[petsc-users] slepc-master does not configure correctly
Jed Brown
jed at jedbrown.org
Wed Mar 21 20:34:22 CDT 2018
Yes, DESTDIR is something that is only used during "make install". If
you had a prefix install of PETSc, it should get PETSC_DIR (set to that
prefix) and empty PETSC_ARCH.
"Kong, Fande" <fande.kong at inl.gov> writes:
> Hi All,
> ~/projects/slepc]> PETSC_ARCH=arch-darwin-c-debug-master ./configure
> *Checking environment...Traceback (most recent call last): File
> "./configure", line 10, in <module>
> execfile(os.path.join(os.path.dirname(__file__), 'config',
> 'configure.py')) File "./config/configure.py", line 206, in <module>
> log.write('PETSc install directory: '+petsc.destdir)AttributeError: PETSc
> instance has no attribute 'destdir'*
> SLEPc may be needed to synchronized for new changes in PETSc.
> Thanks,
> Fande Kong
