[petsc-users] What does DMPlexDistribute actually do?
Ellen M. Price
ellen.price at cfa.harvard.edu
Sun Mar 25 18:44:33 CDT 2018
Here is the full minimal (non)-working example and the problematic
output. I'm using PETSc 3.8.0.
#include <petscdm.h>
#include <petscdmplex.h>
int main(int argc, char *argv[])
PetscInt refine = 0;
PetscErrorCode ierr;
DM dmplex, dmplex_dist;
/* initialize */
PetscInitialize(&argc, &argv, NULL, NULL);
/* get the refinement level and create the mesh */
PetscOptionsGetInt(NULL, NULL, "-refine", &refine, NULL);
ierr = DMPlexCreateHexCylinderMesh(PETSC_COMM_WORLD, refine,
DM_BOUNDARY_NONE, &dmplex); CHKERRQ(ierr);
DMView(dmplex, PETSC_VIEWER_STDOUT_WORLD);
ierr = DMPlexDistribute(dmplex, 0,
NULL, &dmplex_dist); CHKERRQ(ierr);
if (dmplex_dist)
DMDestroy(&dmplex);
dmplex = dmplex_dist;
DMDestroy(&dmplex);
/* finalize */
PetscFinalize();
return 0;
$ mpirun -n 2 bin/mwe -refine 2
DM Object: 2 MPI processes
type: plex
DM_0x1bde850_0 in 3 dimensions:
0-cells: 445 445
1-cells: 1196 1196
2-cells: 1072 1072
3-cells: 320 320
Labels:
depth: 4 strata with value/size (0 (445), 1 (1196), 2 (1072), 3 (320))
DM Object: Parallel Mesh 2 MPI processes
type: plex
Parallel Mesh in 3 dimensions:
0-cells: 445 445
1-cells: 1196 1196
2-cells: 1072 1072
3-cells: 320 320
Labels:
$ mpirun -n 4 bin/mwe -refine 2
DM Object: 4 MPI processes
type: plex
DM_0x20c7790_0 in 3 dimensions:
0-cells: 445 445 445 445
1-cells: 1196 1196 1196 1196
2-cells: 1072 1072 1072 1072
3-cells: 320 320 320 320
Labels:
DM Object: Parallel Mesh 4 MPI processes
type: plex
Labels:
Ellen Price
On 03/25/2018 07:29 PM, Matthew Knepley wrote:
> On Sun, Mar 25, 2018 at 6:32 PM, Ellen M. Price
> <ellen.price at cfa.harvard.edu <mailto:ellen.price at cfa.harvard.edu>> wrote:
> I am trying to understand some unusual behavior (at least, given my
> current understanding) in DMPlexDistribute. I have created a hex mesh
> and distributed it using the following snippet:
> /* "-refine" is an option set at runtime */
> /* this is from the examples */
> ierr = DMPlexDistribute(dmplex, 0, NULL, &dmplex_dist); CHKERRQ(ierr);
> if (dmplex_dist)
> DMDestroy(&dmplex);
> So I do a view operation before and after the distribute call to see how
> the DM is structured. I do not understand what happens next:
> $ mpirun -n 4 ./myprogram -refine 2
> type: plex
> DM_0x1f24d50_0 in 3 dimensions:
> Labels:
> type: plex
> Labels:
> No matter what I choose for the number of processors, every processor
> has a copy of all 320 cells (at this refinement level). Similar behavior
> at other refinement levels. The only thing that is changed is the name
> of the DM, to "Parallel Mesh". This is not what I would have expected
> given the description of DMPlexDistribute in the manual; I thought the
> cells would be split up between all available processors.
> I am also viewing this mesh in VTK and have noticed that the file size
> of the output scales with the number of processors, as if it is really
> writing each "copy" of the mesh and data stored in it to one big file.
> Again, not what I expected.
> Can someone clear up what is going on?
> It definitely does not work that way. Can you send the whole code you
> are running?
> Its hard to tell where the problem might be from snippets. You could
> also try running
> an example. For instance,
> cd $PETSC_DIR/src/snes/examples/tutorials
> make ex13
> master *$:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex13
> -cells 8,8 -dm_view
> DM Object: Mesh 1 MPI processes
> type: plex
> Mesh in 2 dimensions:
> 0-cells: 81
> 1-cells: 208
> 2-cells: 128
> Labels:
> Face Sets: 1 strata with value/size (1 (32))
> marker: 1 strata with value/size (1 (64))
> depth: 3 strata with value/size (0 (81), 1 (208), 2 (128))
> $PETSC_DIR/arch-master-debug/bin/mpiexec -n 4 ./ex13 -cells 8,8 -dm_view
> DM Object: Mesh 4 MPI processes
> type: plex
> 0-cells: 26 26 27 25
> 1-cells: 57 57 58 56
> 2-cells: 32 32 32 32
> Labels:
> Face Sets: 1 strata with value/size (1 (8))
> marker: 1 strata with value/size (1 (17))
> depth: 3 strata with value/size (0 (26), 1 (57), 2 (32))
> $PETSC_DIR/arch-master-debug/bin/mpiexec -n 7 ./ex13 -cells 8,8 -dm_view
> DM Object: Mesh 7 MPI processes
> type: plex
> 0-cells: 17 16 16 17 17 17 19
> 1-cells: 34 33 33 35 34 35 35
> 2-cells: 18 18 18 19 18 19 18
> Labels:
> Face Sets: 1 strata with value/size (1 (5))
> marker: 1 strata with value/size (1 (11))
> depth: 3 strata with value/size (0 (17), 1 (34), 2 (18))
> Thanks,
> Matt
> Ellen Price
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
