[petsc-users] Obtain the preconditioned matrix
Sat Mar 24 12:45:37 CDT 2018
On Sat, Mar 24, 2018 at 10:30 AM, 我 <dayedut123 at 163.com> wrote:
> Hi Matt,
> I found my error! It's due to the output part in my code. How stupid I am!
> When I "Script" the matrix_viewer, I found the none-zero values. I'm ready
> to check my output code. Please forgive my stupid. Thank you for your
> patient reply! Hope you have a nice day!
I am glad you were able to solve it. There are no stupid questions.
   Matt
> Thank you very much!
> daye
> At 2018-03-24 19:58:57, "Matthew Knepley" <knepley at gmail.com> wrote:
> On Sat, Mar 24, 2018 at 8:56 AM, 我 <dayedut123 at 163.com> wrote:
>> Hi Matt,
>> I have tested my code with a really small matrix(10*10) just now and the
>> preconditioned matrix is obtained. But for my case, the output is still
>> equal to zero. I'm thinking if it is because this coefficient matrix is too
>> ill. In my case, due to the Dirichlet boundary condition, I multiply a
>> really huge number(e.g. 1e+10) at the matrix's given position. So this
>> matrix is combined with some really huge numbers. I don't know if it will
>> influence the preconditioned matrix output.
> Try changing the PC to Jacobi and see what you get. I think its not the
> huge numbers.
>   Thanks,
>      Matt
>> The viewer is PETSC_VIEWER_STDOUT_WORLD.
>> Thanks again!
>> daye
>> At 2018-03-24 19:26:34, "Matthew Knepley" <knepley at gmail.com> wrote:
>> On Sat, Mar 24, 2018 at 8:15 AM, 我 <dayedut123 at 163.com> wrote:
>>> Hi Matt,
>>> Sorry to distribute you again. I still have trouble with
>>> KSPComputeExplicitOperator. I reduced the matrix size to around 1000*1000.
>>> The time-cost of this function is acceptable, but when I output the
>>> preconditioned matrix, all the values are equal to zero! Here is part of my
>>> codes, do I operate error with this function?
>>> PC pc;
>>> KSP ksp;
>>> Mat A,PA;
>>> Vec b,x;
>>> ierr=KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>> ierr=KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>>> ierr=KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>> ierr=PCSetType(pc,PCHYPRE);CHKERRQ(ierr);
>>> ierr=KSPSetType(ksp,KSPGMRES);CHKERRQ(ierr);
>>> ierr=KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>> ierr=KSPSolve(ksp,b,x);CHKERRQ(ierr);
>>> ierr=KSPComputeExplicitOperator(ksp,&PA);
>> There is no need to assemble the output matrix.
>>> ierr=MatAssemblyBegin(PA,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>> ierr=MatAssemblyEnd(PA,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> What kind of viewer are you using? The code above should work. I would
>> step through
>> in the debugger to see why one column is all zeros, or try it in an
>> example like
>> SNES ex5 to make sure its not a problem in your code.
>>   Thanks,
>>     Matt
>>> ierr=MatView(PA,viewer);CHKERRQ(ierr);
>>> Daye
>>> At 2018-03-23 07:41:26, "Matthew Knepley" <knepley at gmail.com> wrote:
>>> On Thu, Mar 22, 2018 at 8:29 PM, 我 <dayedut123 at 163.com> wrote:
>>>> Hi all,
>>>> I want to analyze the preconditioned matrix. But the
>>>> KSPComputeExplicitOperator costs too much time to obtain the matrix. My
>>>> origin matrix is about 3000*3000 sparse one. I noticed this function is
>>>> applicable for the relative small system. What's the matrix-size limitation
>>>> for this function? And for my case, any suggestions to solve it with less
>>>> time?
>>> This is just a really expensive operation. There is no way around it.
>>>    Matt
>>>> daye
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180324/7c15de64/attachment.html>
