[petsc-users] Could not execute "['git', 'rev-parse', '--git-dir']"
Kong, Fande
fande.kong at inl.gov
Wed Mar 7 15:53:54 CST 2018
On Wed, Mar 7, 2018 at 2:51 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 7 Mar 2018, Kong, Fande wrote:
> > > If you need to workarround this - you can comment out that test
> (3lines)..
> > > File "/home/kongf/workhome/projects/petsc-3.7.7/config/
> > > BuildSystem/config/package.py", line 519, in updateGitDir
> > > gitdir,err,ret = config.base.Configure.executeShellCommand([self.
> sourceControl.git,
> > > 'rev-parse','--git-dir'], cwd=self.packageDir, log = self.log)
> > "#self.updateGitDir()" works.
> I meant just the 3 lines - not the whole function.
I knew this. "3 lines" does not work at all.
I forgot the error message.
Fande,
> diff --git a/config/BuildSystem/config/package.py
> b/config/BuildSystem/config/package.py
> index 85663247ce..439b2105c5 100644
> --- a/config/BuildSystem/config/package.py
> +++ b/config/BuildSystem/config/package.py
> @@ -516,9 +516,9 @@ class Package(config.base.Configure):
> # verify that packageDir is actually a git clone
> if not os.path.isdir(os.path.join(self.packageDir,'.git')):
> raise RuntimeError(self.packageDir +': is not a git repository!
> '+os.path.join(self.packageDir,'.git')+' not found!')
> - gitdir,err,ret = config.base.Configure.executeShellCommand([self.sourceControl.git,
> - if gitdir != '.git':
> - raise RuntimeError(self.packageDir +': is not a git repository!
> "git rev-parse --gitdir" gives: '+gitdir)
> + #gitdir,err,ret = config.base.Configure.executeShellCommand([self.sourceControl.git,
> + #if gitdir != '.git':
> + # raise RuntimeError(self.packageDir +': is not a git repository!
> prefetch = 0
> if self.gitcommit.startswith('origin/'):
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180307/6405410f/attachment-0001.html>
