[petsc-users] VecGetArrayReadF90 with gfortran
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Fri Mar 23 11:25:56 CDT 2018
  Hmm, try removing the initial assignment of that variable to NULL.
   Barry
> On Mar 23, 2018, at 10:37 AM, Samuel Lanthaler <s.lanthaler at gmail.com> wrote:
> Thanks for your answers.
> @Timothee: I think normally, it should be fine to use the pointer like an array. At least, I have done the same in some other cases. But I can try anyways.
> @Barry: Replacing the copy by a for-loop does not seem to help in this case: the output pointer has LBOUND=1 and UBOUND=0, SIZE=0, so that trying to access any index leads to a segfault.
> On 03/23/2018 04:30 PM, Smith, Barry F. wrote:
>>    Use a loop to do the copy
>> At line 127 of file allreduce.f90
>> Fortran runtime error: Array bound mismatch for dimension 1 of array 'copy_buffer' (10/0)
>>> On Mar 23, 2018, at 9:10 AM, Samuel Lanthaler <s.lanthaler at gmail.com> wrote:
>>> Hi all,
>>> I am having trouble using the function VecGetArrayReadF90 under gfortran. I have created a minimal example and put it in the attachment. Basically, it appears that the input pointer is empty upon return from VecGetArrayReadF90. The code runs fine, when compiled with ifort, so I don't know what's going on.
>>> I am attaching the code and makefile that I used, as well as the command line output that I can see. Though the errors are just to do with the fact that the output pointer is empty, so the command line output is not all that helpful...
>>> Thanks in advance for your help!
>>> Sam
>>> <output.txt><makefile><allreduce.f90>
