[petsc-users] Copy MPIAIJ Matrix onto MPISeq Matrices on All Processors
Tue Mar 20 10:18:30 CDT 2018
On Tue, Mar 20, 2018 at 10:56 AM, Ali Berk Kahraman <
aliberkkahraman at yahoo.com> wrote:
> Now I see my problem. What I want to do is to generate many rows of
> Jacobian once. For this, the method that must be used is coloring. If I am
> to try it without calling coloring, I have no way but to give the all
> processes the whole data, but as you have pointed out it is very very
> nonscalable. It instantly multiplies the memory use with number of
> processors.
> What I would recommend is to use the built-in support for smaller problems
while you get everything working (either -snes_fd or -snes_mf)
and then we can figure out how to coloring you stuff. We have support for
  - Cartesian meshes
  - Known matrix non-zero patterns
  - (Some) unstructured grids
    Matt
> Thank you very much for your constructive replies.
> Ali
> On 20-03-2018 17:30, Matthew Knepley wrote:
> On Tue, Mar 20, 2018 at 10:11 AM, Ali Berk Kahraman <
>> First of all, thank you for elaboration.
>> The problem is, I want to generate J myself, using FD, for the following
>> reason.
> Okay. This generation should happen entirely inside FormJacobian(), so you
> do not need MFFD.
>> I have a WORLD matrix M that I feed into F(u) using user defined context
>> pointer *ctx. And I call collective functions on that matrix.
> That should be fine. To be very precise, when you create the SNES, you
> give it a comm. The FormFunction() and FormJacobian()
> functions are collective on this comm.
>> I call a for loop inside CreateJacobian function to perturb the F()
>> entries one by one. But since I have collective calls on a WORLD matrix M
>> inside F, I have to do this virtually sequentially(not "truly" sequential,
>> but other processes must wait while one is calling F()). I cannot have two
>> different processes perturb the u vector at different locations, this
>> confuses the collective calls on that matrix (or so I have observed, maybe
>> there was another bug in my code.).
> Okay, this is a "bug" in your FD algorithm. What collective calls are you
> making when doing the finite difference?
> Note that if you really do need collective calls, then you are serializing
> the construction of this matrix, meaning no matter
> how many procs you use, the sequence will still be as long as one proc.
> If, however, that is really what you want, then
> you need to make sure that everyone calls that function for each
> perturbation. This means you need to tell everyone how
> many calls they need to make (either sum(perturbations) or
> max(perturbations) depending on what you are doing). You
> can use MPI_Allreduce() for this at the start of your function.
>> Here, what I want to do is to have a SELF copy of the u vector and the
>> input matrix M to F() on every process, so every process can independently
>> work the data. So, I need a way to copy the WORLD matrix into SELF. My
>> current idea is to write the WORLD matrix as a binary file, and read it
>> into a SELF matrix.
> That is really nonscalable. I cannot believe this is really what you want
> to do. However, you can do it using
> VecScatterCreateToAll() and
>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/
> MatCreateSubMatrices.html
> However, I would write out the algorithm in more detail than you have
> explained it here. So far, I am not
> convinced you should be doing this.
>   Thanks,
>     Matt
>> I am aware that what I want to do should be done using coloring, much
>> memory and time effective. But, I am working on adaptive grid finite
>> differences so there is not an easy way to create coloring on my grid. If
>> there is a Petsc function that generates the coloring for me, I can also
>> try it.
>> My apologies, even the simple form got this long :)
>> On 20-03-2018 16:47, Matthew Knepley wrote:
>> On Tue, Mar 20, 2018 at 9:31 AM, Ali Berk Kahraman <
>>> Thank your for the reply.
>>> I have tried it, but could not get it to work. For it to work, I have to
>>> know at which vector entry the epsilon in the FD approximation is to be
>>> added. It is an input for my inexpensive function, and I could not find a
>>> way to pass it in using MFFD context.
>> MFFD has it in the context as current_u. There is no accessor, but we can
>> easily write one. However, that is not how MFFD works. Here is the idea:
>>   You give us a function F, your inexpensive function. We get to call F
>> however we want to call it, and produce the action of the matrix. So for
>> instance,
>>   we could do this
>>     F(x + h u) - F(x)
>>              h ||u||
>>   but we do not have to do that. You should not worry about how we
>> perturb the function, you just return the value of the function when we
>> call it.
>>> I have been trying to get it working with PETSC_COMM_WORLD too with no
>>> luck. My guess is that my FormRHSFunction becomes a collective function on
>>> WORLD, so I cannot generate many separate copies each doing its own thing.
>>> For this reason I am trying to move it to SELF, but I cannot do that if I
>>> cannot find a way to represent my WORLD matrix input fully on each process.
>> I think things have gotten too confused here for us to help. Lets step
>> back and simplify. Can you tell us briefly exactly what you want to
>> accomplish? I will start by
>> explaining SNES. We are essentially doing Newton's method. This means
>> calculating a step du, based on an initial solution u, using this equation
>>   J(u) du = -F(u)
>> so we need a function to form the residual F, and maybe the Jacobian J
>> but we can also form it using calls to F.
>> It sounds like you want to do something inside F, but I cannot figure out
>> what yet.
>>   Thanks,
>>      Matt
>>> Sorry I am stuck in the same question, but any ideas on how to move a
>>> matrix from WORLD to SELF, similar to the way it is possible with vectors
>>> using VecScatter?
>>> On 19-03-2018 21:08, Smith, Barry F. wrote:
>>>> On Mar 19, 2018, at 12:00 PM, Ali Berk Kahraman <
>>>>> Dear All,
>>>>> I have to create my Jacobian numerically using an FD function I have
>>>>> written, but the problem is that the function evaluation FormRHSFunction
>>>>> creates PETSC_COMM_WORLD objects in it, and takes 1 PETSC_COMM_WORLD matrix
>>>>> as an input.  So I cannot work it on parallel (every processor calculating
>>>>> its own portion of Jacobian), I tried but the machine gets confused.
>>>>     Huh. It is fine to have the function work on PETSC_COMM_WORLD, and
>>>> it can be in parallel.
>>>>> My initial idea was to create the objects in PETSC_COMM_SELF type
>>>>> within the RHS function, but the input COMM_WORLD matrix standed where it
>>>>> was. So my question is, is there a way to get a complete copy of a
>>>>> distributed matrix on all the processors as seq matrices?
>>>>> I cannot use the Petsc's version FD function because the
>>>>> FormRHSFunction I call to create the Jacobian is slightly different than
>>>>> the original FormRHSFunction. The original function is too expensive, so I
>>>>> only calculate the relevant parts of it in the Jacobian function.
>>>>     You can do this with MatCreateMFFD() and set your inexpensive
>>>> function as the function.
>>>> Best Regards,
>>>>> Ali Berk Kahraman
>>>>> M.Sc. Student, Mechanical Engineering
>>>>> Bogazici Uni. Istanbul, Turkey
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180320/853f8d22/attachment-0001.html>
