[petsc-users] Problem with solving Poisson eqn for some cases
Mark Adams
mfadams at lbl.gov
Thu Mar 15 07:26:32 CDT 2018
On Thu, Mar 15, 2018 at 3:51 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> I'm running a CFD code which solves the momentum and Poisson eqns.
> Due to poor scaling with HYPRE at higher cpu no., I decided to try using
> PETSc with boomeramg and gamg.
> I tested for some small cases and it work well. However, for the large
> problem which has poor scaling, it gives an error when I change my
> Poisson solver from pure HYPRE to PETSc with boomeramg and gamg.
> The error is :
> Caught signal number 11 SEGV: Segmentation Violation, probably memory
> access out of range
> I tried using:
> -poisson_ksp_type richardson -poisson_pc_type hypre -poisson_pc_type_hypre
> boomeramg
> -poisson_ksp_type gmres -poisson_pc_type hypre -poisson_pc_type_hypre
> boomeramg
> -poisson_pc_type gamg -poisson_pc_gamg_agg_nsmooths 1
> but they all gave similar error.
Did hypre segv?
In addition to what Matt said, given that this error only occurs on large
runs, you can also try
1) test a debug version. This can sometimes give more info like a stack
trace.
2) If you can't get a stack trace, try running with -poisson_pc_type
jacobi. This is a dead simple solver.
> So why is this so? How should I troubleshoot? I am now running a debug ver
> of PETSc to check the error msg.
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng (Zheng Weiming) 郑伟明
> Personal research webpage: http://tayweebeng.wixsite.com/website
> Youtube research showcase: https://www.youtube.com/channe
> l/UC72ZHtvQNMpNs2uRTSToiLA
> linkedin: www.linkedin.com/in/tay-weebeng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180315/dd5a5cf9/attachment-0001.html>
