[petsc-users] error with MPI + ifort
Adrián Amor aamor at pa.uc3m.es
Wed Mar 7 09:34:21 CST 2018
Hi Praveen,
did you try to include the PETSC_AVOID_MPIF_H? I mean, include:
-DPETSC_AVOID_MPIF_H=1 when using mpiifort and I think that the problem
will be solved.
2018-03-07 15:53 GMT+01:00 Praveen C <cpraveen at gmail.com>:
> Dear all
> In a code like this
> subroutine checkgrid(g)
> #include <petsc/finclude/petscsys.h>
>    use petscsys
>    use mgrid
>    use celldata
>    use comdata
>    implicit none
>    type(grid),intent(in) :: g
>    ! Local variables
>    integer        :: i, j, v, tc, nv
>    PetscInt       :: v1, v2
>    PetscErrorCode :: ierr
>    ! Sum g%nvl over all partitions.
>    Call MPI_Allreduce(g%nvl, nv, 1, MPI_INT, MPI_SUM, &
>                       PETSC_COMM_WORLD, ierr); CHKERRQ(ierr)
> end subroutine checkgrid
> we get an error while compiling with mpich-3.2.1 + ifort + petsc-3.8.x
> mpifort -c -O3 -fpp -nogen-interface -W1 -WB -DNS -DVERSION=\"f8e6c025\"
> -I/usr/local/share/applications/Intel_Compiler/petsc/include
> -I/usr/local/share/applications/Intel_Compiler/hdf5/include -DHDF5 -Tf
> checkgrid.F90 -o checkgrid.o -free
> checkgrid.F90(40): error #6405: The same named entity from different
> modules and/or program units cannot be referenced.   [MPI_SUM]
> compilation aborted for checkgrid.F90 (code 1)
> It works fine with clang and gnu compilers.
> Thanks
> praveen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180307/1fee310c/attachment.html>
