinement level and create the mesh */
>> PetscOptionsGetInt(NULL, NULL, "-refine", &refine, NULL);
>> ierr = DMPlexCreateHexCylinderMesh(PETSC_COMM_WORLD, refine,
>> DM_BOUNDARY_NONE, &dmplex); CHKERRQ(ierr);
>> DMView(dmplex, PETSC_VIEWER_STDOUT_WORLD);
>> ierr = DMPlexDistribute(dmplex, 0,
>> NULL, &dmplex_dist); CHKERRQ(ierr);
>> if (dmplex_dist)
>> DMDestroy(&dmplex);
>> dmplex = dmplex_dist;
>> DMDestroy(&dmplex);
>> /* finalize */
>> PetscFinalize();
>> return 0;
>> $ mpirun -n 2 bin/mwe -refine 2
>> type: plex
>> DM_0x1bde850_0 in 3 dimensions:
>> 0-cells: 445 445
>> 1-cells: 1196 1196
>> 2-cells: 1072 1072
>> 3-cells: 320 320
>> Labels:
>> type: plex
>> 0-cells: 445 445
>> 1-cells: 1196 1196
>> 2-cells: 1072 1072
>> 3-cells: 320 320
>> Labels:
>> $ mpirun -n 4 bin/mwe -refine 2
>> DM Object: 4 MPI processes
>> type: plex
>> DM_0x20c7790_0 in 3 dimensions:
>> 0-cells: 445 445 445 445
>> 1-cells: 1196 1196 1196 1196
>> 2-cells: 1072 1072 1072 1072
>> 3-cells: 320 320 320 320
>> Labels:
>> DM Object: Parallel Mesh 4 MPI processes
>> type: plex
>> Labels:
>> Ellen Price
>> On 03/25/2018 07:29 PM, Matthew Knepley wrote:
>> > On Sun, Mar 25, 2018 at 6:32 PM, Ellen M. Price
>> > <ellen.price at cfa.harvard.edu <mailto:ellen.price at cfa.harvard.edu>>
>> wrote:
>> > I am trying to understand some unusual behavior (at least, given my
>> > current understanding) in DMPlexDistribute. I have created a hex
>> mesh
>> > and distributed it using the following snippet:
>> > /* "-refine" is an option set at runtime */
>> > /* this is from the examples */
>> > ierr = DMPlexDistribute(dmplex, 0, NULL, &dmplex_dist);
>> CHKERRQ(ierr);
>> > if (dmplex_dist)
>> > DMDestroy(&dmplex);
>> > So I do a view operation before and after the distribute call to
>> see how
>> > the DM is structured. I do not understand what happens next:
>> > $ mpirun -n 4 ./myprogram -refine 2
>> > type: plex
>> > DM_0x1f24d50_0 in 3 dimensions:
>> > Labels:
>> (320))
>> > type: plex
>> > Labels:
>> (320))
>> > No matter what I choose for the number of processors, every
>> processor
>> > has a copy of all 320 cells (at this refinement level). Similar
>> behavior
>> > at other refinement levels. The only thing that is changed is the
>> name
>> > of the DM, to "Parallel Mesh". This is not what I would have
>> expected
>> > given the description of DMPlexDistribute in the manual; I thought
>> the
>> > cells would be split up between all available processors.
>> > I am also viewing this mesh in VTK and have noticed that the file
>> size
>> > of the output scales with the number of processors, as if it is
>> really
>> > writing each "copy" of the mesh and data stored in it to one big
>> file.
>> > Again, not what I expected.
>> > Can someone clear up what is going on?
>> > It definitely does not work that way. Can you send the whole code you
>> > are running?
>> > Its hard to tell where the problem might be from snippets. You could
>> > also try running
>> > an example. For instance,
>> > cd $PETSC_DIR/src/snes/examples/tutorials
>> > make ex13
>> > master *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex13
>> > -cells 8,8 -dm_view
>> > DM Object: Mesh 1 MPI processes
>> > type: plex
>> > 0-cells: 81
>> > 1-cells: 208
>> > 2-cells: 128
>> > Labels:
>> > Face Sets: 1 strata with value/size (1 (32))
>> > marker: 1 strata with value/size (1 (64))
>> > depth: 3 strata with value/size (0 (81), 1 (208), 2 (128))
>> > $PETSC_DIR/arch-master-debug/bin/mpiexec -n 4 ./ex13 -cells 8,8
>> -dm_view
>> > DM Object: Mesh 4 MPI processes
>> > type: plex
>> > 0-cells: 26 26 27 25
>> > 1-cells: 57 57 58 56
>> > 2-cells: 32 32 32 32
>> > Labels:
>> > Face Sets: 1 strata with value/size (1 (8))
>> > marker: 1 strata with value/size (1 (17))
>> > depth: 3 strata with value/size (0 (26), 1 (57), 2 (32))
>> > $PETSC_DIR/arch-master-debug/bin/mpiexec -n 7 ./ex13 -cells 8,8
>> -dm_view
>> > DM Object: Mesh 7 MPI processes
>> > type: plex
>> > 0-cells: 17 16 16 17 17 17 19
>> > 1-cells: 34 33 33 35 34 35 35
>> > 2-cells: 18 18 18 19 18 19 18
>> > Labels:
>> > Face Sets: 1 strata with value/size (1 (5))
>> > marker: 1 strata with value/size (1 (11))
>> > depth: 3 strata with value/size (0 (17), 1 (34), 2 (18))
>> > Thanks,
>> > Matt
>> > Ellen Price
>> > What most experimenters take for granted before they begin their
>> > experiments is infinitely more interesting than any results to which
>> > their experiments lead.
>> > -- Norbert Wiener
>> > https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180325/13db00e2/attachment-0001.html>
