[petsc-users] Load balancing / redistributing a 1D DM
Jed Brown jed at jedbrown.org
Mon Mar 5 07:31:42 CST 2018
Dave May <dave.mayhem23 at gmail.com> writes:
> For a 1D problem such as yours, I would use your favourite graph
> partitioner (Metis,Parmetis, Scotch) together with your cell based
> weighting and repartition the data yourself.
That's overkill in 1D.  You can MPI_Allreduce(SUM) and MPI_Scan(SUM) the
weights, then find the transition indices in each subdomain.  It'll be
cheaper, more intuitive/deterministic, and avoid the extra library
dependency.  Of course if you think you may want to move to multiple
dimensions, it would make sense to consider DMPlex or DMForest.
