[petsc-users] Non deterministic results with MUMPS?
Tim Steinhoff
kandanovian at gmail.com
Wed Mar 14 10:06:29 CDT 2018
Fande,
thank you for your answer. Yes, of course you are totally right and I
could not agree more.
So far we are fine with accuracy/variance of the results. My main
intention is to figure out, if that is really supposed to be like that
due to for example dynamic load balancing of the method or if it is a
bug in MUMPS / PETSc-Interface. If it is possible, we would prefer to
know that this is expected behaviour instead of guessing. Just to feel
certain. :-)
Kind regards,
Volker
2018-03-14 15:27 GMT+01:00 Fande Kong <fdkong.jd at gmail.com>:
> We had the similar problem before with superlu_dist, but it happened only
> when the number of processor cores is larger than 2. Direct solvers, in our
> experiences, often involve more messages (especially non-block
> communication). Then this causes different operation orders, and have
> different results. BUT, the differences do not matter as long as your
> formula is stable.
> The problem we had before was that the convergence path even changed from
> run to run, and it turned out because our formula was unstable.
> If you do not trust MUMPS at this point, you could use it as a
> preconditioner together with a Krylove method (such as GMRES). The
> preconditioner may not affect your solution as long as it is not singular.
> Fande,
> On Wed, Mar 14, 2018 at 5:10 AM, Tim Steinhoff <kandanovian at gmail.com>
> wrote:
>> I guess that the partioning is fixed, as two results can also differ
>> when I call two successive solves, where matrix and rhs vector and
>> everything is identical.
>> In that case the factorization/partitioning is reused by MUMPS and
>> only the solving phase is executed twice, which alone leads to
>> slightly different results on two processes.
>> The MUMPS manual says that there is some kind of dynamical task
>> scheduling for the pivoting part, but I could not find any
>> information, if they use something similar in the solving phase.
>> 2018-03-13 21:59 GMT+01:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>> >> On Mar 13, 2018, at 1:10 PM, Tim Steinhoff <kandanovian at gmail.com>
>> >> wrote:
>> >> Thanks for your fast reply.
>> >> I see that I can't expect the same results when changing the number of
>> >> processes, but how does MPI change the order of operations, when there
>> >> are for example 2 processes and the partitioning is fixed?
>> > Hmm, how do you know the partitioning is fixed? Is there the use of
>> > a random number generator in MUMPS or the partitioning packages uses?
>> > Barry
>> >> With GMRES I could not prorduce that behavior, no matter how many
>> >> processes.
>> >> 2018-03-13 18:17 GMT+01:00 Stefano Zampini <stefano.zampini at gmail.com>:
>> >>> This is expected. In parallel, you cannot assume the order of
>> >>> operations is
>> >>> preserved
>> >>> Il 13 Mar 2018 8:14 PM, "Tim Steinhoff" <kandanovian at gmail.com> ha
>> >>> scritto:
>> >>>> Hi all,
>> >>>> I get some randomness when solving certain equation systems with
>> >>>> MUMPS.
>> >>>> When I repeatedly solve the attached equation system by ksp example
>> >>>> 10, I get different solution vectors and therefore different residual
>> >>>> norms.
>> >>>> jac at jac-VirtualBox:~/data/rep/petsc/src/ksp/ksp/examples/tutorials$
>> >>>> mpiexec -np 4 ./ex10 -f ./1.mat -rhs ./1.vec -ksp_type preonly
>> >>>> -pc_type lu -pc_factor_mat_solver_package mumps
>> >>>> Number of iterations = 1
>> >>>> Residual norm 4.15502e-12
>> >>>> Residual norm 4.17364e-12
>> >>>> It seems to be depending on a combination of number of processes and
>> >>>> the equation system.
>> >>>> I used GCC 7.2.0, Intel 16, MUMPS 5.1.1 / 5.1.2 (with & without
>> >>>> metis/parmetis), openMPI 2.1.2. All with the same results.
>> >>>> PETSc configuration is the current maint branch:
>> >>>> ./configure --download-mumps --with-debugging=0 --COPTFLAGS="-O3"
>> >>>> --CXXOPTFLAGS="-O3" --FOPTFLAGS="-O3" --with-scalapack
>> >>>> Using "--download-fblaslapack --download-scalapack" didnt make a
>> >>>> difference neither.
>> >>>> Can anyone reproduce that issue?
>> >>>> Thanks and kind regards,
>> >>>> Volker
