[petsc-users] VecGetArrayReadF90 with gfortran
Samuel Lanthaler
s.lanthaler at gmail.com
Sun Mar 25 12:10:08 CDT 2018
Dear Satish,
Yes, I used the makefile you provided.
On 23.03.2018 19:00, Satish Balay wrote:
> Have you compiled the my modified code with petsc makefile that I provided?
> I've check with - but I can't reproduce this problem.
> balay at es^/sandbox/balay/test $ gfortran --version
> GNU Fortran (GCC) 6.2.0
> Copyright (C) 2016 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> Satish
> On Fri, 23 Mar 2018, Samuel Lanthaler wrote:
>> Thank you very much for your effort Satish. It appears that even in your
>> version of the example, I'm having the same problem with a pointer that is not
>> properly assigned. Seems weird, I also tried recompiling petsc, but that gave
>> me the same. The configure file for petsc is also attached.
>> Btw. It appears the latest version of gfortran I have access to on my work
>> station is gcc-6.3.
>>>> mpif90 --version
>> GNU Fortran (GCC) 6.3.0
>> Does anyone maybe have any ideas?
>> Thanks,
>> Samuel
>> On 03/23/2018 05:42 PM, Satish Balay wrote:
>>> Attaching the modified version that works with complex [using complex build
>>> of petsc]
>>> BTW: I'm using the following gfortran [but I don't think the version makes
>>> any difference] with petsc-3.8 (maint branch):
>>> GNU Fortran (GCC) 8.0.1 20180222 (Red Hat 8.0.1-0.16)
>>> Satish
>>> balay at asterix /home/balay/download-pine
>>> $ make ex2f
>>> mpif90 -c -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g
>>> -I/home/balay/petsc/include -I/home/balay/petsc/arch-cmplx/include -o
>>> ex2f.o ex2f.F90
>>> mpif90 -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -o ex2f
>>> ex2f.o -Wl,-rpath,/home/balay/petsc/arch-cmplx/lib
>>> -L/home/balay/petsc/arch-cmplx/lib
>>> -Wl,-rpath,/home/balay/soft/mpich-3.3b1/lib
>>> -L/home/balay/soft/mpich-3.3b1/lib
>>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/8
>>> -L/usr/lib/gcc/x86_64-redhat-linux/8 -lpetsc -llapack -lblas -lX11 -lpthread
>>> -lm -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lmpicxx -lstdc++ -lm
>>> -L/usr/lib/gcc/x86_64-redhat-linux/8 -ldl
>>> -Wl,-rpath,/home/balay/soft/mpich-3.3b1/lib -lmpi -lgcc_s -ldl
>>> /usr/bin/rm -f ex2f.o
>>> $ ./ex2f
>>> setting values
>>> assembling vector
>>> copying vector to array
>>> N = 10
>>> m = 10
>>> getting vecX size
>>> getting ownership range
>>> ownership range: 0 10
>>> copy values to global array
>>> vecX_pt:
>>> SIZE = 10
>>> (1.0000000000000000,0.0000000000000000)
>>> (2.0000000000000000,0.0000000000000000)
>>> (3.0000000000000000,0.0000000000000000)
>>> (4.0000000000000000,0.0000000000000000)
>>> (5.0000000000000000,0.0000000000000000)
>>> (6.0000000000000000,0.0000000000000000)
>>> (7.0000000000000000,0.0000000000000000)
>>> (8.0000000000000000,0.0000000000000000)
>>> (9.0000000000000000,0.0000000000000000)
>>> (10.000000000000000,0.0000000000000000)
>>> copy_buffer =
>>> calling allreduce
>>> buffer =
>>> On Fri, 23 Mar 2018, Satish Balay wrote:
>>>> I'm attaching the modified code - that appears to work fine for me. My
>>>> changes are:
>>>> 1. use .F90 suffix - so the compiler does the f90 freeform/preprocessing
>>>> automatically
>>>> 2. remove slepc references and use petsc only
>>>> 3. compile with a petsc formatted makefile
>>>> 4. replace complex with real*8 - thats compatible with PetscScalar
>>>> So perhaps you can modify your version of test code - to be closer to
>>>> this one [or vice versa] to see what is triggering the difference in
>>>> behavior.
>>>> Satish
>>>>> Hi all,
>>>>> I am having trouble using the function VecGetArrayReadF90 under gfortran.
>>>>> I
>>>>> have created a minimal example and put it in the attachment. Basically, it
>>>>> appears that the input pointer is empty upon return from
>>>>> VecGetArrayReadF90. The code runs fine, when compiled with ifort, so I
>>>>> don't know what's going on.
>>>>> I am attaching the code and makefile that I used, as well as the command
>>>>> line output that I can see. Though the errors are just to do with the fact
>>>>> that the output pointer is empty, so the command line output is not all
>>>>> that helpful...
>>>>> Thanks in advance for your help!
>>>>> Sam
